Old 03-11-2011, 11:03 PM   #1
wizzle-stick
Member#: 160534
2002 impreza rs
Default new ej25 full rebuild oil question
im doing a full rebuild on my 02 ej25 and was wondering about what kind of oil to put in it once its together
when i say full rebuild, i mean new piston heads and bearings and vatting the block
i plan on doing synth blend, but was curious about the weight i should use. i have always used 10w40, but, during break in after the rebuild, what do you guys recommend?
wizzle-stick is offline   Reply With Quote
Old 03-11-2011, 11:28 PM   #2
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
5w30 during break in and for the rest of the life of the engine unless you're getting it VERY hot or VERY cold.
Old 03-12-2011, 01:21 AM   #3
rhino6303
Member#: 181314
2005 Impreza OBS SRR
05 Legacy GT RBP
Make sure to use Dino oil and not synthetic or a blend during the break in.
rhino6303 is offline   Reply With Quote
Old 03-13-2011, 11:42 PM   #4
wizzle-stick
Member#: 160534
2002 impreza rs
just out of curiosity, why dino oil on break in?
what drawbacks does using synthetic on a rebuild have?
Old 03-13-2011, 11:44 PM   #5
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I have been able to find absolutely no scientific justification for not using synth for break in. I've found thousands of people advising against it for no justifiable reason. I break in on dino simply because it's cheaper and I'm doing 3 oil changes in the first 2,000mi. Then I switch to synth because of its better protection properties. Money no object, I'd run it from the start.
Old 03-14-2011, 10:51 AM   #6
wizzle-stick
Member#: 160534
2002 impreza rs
ok cool. thats kinda what i thought but wanted to make sure.
Thanks for the info.
AMS EJ25 Engine Rebuild Kits - Discounted Packages For Built Motors! AMS Engine/Power/Exhaust 6 09-17-2010 05:35 PM
WTB: EJ25 phase 2 Crank new to almost new, needed for rebuild (Portland) OregonRS-Dude NWIC Private Classifieds 11 04-09-2008 11:27 PM
NA ej25 build/rebuild cueball89 Built Motor Discussion 0 02-22-2008 12:44 PM
EJ25 engine rebuild! boomer3 Normally Aspirated Powertrain 24 01-31-2008 06:14 PM
ej25 headgasket rebuild spdracr00 Normally Aspirated Powertrain 6 01-12-2006 01:12 PM
