Welcome to the North American Subaru Impreza Owners Club Sunday January 25, 2015
Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 01-30-2012, 12:38 PM   #676
2gnt2wrx
Member#: 123625
2002 wrx
2015 wrx gbp
Originally Posted by punchjamesarnol View Post
When I keep rpms less than 3K and shift easy, I see 200-220 mile a tank no problem, its just when I go over 3K with my ev14 1200cc's my milage starts to hurt. I've learned to be a very disciplined driver... Just playing! but I can get anywhere from 100 miles to 200 with a tank of e85. Ron, what the werd? Hows the build? Waiting for more pics...
I had the same injectors on my sti and was seeing about the same mileage on E-85.
2gnt2wrx is offline   Reply With Quote
Old 01-30-2012, 08:45 PM   #677
Exec809657
Member#: 59050
kbiz 30r E85 STI
Phatbotti tuned
I have dw1100's & only see maybe 170 tops, thats normal non boost driving, maybe 140 or something with a little fun here or there e85
but, I had a bunch of other probs with the last motor maybe it had something to do with parts not working good together or something, even at almost 100 miles less per tank, I dont regret e85 & recommend anyone choose it over 91/ 93 pump
I removed my aquamist to run it, less things to fail now
Exec809657 is offline   Reply With Quote
Old 01-31-2012, 05:55 PM   #678
Exec809657
Member#: 59050
kbiz 30r E85 STI
Phatbotti tuned
Originally Posted by Phatron View Post
(although I havent talked to Kenny yet) i signed him up to fabricate a top feed conversion kit. Instead of dealing with crappy sidefeed injectors I'm trying to get five-0 to discontinue 1000cc+ sidefeeds and instead getting a cheap top feed conversion kit together.
You guys have known me and know I don't push products on people that don't work, so these kits are going to fit, install easy, work as advertised and be cheap. Jeff already suggested different connectors and o-rings for the 2200 injectors and five-0 shipped out different o-rings and connectors the next day. They are totally on board with delivering the best product possible and they've been a pleasure to work with so far.
It's in the making, stay tuned , I can't wait for some bigger injectors myself, I just never wanted to swap my deleted sidefeed tgv's, this is going to be nice for alot of people.
Old 01-31-2012, 06:01 PM   #679
tbledsoe11
Member#: 240565
2002 WRX-E85-VF39
8.39@88.2
I can get around 300 on e85 on a tank doing highway 60mph...but thats not fun lol...I average about 220 on and off hard daily. 850cc injectors/2.0L
tbledsoe11 is offline   Reply With Quote
Old 03-20-2012, 06:23 PM   #680
jimountain
Member#: 207619
Default hello from iowa
Just checking in on your progress, looked like some pictures of "Lana"- way back in the beginning. Can't wait to see this run. Cheers again,
Jim
jimountain is offline   Reply With Quote
Old 06-05-2012, 04:47 PM   #681
wgr73
Member#: 232458
2008 STi (OBP)
CAMTuning ftw
We need updates!
wgr73 is offline   Reply With Quote
Old 06-05-2012, 08:47 PM   #682
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
the motor is in my STi being broken in with the GTX35 right now on Cobb Speed Density
Not much other than that. Kenny was busy moving and builiding. Ive been busy trying to fix up my house to rent or sell. Got the tile done. Diagonal offset brick pattern....looks pretty good.
Old 06-05-2012, 08:53 PM   #683
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
Nice setup! It's gonna be a monster... both setups are monstrous! LOL
punchjamesarnol is offline   Reply With Quote
Old 06-05-2012, 09:19 PM   #684
jockeygolfs
Member#: 260868
2011 STI
Sticking with TMIC?
jockeygolfs is offline   Reply With Quote
Old 06-05-2012, 09:27 PM   #685
Phatron
Member#: 36033
CEO PhatBottiTuning
on my DD yes. on the drag car, no.
Old 06-05-2012, 10:29 PM   #686
jockeygolfs
Member#: 260868
2011 STI
You have to much going on to keep track. So your new built motor is in you DD for break in?? Then swap it into the drag car?
Old 06-05-2012, 10:36 PM   #687
Phatron
Member#: 36033
CEO PhatBottiTuning
That's the loose plan. I might just put rings in the sleeved motor I just pulled out and put that in the drag car.
Old 06-06-2012, 03:25 AM   #688
Lazzydog
Member#: 240287
2012 WRX
you know where i can find a creeper to get under there and do one of the 100 oil changes required for break in? lol
Lazzydog is offline   Reply With Quote
Old 06-08-2012, 09:51 AM   #689
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
How you like SD Ron? Any gains on power vs MAF? Post some Airboys or VDs when you have some time
Old 06-08-2012, 09:57 AM   #690
Phatron
Member#: 36033
CEO PhatBottiTuning
No power gains. Fueling is fueling.
And I'm out of injector at 24psi so no graphs until I get some topfeeds in.
Old 06-08-2012, 10:54 AM   #691
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Are you still running the stock like restrictive intake?
Old 06-08-2012, 12:50 PM   #692
juanmedina
Member#: 133146
07 FPgreen 7.37@95
Removing the MAF sensor from the intake path?
Old 06-08-2012, 03:10 PM   #693
Phatron
Member#: 36033
CEO PhatBottiTuning
Mines not removed
Old 06-08-2012, 03:47 PM   #694
juanmedina
Member#: 133146
07 FPgreen 7.37@95
Mines not removed
Why?
Old 06-08-2012, 03:51 PM   #695
Phatron
Member#: 36033
CEO PhatBottiTuning
cause i didnt plan to run sd....i didnt set the car up with it in mind.
Old 06-08-2012, 03:51 PM   #696
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Mines not removed
Put a 4 inch diameter filter directly on the turbo inlet and report back then. I wouldn't expect you to gain much otherwise.
Old 06-08-2012, 04:06 PM   #697
Phatron
Member#: 36033
CEO PhatBottiTuning
if i keep this setup in my DD, im not going to push it enough to tell a difference anyway. and if it goes into the drag car its going to be a different setup....fmic...maybe front mount turbo.....
Old 06-13-2012, 02:03 AM   #698
Phatron
Member#: 36033
CEO PhatBottiTuning
got another goodie on teh way.....any guesses?
Old 06-13-2012, 02:10 AM   #699
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
Lemme guess. Top feeds?
Old 06-13-2012, 02:13 AM   #700
Phatron
Member#: 36033
CEO PhatBottiTuning
already have those, just gotta install em. its long...and lightweight
COBB Tuning Surgeline: 2004 WRX Wagon 2.5L GT35R E85 Employee Car Build Cobb Tuning Proven Power Bragging 34 11-30-2011 07:04 AM
FS/FT : IL: 2002 WRX Wagon 2.5L hybrid/4EAT smeagol Private Vehicle 'For Sale' Classifieds 4 07-30-2010 06:28 PM
FS/FT : 2002 WRX Wagon 2.5L hybrid/4EAT smeagol MWSOC Private Classifieds 0 07-05-2010 12:15 AM
2002 WRX FXT 2.5L, 18G, boost/rev issues 2000wrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 05-13-2010 07:36 PM
2002 WRX wagon 2.5L hybrid w/ Blouch 2.5R turbo triguy Proven Power Bragging 12 10-18-2008 04:09 PM
