Old 02-26-2012, 11:36 PM   #51
shisnick
Member#: 303263
2008 Impreza WRX
That may be the case, but hey you got more psace than I do! I'm house hunting so hopefully I'll find a place with a decent sized garage. Hopefully I can find a Scooby club around here that can help with some of the other mods I'm lookin at doing. Anyway, lookin forward to the rest of the build buddy!
shisnick is offline   Reply With Quote
Old 02-29-2012, 10:38 AM   #52
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Thanks and good luck with the house hunting!
Finally got this wrapped up........
After numerous setbacks the rear end is finally finished and aligned, and this all started because of a wheel barring...? The first issue was the massive amount of rust on all the trailing and latter arm bolts, so they all had to be cut off and replaced. After removal of OEM arms that was one day of waiting on parts. The next issue was finding my backing plates to be basically rusted away to nothing, so I have to either get new plates or get new complete hubs with plates, luckily I had both options sitting in the garage. ( backing plates were bought for this car a month after I got it because I saw the bad BP then. The hubs were for my show car, as it needs new wheel barrings an all for corners ) I figures I just swap the whole hub and be done with it, well that was not as easily done as expected. After swapping the hubs and getting all the new suspension bits bolted on, I had forgotten the caliper mounts where a different spacing . So now everything has to come off again and the hubs had to be pressed apart and the backing plates swapped off the 06 hubs to 05 and older backing plates so my 03 calipers would bolt on......did I mention That was another day of waiting to have the barrings pressed apart, and them being told that would destroy them and new ones need to go in before pressing together. Luckily, I had not considered the 06 hubs where the better STi type barrings, so that was an unforeseen upgrade
All this happened 48 hours before my scheduled alignment at R/T Tuning.
I cant say i feel a ton of difference but that is more than likely due to the large suspension upgrades done to the wagon already.
dangerousatom is offline   Reply With Quote
Old 03-31-2012, 05:01 PM   #53
shisnick
Member#: 303263
2008 Impreza WRX
......pics!!
Old 04-25-2012, 08:14 PM   #54
dangerousatom
Member#: 70710
Progress:
Finally got around to starting multiple projects on the Wagon again......
Gauge Pod for the Drivers side of the dash
I had made one of these for my GC Wagon a few years ago and really liked the position of the 3 gauges compared to the center dash or the Pillar, so here we go again!!
Spec C Roof Scoop
Got this on ebay from a guy who drives rally's in Poland......for a steal! It was pretty filthy with green tree mold and bug guts plaster all on the under side. Few passes of lacquer thinner and it was cleaned up and ready for primer.
STi 04^ rear fender flairs
Im sick or the rust starting to form in the usual spots just above the rear bumper and quarter panel area. In addition to the rust Im slicing the rear tires on the inner fender lip, so it will be easier to flair it the pull and roll it.
...........more pic's to follow
Old 04-27-2012, 07:38 PM   #55
dangerousatom
Member#: 70710
Old 04-27-2012, 09:04 PM   #56
slackaforlife
Member#: 236679
02 WRX
the quick pin design on the rear bars is ingenious. gives me ideas for my next car (gf8). have you considered making it a three door?
slackaforlife is offline   Reply With Quote
Old 04-27-2012, 10:13 PM   #57
dangerousatom
Member#: 70710
Huh? Three door? . . . Like welding the rear passenger doors shut?
Old 04-28-2012, 04:53 AM   #58
stg2wgn
Member#: 182387
2004 Wrx Wagon
WRB - stg. 2
i love checking in on your wagon and getting ideas for mine.
stg2wgn is offline   Reply With Quote
Old 04-28-2012, 06:59 AM   #59
CatfaceType-R
Member#: 81102
Lots of w1n going on in here. Sub'd
CatfaceType-R is offline   Reply With Quote
Old 04-28-2012, 11:09 AM   #60
dangerousatom
Member#: 70710
Thanks Guys....hope to get the Gauge Pod laid up tonite
Old 04-28-2012, 02:03 PM   #61
slackaforlife
Member#: 236679
02 WRX
like removing the middle section.
kinda like this,
http://bbs.scoobynet.com/members-gal...es-please.html
Old 04-28-2012, 03:37 PM   #62
dangerousatom
Member#: 70710
O I C......
nah I need them doors for grocery-getting and parts runs along with hauling peeps. It does look pretty clean though.
