Old 03-11-2011, 11:25 AM   #1
grossgary
Member#: 88368
1989 XT6
Default What are EJ25 head cc's?
Cometic says they can help me if I figure out the cc's of:
EJ25D heads (DOHC).
and 2000 Forester SOHC EJ25 heads.
I want to use an EJ25D block in a 2000 forester but the EJ25D pistons stick out above the deck. Cometic offers their thickest headgasket at 140 thousands, or 3.5mm and I'm wondering if that's enough to allow the SOHC heads to bolt to the EJ25D block.
grossgary is offline   Reply With Quote
Old 03-12-2011, 06:26 PM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
The pistons only clear the deck by .015-.018". A standard .040" thick gasket is fully suitable for the application.
PS: Is this EJ25D block already in your possession? If so, measure it ya jackwagon....
Jay
Old 03-12-2011, 08:09 PM   #3
grossgary
Member#: 88368
1989 XT6
great, thanks for your time Jay. didn't want to waste time or tear down a motor if someone already knows. i frequent/moderate two other subaru forums and while I experiment and figure things out (who else converts an EJ25 to FWD auto and EJ18? is there a yawn smiley? ) I realize most things are already known. motor came out today and sits next to the "new" EJ25D.
What would the compression ratio be with a 96 ej20H shortblock with 96 ej25 heads? hotshot2109 Subaru Conversions 3 10-10-2005 11:02 AM
What is the factory cc's of STI 04-05 USDM S14guy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 11-16-2004 01:55 PM
Engine Builders: head cc's and deck height Forsa Normally Aspirated with bolt-on Forced Induction Powertrain 7 07-31-2003 01:40 AM
Engine Builders: head cc's and deck height Forsa Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-24-2003 10:30 AM
What are possible bad effects for a EJ25 that used to be turboed? balajc Normally Aspirated with bolt-on Forced Induction Powertrain 1 01-27-2003 05:11 PM
