Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 03-11-2011, 12:12 PM   #1
island boyeee
Member#: 171758
2006 WRX Ltd Stg m@!
Blk&Grn / 08 Daytona 675
Default Oil keeps leaking from drain plug
This has been going on for over a year. I've tried the crush washers in both orientations, I've tried over-tightening the drain plug. No there aren't two washers on there.
None of this has been able to prevent a very slow drip from the drain plug. Is it possible I need a new plug? Only thing I could think is maybe the threads got stretched out a little... Nothing is stripped though, as I have cranked on that thing as I hard as I can until it wouldn't budge.
Just wondering if anyone else has this problem.
island boyeee is offline   Reply With Quote
Old 03-11-2011, 12:15 PM   #2
rexspeedworthy
Member#: 26965
2011 WRX
DarkGray
wrap the drain plug threads with teflon tape?
rexspeedworthy is offline   Reply With Quote
Old 03-11-2011, 12:25 PM   #3
SeeeeeYa
Member#: 129681
2014 FXT Touring
This happened to me on my 05 LGT. In my case it turned out to be... I had never removed the stock O-ring, merely putting a new one on at oil changes like I always did, doubling them up and leaving a leaky seal.
Determined to find what was causing the leak, at about the third oil change I inspected the drain plug... on close inspection I could see there was an O-ring already on it, painted black like the plug, and stuck so tightly I had to use a knife to separate and remove it. New O-ring and leak was gone.
Next new Suby I was smarter and FIRST oil change I got that stock one out of there. It seems they paint the pan with the plug/O-ring installed, so the O-ring isn't really visible, and is sometimes seriously stuck on the plug.
I'd check this first... better than trying RTV or teflon tape, both of which I used until I found the root cause.
SeeeeeYa is offline   Reply With Quote
Old 03-11-2011, 01:40 PM   #4
island boyeee
Member#: 171758
I wasn't sure Teflon tape was ok for this application...
I'm glad you mentioned that, because every time I look at my drain plug I am convinced it's made of 2 different materials. I might have to look more closely next time, and actually see if there is a washer there I can pry of. If that is so, than that thing is SERIOUSLY crushed on there. Exact same diameter as the head of the bolt too. I may just buy a new bolt. Just did an oil change so I don't want to let it all run out.
Old 03-11-2011, 03:28 PM   #5
b00stin
Member#: 212898
05 CGM STi
WFC #289
Do you have to the oil temp plug?
b00stin is offline   Reply With Quote
Old 03-11-2011, 03:30 PM   #6
island boyeee
Member#: 171758
^ no.
Old 03-11-2011, 05:29 PM   #7
boost4life
Member#: 75129
09 WRX stg 2+
Lost the boxer rumble
This thing is awsome no more mess or burned hands http://fumotousa.com/
boost4life is offline   Reply With Quote
Old 03-11-2011, 07:46 PM   #8
island boyeee
Member#: 171758
i've heard of those things leaking too
Old 03-11-2011, 07:59 PM   #9
424wrx
Member#: 171948
08 wrx prem sedan
vf52 swap. bilstein susp
i have one too. its never dripped once in 3 years. also oil doesnt splash everywhere like taking out the stock drainplug.
424wrx is offline   Reply With Quote
Old 03-11-2011, 08:52 PM   #10
dakrat
Member#: 272840
2011 STI
is turning a wrench 1/4 a turn too much work?
putting that in the drain hole gives it the added thickness to the hole and traps more oil in the pan... if you want to remove as much old oil every oil change, don't put anything in the drain hole...
dakrat is offline   Reply With Quote
Old 03-11-2011, 08:57 PM   #11
dakrat
Member#: 272840
2011 STI
the stock crusher ring on mine is stuck to the bolt and was painted together. it is impossible to find it if you are not looking for it.
Old 03-11-2011, 09:07 PM   #12
boost4life
Member#: 75129
09 WRX stg 2+
Same here no problems
Old 03-11-2011, 09:07 PM   #13
PeteJM
Member#: 244836
2012 Legacy 3.6R LM
+1 on the stuck washer. Mine has had the same issue when I bought it. Crush washer was plastered to the drain plug.
PeteJM is offline   Reply With Quote
Old 03-11-2011, 09:08 PM   #14
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Definitly check for the original crush washer. As already stated, the pans are assembled and then painted (epoxy paint I believe). So sometimes those washers are 1) really hard to tell they are not part of the bolt, and 2) a wicked pain to get off.
