Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 01-04-2012, 02:56 PM   #576
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
its really next level sheet dog. congrats on your progress and looks like great times with kenny!!! more pics!!
really looking forward to seeing it in person. hopefully next to mine.
maxpowr is offline   Reply With Quote
Old 01-04-2012, 04:00 PM   #577
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
We're going to get the sheets for the flat bottom, wing, canards and trunk bottom right now. Should get all that done today.
Old 01-04-2012, 04:38 PM   #578
Exec809657
Member#: 59050
kbiz 30r E85 STI
Phatbotti tuned
Originally Posted by maxpowr View Post
gonna run a 10mm oil pump this time.
I thought an 11 was slightly small for a big build, but researching a little before I picked that, I havent even heard of people having problems with the 12, why a 10? What problems have you had?
Exec809657 is offline   Reply With Quote
Old 01-04-2012, 07:46 PM   #579
Phatron
Member#: 36033
CEO PhatBottiTuning
Old 01-04-2012, 09:40 PM   #580
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
why do people think that a 600whp car needs more oil volume per RPM than a 400whp car?
Maintaining pressure should be your only concern. Driving more volume (resulting in pressure and bypassing) only robs you of power...as well as heating up the oil and aerating it, right back into your pan
Old 01-05-2012, 01:07 AM   #581
PhatBotti Tuning TKR
Member#: 239659
STI Mikey & Phatron
Tuning Da Subies
Ok, enough thread!! Everything is baller outrageous, but when are we hopping in and going 9's?!?!?
LOL,
Nice progress Ronald!!
-Mikey
PhatBotti Tuning TKR is offline   Reply With Quote
Old 01-05-2012, 03:31 PM   #582
Exec809657
Member#: 59050
kbiz 30r E85 STI
Phatbotti tuned
the 08+ sti comes oem with an 11mm oil pump, he mentioned he was going with a 10 for his built (non stock) set-up. I was just curious why as it sounded like he might have had a problem with the previous setup
I've heard from several that the 12mm isn't nessacary and the reason why I didnt go with one, so a 600whp set-up doesn't need anymore oil pump then a 220-230whp car came with tho? thats something I don't fully get, but then again I don't build motors & am still learning with all this, so your advice is appriciated
Old 01-05-2012, 03:43 PM   #583
Exec809657
Member#: 59050
kbiz 30r E85 STI
Phatbotti tuned
Old 01-05-2012, 11:23 PM   #584
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
sorry for the thread jack ron...looks really fun over there.
exec...i have a build thread. i attribute blown rod bearing to excessive oil pressure, based on how the bearings were damaged.
10mm non avcs, 11mm single avcs, 12mm dual avcs? i will be closely monitoring oil pressure this time. homemade has been warning me about the 12mm bypass problem for some time...
Old 01-06-2012, 09:36 AM   #585
Homemade WRX
Member#: 33782
96 bastard child
The 08 STi also came with dual AVCS...
from the factory, 10mm is turbo and turbo single avcs, 11mm is turbo w/dual avcs, while the ONLY 12mm setup was dual avcs and TWIN turbo. <--the Legacy B4 was also a low RPM engine (redline was 7k IIRC). So high speed (8k+) pump efficiency was far from the design table.
now what is needed for your build is up to the build itself and how loose your tolerances and how much oil the turbo requires. Also to be noted is for extreme cases of a monster tq auto-x build, a larger pump can be benificial in that it can created pressure earlier, so when you're making 400+ lb-ft at 4k, you have a strong oil wedge.
the years of Subaru 'engine builders' who really don't know wtf they're doing and spouting misinformation has caused some issues and numerous engine failures (see my plagued pm box of questions) but it does seem like many more people are taking on their own builds and using their own insight and research
Old 01-06-2012, 01:18 PM   #586
Phatron
Member#: 36033
CEO PhatBottiTuning
Old 01-06-2012, 11:14 PM   #587
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Looks tighter.
