Old 07-15-2002, 01:44 PM   #1
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Default Why would you heat a Nitrous bottle?
Realize I have no intention of using NAWS in my car, just curious why you would want to heat the bottle.
Old 07-15-2002, 01:49 PM   #2
Jademonkey
Member#: 9213
2000 RS
Red
If a bottle gets too cold, it will reduce pressure in the bottle. If you heat it up, it will increase.
My guess is that if it gets too cold, you're getting less NOS, and if you give it just a little heat, it will keep the pressure constant. You don't want to keep the bottle "hot" though...too much pressure...
Jademonkey is offline   Reply With Quote
Old 07-15-2002, 02:05 PM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
keeps the pressure high and constant to get the best N2O flow.
jeremy
Old 07-15-2002, 02:16 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
To answer my own question, I found this in a faq
A bottle that had 800 psi at 75 degrees would fall to 450 psi at 30 degrees, and only 275 psi at O degrees.
On the other side of the coin, heating the bottle increases the pressure, but heat also tends to make the N2O vaporize in the line between the solenoid valve and the discharge nozzle, which upsets metering and reduces N2O flow. Ideally, the bottle and lines should be kept at room temperature. At the drags, some cooling of the bottle may be required to achieve this while the car sits in the staging lanes, but a damp cloth or towel wrapped around the bottle will generally be all that's required. If you really want to pursue additional cooling, chill the line between the solenoidvalve and the nozzle, and keep that line as short as possible to reduce the likelihood of vaporization before the discharge nozzles.
Why can't you recycle plastic water bottle caps? Thaddy Off-Topic 11 06-18-2009 06:05 PM
If you get oil temp gauge why would you want oil pressure? casualsurfer Interior & Exterior Modification 18 06-18-2005 07:06 PM
On what other Subarus can you put a WRX suspension? Why would you want to? rex n effect Brakes, Steering & Suspension 3 06-29-2003 06:47 PM
Why would you port the exhaust manifold at the heads? Red Rocket Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-21-2002 10:01 PM
Why would you want a STI? PanamaJack General Community 50 07-09-2002 01:24 AM
