Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 07-15-2002, 02:16 PM   #1
Z1 Performance
Member#: 9327
Default Replacement front rotors for 91 Turbo
What other Subaru (pref. with larger rotors) fot on my BC5 chassis?
Mine need to be replaced, and I figure I mind as well go for the biggest possible for aesthetic reasons.
These must fit under the stock 15 inch turbo wheels though
thanks!
Z1 Performance is offline   Reply With Quote
Old 07-15-2002, 02:48 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
See what the outbacks have....
You're pretty much limited since you want to stay with 15" wheels. If you had 16" you could go with the 11.4" WRX rotors & calipers.
Buy some stock rotors & have them cryo-treated www.onecryo.com $20 per rotor.
That'd be probably the cheapest option, then just get some good pads. The rotors will be a lot more durable with the cryo treatment.
Josh
Legacy777 is offline   Reply With Quote
Old 07-15-2002, 10:40 PM   #3
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default I dont know exactly what wheels......
you have but the WRX/OB/Legacy GT brakes(11.4") may well fit under them. If you know some nearby with a WRX, pop one of your wheels on and see if they fit. There is plenty of clearence under the 16s and I know the will fit under some 15s. The four pots will even fit under some 15s.
subysouth
subysouth is offline   Reply With Quote
Old 07-15-2002, 11:16 PM   #4
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default wait
I see youve got a WRX-see above.
Old 07-16-2002, 01:42 AM   #5
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Anything 10.9" and smaller will obviously fit, as that was the diameter of the stock front units. I'm uncertain as to whether the 11.4" brakes will fit, but i'd say it's worth a try.
Dave
DLC is offline   Reply With Quote
Old 07-16-2002, 02:17 AM   #6
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
I really don't think you can go much bigger than RS or OB-spec under the 15's. I had next to no clearance when I was running the stockers......
sybir is offline   Reply With Quote
Old 07-17-2002, 01:02 AM   #7
Z1 Performance
Member#: 9327
Well, I found the set of rortrs from my 99 Rs from when I first did the Prodrive brakes...will fit them tomorrow, with my new to me gold 98 rims!
Old 07-17-2002, 07:08 PM   #8
Jgrahn555
Member#: 3224
Default Dude!
I hate to be a dick and all, but you're the vendor; you should be the one answering these questions, not asking!
order some stock, try them out, then let us know what you've found out. If they're too big, sell them as upgrades, if they're too small, return them to the vendor.
-Jason
Jgrahn555 is offline   Reply With Quote
Old 07-17-2002, 08:18 PM   #9
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Adam: the RS brakes are SMALLER than the stock Legacy Turbo rotors, and probably thinner as well.
Why 15"?
You can get replacement rotors from Autozone for pretty cheap, why not do that?
Dave
Old 07-19-2002, 12:24 PM   #10
Z1 Performance
Member#: 9327
JGrahn - I don't know about you, but I am not in the practice ordering stuff that "might" fit and returning it if it doesn't..I like to know it WILL fit, otherwise, it is just a waste of my supplier's and my time. Plus, these guys ar ehte Legacy experts: nned to know what to do, what not to do on your RS or WRX, then I am the one to talk too, but for other Subaru's, I am admittedly a bit in the dark!
DLC - we fitted my MY99 rotors yesterday..same exact size as the ones that were on there, and the RS rotors are thicker too.
I wanted them to fit the stock 15's as I intend to use them (with Blizzaks) for the winter assuming I keep the car.
For now, I got a set of gold MY98 RS rims and 205/55/16 Yokohama A520's
Old 07-20-2002, 02:35 PM   #11
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Perhaps it was the MY98 that had 10.5" front rotors, and they switched in 99.
Regardless, that's good information anyway.
I need to get some WRX wheels and serious snow tires this season, as Ecsta 712s aren't snow tires. Granted, my car was basically FWD last winter with the tranny going south, and the 5MT works a lot better, but there's no comparison between an AWD car on summer tires and a FWD/RWD car on true snow tires, much less an AWD on serious tires.
Dave
WTT 2007 STI FRONT ROTORS for 2004 STI FRONT rotors NotoriousD Private 'Wanted' Classifieds 0 12-18-2006 02:57 PM
Replacing front rotors, keeping old pads, is breaking in necessary? Drew888 Brakes, Steering & Suspension 5 05-22-2006 04:36 PM
Need to replace front rotors/pads on 2002 OBS - Need Advice! mekkon Brakes, Steering & Suspension 6 04-24-2006 07:16 PM
Is it ok to replace front rotor/pad only for now? GOT_WRX Brakes, Steering & Suspension 7 06-02-2005 02:08 PM
best replacement front rotors for least amount of $$$ IgotWRXed Brakes, Steering & Suspension 16 08-02-2004 02:07 PM