Old 01-08-2012, 04:02 PM   #588
Phatron
Member#: 36033
CEO PhatBottiTuning
Old 01-08-2012, 06:33 PM   #589
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
wow that thing is going to be sick
Old 01-09-2012, 01:32 AM   #590
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
looks really good. i'd have trouple sleeping.
Old 01-09-2012, 02:26 AM   #591
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
Ron, what are you expecting to run with this build? 600hp? 10 seconds? what's the magic number?
punchjamesarnol is offline   Reply With Quote
Old 01-09-2012, 02:48 AM   #592
Phatron
Member#: 36033
CEO PhatBottiTuning
my loose limits are 30psi and 7500-7800 rpm with the gtx3582....so whatever that gets me....
for 2500 lb weight people have been predicting 9.2-9.5
but i'll be happy with anything under 10.5 during the first 2-3 track days.
we're probably gonna run it on the street tires at first just to get it dialed in and see some traps so 9's most likely wont happen on those tires
Old 01-09-2012, 07:36 AM   #593
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
your gonna crap your pants RON.
Old 01-09-2012, 10:48 PM   #594
spdracerut
Member#: 269226
Figure on around 700whp. I'd say definitely a 9 second car, but I'm thinking more around 9.7.
spdracerut is offline   Reply With Quote
Old 01-09-2012, 11:05 PM   #595
Phatron
Member#: 36033
CEO PhatBottiTuning
700whp is way too high. The turbo is only a 720chp turbo. Maybe 700 on a dj or dynapack....but on the road dyno I'm expecting ~550whp
Old 01-09-2012, 11:18 PM   #596
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Considering he has larger cams than me, but a slightly smaller turbo, it should make very similar power to my car. Weighing in at close to 1000 pounds less than my car with much better gearing PPG's, this car should go very low into the 9's with no problem and into the 8's with me in the cockpit
Crystal_Imprezav is offline   Reply With Quote
Old 01-10-2012, 01:27 AM   #597
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
its gwon b like dat?
Old 01-10-2012, 04:52 AM   #598
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Ron,
Check this out:
http://forums.nasioc.com/forums/show....php?t=2294126
Its pretty much your build in a new body. This is a true 600+ combo. 580 on this dyno made 711 on a dynojet. I tuned a vf car here and made 258.. lol.
Expect big tings!!
STi Mikey is offline   Reply With Quote
Old 01-10-2012, 12:14 PM   #599
juanmedina
Member#: 133146
Originally Posted by STi Mikey View Post
Ron,
Check this out:
Expect big tings!!
^ sick car, but he is running 34psi and his engine is sleeved
when do you think you will be finish Ron?
Old 01-10-2012, 12:30 PM   #600
Phatron
Member#: 36033
CEO PhatBottiTuning
I'd like to be done in 2 months....but in reality it will probably be another year. I only get to work on it 4-6 days a month.
Still to be done
- finish cage
- front diffuser
- rear diffuser
- rear wing
- rear canards
- parachute mounts
- fuel lines
- brake lines
- brakes
- EM & wiring
- fiberglass front end
- trunk/cockpit divider
- sand blast whole car
- remove sound deadening from underbody and wheel wells
- aluminum driveshaft
- window mounts
- repair ppg's
- shave door handles (maybe)
- install trans, motor, driveshaft
COBB Tuning Surgeline: 2004 WRX Wagon 2.5L GT35R E85 Employee Car Build Cobb Tuning Proven Power Bragging 34 11-30-2011 06:04 AM
FS/FT : IL: 2002 WRX Wagon 2.5L hybrid/4EAT smeagol Private Vehicle 'For Sale' Classifieds 4 07-30-2010 05:28 PM
FS/FT : 2002 WRX Wagon 2.5L hybrid/4EAT smeagol MWSOC Private Classifieds 0 07-04-2010 11:15 PM
2002 WRX FXT 2.5L, 18G, boost/rev issues 2000wrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 05-13-2010 06:36 PM
2002 WRX wagon 2.5L hybrid w/ Blouch 2.5R turbo triguy Proven Power Bragging 12 10-18-2008 03:09 PM
