Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 03-13-2011, 05:39 PM   #1
PHATsuby
Member Sales Rating: (12)
Member#: 13617
2001 Legacy GT back
to stock is a project too
Default 2009 STi Brembo Brakes
Hey Everyone,
Well my plans to create a 2010 STi Legacy have been put on hold for the time being so I am putting my great setup up for sale. These have less than 15k miles on them and are in excellent condition.
These will include all four calipers, rotors, pads and lines.
The calipers are a direct bolt-on for the 2008+ WRX, 2009+ Forester and 2010+ Legacy GT, you would just need to have the rotors re-drilled to a 5x100 bolt pattern or swap to STi hubs(which would require changing wheels as well).
$2,000 shipped I will NOT part these out unless there are simultaneous buyers of the front and rear setups.
Any questions feel free to ask.
Thanks!
Ben
Last edited by PHATsuby; 03-14-2011 at 11:19 AM. Reason: added info about not parting out
PHATsuby is online now   Reply With Quote
Old 03-13-2011, 10:05 PM   #2
09duffman89
Member Sales Rating: (5)
Member#: 211495
willing to seperate rears from fronts?
09duffman89 is offline   Reply With Quote
Old 03-13-2011, 10:15 PM   #3
Zulu-
Member Sales Rating: (6)
Member#: 232213
^^ what this guy said. Even just sell rear calipers.
Zulu- is offline   Reply With Quote
Old 03-13-2011, 11:01 PM   #4
PHATsuby
Member#: 13617
2001 Legacy GT back
Well I'd like to sell them together so I guess if one of you wants the fronts and the other wants rears and we can work out a price then I would consider doing it.
The last thing I want to do though is be stuck with the just the fronts or just the rears because then I can't even use them if I wanted haha.
Ben
Old 03-14-2011, 10:22 AM   #5
charlesdixon
Member Sales Rating: (11)
Member#: 161345
2005 AW STi
Stage Poo
willing to sell me the rotors?
charlesdixon is offline   Reply With Quote
Old 03-14-2011, 11:18 AM   #6
PHATsuby
Member#: 13617
2001 Legacy GT back
Did you happen to read my post above yours? I am not going to part these out unless there are buyers of the fronts and rears at the same time.
Thanks
Ben
Old 03-15-2011, 06:59 AM   #7
darkrexy
Member#: 226972
if charlesdixon wants the rotors
i would be interested in the calipers
how much for just the calipers
darkrexy is offline   Reply With Quote
Old 03-18-2011, 01:13 AM   #8
lillie18soriano
Member Sales Rating: (1)
Member#: 264494
how much for front calipers??
lillie18soriano is offline   Reply With Quote
Old 03-20-2011, 09:59 AM   #9
1970gopher
Member#: 189851
2011 wrx sedan
wrb
Has any of this been sold yet?
1970gopher is offline   Reply With Quote
Old 03-20-2011, 10:24 AM   #10
PHATsuby
Member#: 13617
2001 Legacy GT back
Nope not yet.
Ben
Old 03-20-2011, 10:28 AM   #11
Rat^3
Member#: 210856
12 WRX
Sick price, if I needed calipers I would be all over this
Rat^3 is offline   Reply With Quote
Old 03-22-2011, 10:58 AM   #12
Quik265
Member Sales Rating: (3)
Member#: 189662
2012 S4
Monsoon
your saying the rear calipers are direct bolt on for 09 WRX if i pick up an 04 sti rotor thats 5x100? no extra mods to make the rears work?
Quik265 is offline   Reply With Quote
Old 03-22-2011, 12:18 PM   #13
PHATsuby
Member#: 13617
2001 Legacy GT back
Yes the calipers are direct bolt on. You would need to use the 09 STi rear rotors and drill them for 5x100. They have different backspacing than the 04-07. At least this is the case on the STi and the 2010 legacy GT, I assume since your rear suspension is the same it would also be the case unless your parking brake setup is different.
Ben
Old 03-22-2011, 05:54 PM   #14
1970gopher
Member#: 189851
2011 wrx sedan
wrb
Ben
There is also a lip on the inside of the rotor that has to be machined off. Plus drilled for 5x100 then it's good to go. the parking brake is the same.
Old 03-22-2011, 06:00 PM   #15
PHATsuby
Member#: 13617
2001 Legacy GT back
Is this specific to the wrx do you know? what does the lip interfere with on the wrx?
Thanks for the info.
Ben
Old 03-23-2011, 05:26 PM   #16
1970gopher
Member#: 189851
2011 wrx sedan
wrb
Ben
Yes on the rear brake rotor there is a lip that has to be machined off to fit on the wrx not sure about the other models. It interfers with the spacing if not removed. With the lip still in place it will not seat against the hub correctly.
Old 03-25-2011, 10:44 AM   #17
Quik265
Member#: 189662
2012 S4
Monsoon
Would i be able to use 04 sti replacement rotors, something slotted etc. rather than use 09 sti rotors and have to drill them? the lip has to be machined off either way i'm assuming, no getting around that but the rotor shoudnt have to be an 09sti right?
Old 03-25-2011, 11:32 AM   #18
PHATsuby
Member#: 13617
2001 Legacy GT back
You would be able to use 04 sti fronts. As for the rears I am less confident in an answer because the lip machining was news to me. My understanding is the 08+ has a wider parking brake band so the spacing is diff as a result.
I'd like to see this lip that needs machining. Maybe someone else will have more info.
Ben
Old 03-25-2011, 06:54 PM   #19
1970gopher
Member#: 189851
2011 wrx sedan
wrb
Here is a link that explains the rear Brembo issue.
http://www.3gwrx.com/forum/index.php/topic,6568.0.html
Old 03-26-2011, 04:36 PM   #20
1970gopher
Member#: 189851
2011 wrx sedan
wrb
I may have overlooked and misread some info. After rereading some of the stuff other than the rear dust shield it should bolt directly on.
Old 03-31-2011, 11:32 PM   #21
GrindingGears
Member Sales Rating: (4)
Member#: 196637
Hey Everyone,
Thanks!
Ben
Payment sent.
GrindingGears is offline   Reply With Quote
Old 03-31-2011, 11:51 PM   #22
PHATsuby
Member#: 13617
2001 Legacy GT back
Originally Posted by GrindingGears View Post
Payment sent.
Sold!
Ben
The STi Brembo Brake FAQ - including "will STi Brembos fit on [x]?" Butt Dyno Brakes, Steering & Suspension 93 05-10-2016 09:22 AM
2008-2009 STi Brembo pads in 2004-2007 STi calipers relliMmoT Brakes, Steering & Suspension 2 11-17-2009 08:30 PM
WTB: STi Brembo Brakes & Stock WRX Brakes willfong Private 'Wanted' Classifieds 0 07-28-2005 10:37 PM
Brembo and STi/Brembo brakes and rim info Imprezer Brakes, Steering & Suspension 13 03-20-2003 07:14 PM
