Old 03-12-2011, 09:02 PM   #26
boost4life
Member#: 75129
09 WRX stg 2+
Lost the boxer rumble
I figure by letting the oil drain at least 15 minutes i'm getting more oil out then most people are. I usually open the valve and find something to do for 15 minutes or so.
I also can tell you almost all Caterpillar engines have a similar design FUMOTO type valve.
They come this way from the factory.
boost4life is offline   Reply With Quote
Old 03-12-2011, 09:40 PM   #27
jetski247
Member#: 188171
04 sti baby
wrb
lol........i thought we were talking about ways to get all the oil out, yes, i don't change my oil every time with those methods but if i have the vacuum pump already out from another change then i just use it. and assuming that we have 80ml left in the pan and tilting the car spilled out 20ml, thats a good percentage but overkill no doubt.
the tilting the car was a joke, really.
i wouldn't worry about the 80-100ml left in the bottom of the pan either.
jetski247 is offline   Reply With Quote
Old 07-23-2012, 09:17 PM   #28
subime4life
Member#: 181178
2006 wrx wagon
pewter
What way is the crush washer supposed to face? I'm having slight leak at the drain plug and I believe I may have put it on wrong.
subime4life is offline   Reply With Quote
Old 07-23-2012, 11:29 PM   #29
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
sounds like if the op cant stop the leak maybe its time for a new oil pan.
scby rex is offline   Reply With Quote
Old 07-24-2012, 10:16 AM   #30
island boyeee
Member#: 171758
2006 WRX Ltd Stg m@!
Blk&Grn / 08 Daytona 675
I always put the flat side against the bolt. That way the side that crushes can conform to the shape of the oil pan.
island boyeee is offline   Reply With Quote
Old 07-24-2012, 11:45 AM   #31
subime4life
Member#: 181178
2006 wrx wagon
pewter
And you've had no leaks?
Old 07-24-2012, 11:56 AM   #32
island boyeee
Member#: 171758
nope. sometimes i give it a tiny extra crank if need be
Old 07-24-2012, 11:57 AM   #33
Andrewxxcarlson
Member#: 316415
2006 WRX
Originally Posted by boost4life View Post
This thing is awsome no more mess or burned hands http://fumotousa.com/
[quote] is turning a wrench 1/4 a turn too much work?
putting that in the drain hole gives it the added thickness to the hole and traps more oil in the pan... if you want to remove as much old oil every oil change, don't put anything in the drain hole... [quote]
I've never had a problem with the valve drain plug. I just maybe use half a quart just to make sure I get all the excess grime oil in the pan and my pans clean
Andrewxxcarlson is offline   Reply With Quote
Old 12-04-2012, 08:30 PM   #34
sreggie101
Member#: 337458
2012 WRX Hatch
PBP
didn't want to start a new thread. but i just did my first oil change a couple days ago and found today that there was an oil leak. really small. but found the small puddle and looked under just now and found a drop dangling from the oil drain plug. suggestions? car is brand new. im seeing some people had an issue with the old washer that is impossible to notice unless u were looking for it?
kind of feel like a lame since an oil change is an easy thing to do. im sure i tightened the plug all the way without ODing on torque. but if an old washer is in the way then i lose my oil right?
NM didnt find my oem washer on my oem plug (replaced with magnetic plug) so im pretty sure i have two washers on my car...problem solved i guess.
sreggie101 is offline   Reply With Quote
Old 12-04-2012, 09:01 PM   #35
crfnick56
Member#: 329410
2003 bugeye wagon
Sonic Yellow
I would suggest a new drainplug, they do not have the washer painted to them, this way you know for certain that you are only using one gasket, not two
crfnick56 is offline   Reply With Quote
Old 12-05-2012, 01:40 AM   #36
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
If you tighten it too much you will warp the Oil pan its self! When you crank on the drain plug like hulk would.... you end up twisting the actual threaded piece that is welded to the inside of the pan. This distorts the outside of the pan and thus.... a leak that will never stop. There are only 3 small spot welds that hold the threaded part to the inside of the pan, its very easy to twist it and distort the sealing area just enough to cause a leak.
Picture of what happens when people over tighten or try to reuse the crush washer and it leaks so they tighten it more.
UK-Wagon is offline   Reply With Quote
Old 12-05-2012, 10:58 AM   #37
sreggie101
Member#: 337458
2012 WRX Hatch
PBP
the magnetic plus i used has a separate washer. does the OEM not come with a washer or are you saying its part of the plug?
hoping that isn't the case. will look this weekend. out of curiosity what would it cost to repair that? can i put the OEM plug back in and get it covered under warranty?
Old 12-05-2012, 11:19 AM   #38
danger1138
Member#: 279525
04 rex luger!
I would use one round of teflon tape..
danger1138 is online now   Reply With Quote
Old 12-05-2012, 04:55 PM   #39
dsn112
Member#: 332561
2016 WRX LTD
Did my first change, had the drip, took the plug out and changed again. Took the new crush washer I just used off. Then took a box cutter around the rim of the bolt, broke the paint seal and voila, factory crush washer broke loose. No more leaks
dsn112 is offline   Reply With Quote
Old 12-09-2012, 12:02 PM   #40
sreggie101
Member#: 337458
2012 WRX Hatch
PBP
found that the aftermarket magnetic plug wasn't fitting in snug as i had imagined. putting the OEM plug back in stopped the leak easy. oh well.
Old 12-17-2012, 04:10 AM   #41
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
No, warpage is not covered under warranty! They don't warp on their own, its purely from over tightening. The repair is $87 for a new pan and 1.5 hrs labor @ what ever the shop rate is of that shop.
Oil change without removing drain plug... Konvict Alaskan Impreza Club Forum -- AKIC 15 09-30-2006 12:44 AM
Oil/Coolant leak from GT35R the_owl Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-18-2005 04:55 PM
Oil leaking from spark plug wells normal?! Seeing StaRS Normally Aspirated Powertrain 25 06-28-2004 11:11 PM
Leaking Coolant Drain Plug (What am I missing?) maclif Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-04-2002 08:24 AM
Oil leaking from spark plug area... anyone else had this? BoomerRS Technical Forum Archive 7 06-29-2000 05:16 AM
