Old 03-11-2011, 12:34 PM   #1
TRSCobra
Member#: 181009
`12 MZ3 Skyactiv
'12 C300 4matic Sport
Default Ringland failures with ELH?
I've read on a few forums that a possible cause for ringland failures on cyl's 2 and 4 is due to higher EGT's with the stock unequal length manifold.
If this is true, has anyone running an equal length header had ringlands crack?
TRSCobra is offline   Reply With Quote
Old 03-11-2011, 01:16 PM   #2
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Yes
#3 is a common one to crack too.
People have tried to blame the excessive #4 failures on everything imaginable. What comes to mind is:
#4 has longer exhaust manifold runners which leads to higher EGTs
#4 receives fuel later in the path (fuel gets to other cylinders first so the pressure has dropped by the time it gets to #4)
The intake manifold flows more air to #4 so it runs consistently leaner
The factory ECU runs more timing on #4 than the others so it will be the first to knock and trigger the ECU to pull timing (the ECU can hear knock better on #4 than the others because that's where the knock sensor is)
Old 03-11-2011, 02:07 PM   #3
A-man07
Member#: 271525
07 STi
424whp/382wtq GT3076
Well-tuned cars live longer no matter what the mods.
A-man07 is online now   Reply With Quote
Old 03-11-2011, 02:10 PM   #4
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
^true so true.
stretchedk7 is offline   Reply With Quote
Old 03-11-2011, 05:32 PM   #5
boost4life
Member#: 75129
09 WRX stg 2+
Lost the boxer rumble
I think EL header is a step in the right direction, Nothing other then a good tune can prevent that.
boost4life is offline   Reply With Quote
And I Thought Ringland Failures were for the 2.5 motors... dux10 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-18-2011 03:32 PM
Ringland discussion with SUBARU UK on facebook motec 88 General Community 3 09-02-2010 03:56 AM
School me on ringland failure...preventive measures? JDMFLCL Newbies & FAQs 12 06-18-2009 09:33 PM
MAF failure with JC intake.......... Mprezive Normally Aspirated Powertrain 19 03-07-2001 11:02 PM