Old 04-29-2012, 05:27 PM   #63
dangerousatom
Member#: 70710
My last pod in the GC8 wagon did not fit quite as tight into the dash lines as I would have liked so I molded out the A-pillar/dash area. Hopefully I will be able to get the current pod and the dash mold to marry up in a way that will a nice tight fit.....?
Old 04-29-2012, 08:56 PM   #64
shisnick
Member#: 303263
2008 Impreza WRX
Holy crap you've been busy! Nice job!! Might have to send some $'s your way for a nice guage pod myself! Keep it up dude! Great work!
Old 04-29-2012, 10:07 PM   #65
dangerousatom
Member#: 70710
Heh . . . Actually I'm a bit impatient. There for there is a space heater currently running in my Wagon to help cook the resin over night while it's like 40 degrees outside.
Old 05-01-2012, 11:05 PM   #66
dangerousatom
Member#: 70710
After glassing the dash cast to the pod
Covered and Trimmed just before wetting
Fully wetted out.... hopefully this is on the money and it will be on to bondo?
Old 05-06-2012, 10:39 PM   #67
dangerousatom
Member#: 70710
Today I installed a few more goodies......
Cuso Motor and Trans mounds along with Whiteline Trans bushings
Carbing Light Weight Sub Frame
After 15-20 miles of driving I can already feel and hear the difference in the transmission and its response. The Sub Frame is defiantly an improvement in handling.
Old 05-07-2012, 01:07 AM   #68
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
nice parts!! haha
D Money is offline   Reply With Quote
Old 05-07-2012, 01:09 PM   #69
dangerousatom
Member#: 70710
Originally Posted by D Money View Post
nice parts!! haha
More then nice for the price!!
Old 05-11-2012, 12:03 AM   #70
dangerousatom
Member#: 70710
Got this trick little 4 step shift light to put into the gauge pod.....
After the first coat of bondo and a quick scuff
About 3 coats of bondo later and lots of sanding and dash fitment
Hopefully I will finish this up on Sunday or Monday, and then off to Black Plasti Dip
Old 05-11-2012, 12:06 AM   #71
MGigantelli44
Member#: 234591
2004 STI
youre crazy man!
beater
MGigantelli44 is offline   Reply With Quote
Old 05-11-2012, 12:09 AM   #72
RScoobyy
Member#: 236276
2006 OBP WRX Wagon
I can't wait to see that pod, it looks sweet!
RScoobyy is offline   Reply With Quote
Old 05-11-2012, 12:16 AM   #73
dangerousatom
Member#: 70710
Originally Posted by MGigantelli44 View Post
youre crazy man!
beater
Yup...drive it like I stole it, I Kiss Redline at least 3-4 times a week Hopfully the shift light will give me a jump on nearing 7200rpms at like 6500...?
Thanks! I hope it comes out like I want, my last pod from the 97 GCF was ok but not to my particular standards in precise fitment.
Old 05-11-2012, 12:34 AM   #74
dangerousatom
Member#: 70710
Ah forgot to mention I was at a local Dyno Day last weekend and found out Im making more power then I assumed......
301whp & 297tq
Old 05-11-2012, 10:24 AM   #75
Dr. octagon
Member#: 171127
GDA BW 8375 SOLD
Bump because this is good ****
Dr. octagon is offline   Reply With Quote
Is this a good deal for a DD Beater? memma Off-Topic 18 07-23-2010 01:48 PM
Looking for cheap DD/Beater/Commuter. heavyarmscustoms NESIC Private Classifieds 14 07-09-2010 11:57 AM
Dangerousatom's new turbo crap box "91 Leg SS" dangerousatom Member's Car Gallery 45 06-19-2010 12:27 AM
FS: Great DD/beater - 2006 Nissan Sentra 1.8S AT JeromeS13 SWIC Private Classifieds 2 05-15-2010 02:27 AM
(feeler)WTB DD beater jeep cherokee or grand cherokee bjwk89 Tri-State Area Private Classifieds 4 06-20-2008 10:12 PM