The pan bolt torque is 32ft/lbs. Make sure you either torque to spec or are VERY certain in your skills to eyeball it. Under and you won't properly crush the crush washer, too much and you risk striping the skimpy 3 threads that hold the plug.
KillerBMotorsport is offline   Reply With Quote
Old 03-11-2011, 09:10 PM   #15
boost4life
Member#: 75129
09 WRX stg 2+
No it's not to hard , Have you seen one in person? If you did you'd think different, It's not holding that much oil back esp on the Subaru oil pan that narrows on the bottom.
Old 03-11-2011, 11:41 PM   #16
jetski247
Member#: 188171
04 sti baby
wrb
you must be running a really good synthetic......lol.......
jetski247 is offline   Reply With Quote
Old 03-12-2011, 02:19 AM   #17
atomicfire
Member#: 136296
2005 STi
I have one and I love it. A little bit of oil left over in the pan isn't going to hurt anything.
My father has these on all of his cars as well. I also had a few friends in college that had them on supras and other STi's.
None of them have ever leaked or come open on their own.
atomicfire is offline   Reply With Quote
Old 03-12-2011, 08:55 AM   #18
boost4life
Member#: 75129
09 WRX stg 2+
Notice how the pan narrows at the bottom, With about 2 threads protruding into the pan do you really thing it makes that much difference? Most oil change places drain oil for 30 seconds I drain mine for 20-30 mins.
Old 03-12-2011, 05:25 PM   #19
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ It's not that it protrudes into the pan as much as the Fumoto's hole is much smaller than the OEM plug and in the center.
Pre-06 pans hold ~180ml of oil after "fully" drained.
and
Post-06 pans holds ~80ml of oil after "fully" drained.
I would guess the Fumoto would add about another 100ml to that, but that's a guess.
Old 03-12-2011, 06:03 PM   #20
b00stin
Member#: 212898
05 CGM STi
WFC #289
100 ml is nothing compared to the amounts left in the motor after an oil change. Just my .02
Old 03-12-2011, 08:29 PM   #21
jetski247
Member#: 188171
04 sti baby
wrb
you can jack the car up on the passanger side.
Old 03-12-2011, 08:32 PM   #22
b00stin
Member#: 212898
05 CGM STi
WFC #289
That way too involved for very little results in my opinion. Especially if you change your oil on a lift.
Old 03-12-2011, 08:43 PM   #23
jetski247
Member#: 188171
04 sti baby
wrb
ok, you can use a vacuum pump like we use on jet skis. it'll get quite a bit out, better than draining, not sure how a baffle on the pan will hinder this but iv'e used it a couple times on my car and pulled the plug and no oil came out.
Old 03-12-2011, 08:47 PM   #24
b00stin
Member#: 212898
05 CGM STi
WFC #289
ok, you can use a vacuum pump like we use on jet skis. it'll get quite a bit out, better than draining, not sure if a baffle on the pan will hinder this but iv'e used it a couple times on my car and pulled the plug and no oil came out.
True, but every mechanic I have ever talked to about residual oil after oil changes has said it makes no difference. The motors were designed this way. So if you really want every drop out, with no results, than sure a vacuum pump or tilting your car is for you. Personally I'll just keep changing every 3k and call it good. Whatever puts your mind at ease though.
Old 03-12-2011, 08:48 PM   #25
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Yes, you'd have to tip the car at a rediculous angle. Just jacking from the passenger side makes little difference, if any.
Oil change without removing drain plug... Konvict Alaskan Impreza Club Forum -- AKIC 15 09-30-2006 12:44 AM
Oil/Coolant leak from GT35R the_owl Factory 2.5L Turbo Powertrain 3 03-18-2005 04:55 PM
Oil leaking from spark plug wells normal?! Seeing StaRS Normally Aspirated Powertrain 25 06-28-2004 11:11 PM
Leaking Coolant Drain Plug (What am I missing?) maclif Factory 2.0L Turbo Powertrain 6 11-04-2002 08:24 AM
Oil leaking from spark plug area... anyone else had this? BoomerRS Technical Forum Archive 7 06-29-2000 05:16 AM
Message Board Statistics All times are GMT -4. The time now is 12:23 AM.
