Old 07-15-2002, 08:01 PM   #1
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
Question Split Second VC2 or proECM?
Well, fella, I'm at a quandry. Tying to keep the cost down on my turbo kit, but I want it to be safe for the engine. So looks like I'll need a J&S Safegaurd. But I'm thinking about not getting theproECM, and just getting a Split Second VC2 voltage clamp. Now, my question is, will the proECM make enough difference to a turbo'd 2.5RS to justify the price difference between it and just a voltage clamp?
HondaH8er is offline   Reply With Quote
Old 07-15-2002, 11:01 PM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
personally, I'd go with the SS VC
kastle is offline   Reply With Quote
Old 07-15-2002, 11:35 PM   #3
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
That's the way I was leaning, and considering how much you know about the subject, That pretty much makes my mind up. Unless someone has a good arguement as to why the proECM would be a better choice for my application.
Old 07-15-2002, 11:36 PM   #4
STiTuner
Member#: 5778
09 135i
Jet Black
Why not just do the zener diode trick and save yoru self 40 bucks.
I'm sure you can rig one up yourself its not that hard.
Brad
STiTuner is offline   Reply With Quote
Old 07-16-2002, 01:51 AM   #5
akcel
Member#: 10268
gc8 I ride ride 24s
with the top down low.
whats the diff between vc1 and vc2? is the vc2 adjustable?
akcel is offline   Reply With Quote
Old 07-16-2002, 11:53 AM   #6
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
Yeah, the VC2 is adjustable from 0-5V max output. That's the main reason I'm looking at one of them over a zener diode.
Old 07-17-2002, 01:40 AM   #7
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
I have a 99RS, so I don't use the voltage clamp on my proecm. However, I can say that the chip made a big difference in the car before it was turbo. I can only assume it is still adding that power now, in addition to the turbo. The proecm is a great product and I'd recommend it to anyone.
Drac9 is offline   Reply With Quote
Old 07-17-2002, 01:43 AM   #8
Andrew
Member#: 1170
2005 STi
i will be selling my split second programmable map soon.
Andrew is offline   Reply With Quote
Old 07-17-2002, 01:49 AM   #9
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
Will the chip even do anything when under boost? Scince the stock ECU goes into closed loop?
LVSUBARU is offline   Reply With Quote
Old 07-18-2002, 11:25 AM   #10
proecm
Member#: 12081
People with aftermarket turbo kits and the powerchip is very happy with the added low end and throttle response.
When is comes to the voltage clamp issue. There is a BIG difference between a zener diode and a correctly designed voltage clamp. A zener diode will always put a load on the sensor. This load will change the caracteristics of the sensor output. With other words if you are using a zener diode you are not only clamping the maximum voltage but you have loaded the sensor to give a smaller (not linearly) output all the way. The stock computer will use the sensor value from the map, which now is less than normal and consequently lean the car out. The ECU will learn around this after a while but the way I see it is that the zener diode fix is noting else than a hack, that will not produce the optimal result. If you have spent several thousands $ on a turbo kit, $40 extra (if that's what it is) to make it right is easily worth it.
/David
proecm is offline   Reply With Quote
Old 07-19-2002, 09:40 PM   #11
adamsrs
Member#: 3768
Can someone please link me to where i can get the VC2 and how much it is, and how hard it is to install, thanks!
adamsrs
adamsrs is offline   Reply With Quote
Old 07-20-2002, 07:49 PM   #12
traskw
Member#: 9604
2005 LGT '94SS MR2
AtlanticBlue, Red, Silver
The current version of the J&S comes with the voltage clamp.
traskw is offline   Reply With Quote
Old 07-21-2002, 02:55 AM   #13
adamsrs
Member#: 3768
WHERE CAN I GET A SSVC2?
adamsrs
Old 07-21-2002, 03:21 AM   #14
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
didn't i see split second stuff at spomotorsports once?
ImprezaRS dot com is offline   Reply With Quote
Old 07-21-2002, 03:31 AM   #15
Andrew
Member#: 1170
2005 STi
adamsrs
um...try calling Split Second...
Old 07-21-2002, 03:33 AM   #16
Ethan
Member#: 246
yea they still have two of their things but not this thing
Ethan is offline   Reply With Quote
Old 07-21-2002, 11:51 AM   #17
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
I looked on the Split Second website, and din't see it there, but I found mine on eBay, got a pretty good price on it One more part for my eBat turbo kit (turbo, IC, and VC2 so far, probably at least the BOV, too)
Old 07-21-2002, 02:08 PM   #18
Andrew
Member#: 1170
2005 STi
if you dont see it on the site, call them.
Old 07-21-2002, 03:17 PM   #19
akcel
Member#: 10268
gc8 I ride ride 24s
grrrrrr i was bidding on that and then had to leave...theif! haha
Old 07-21-2002, 04:02 PM   #20
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Split Second Voltage Clamp --> http://www.splitsec.com/products/vc1/vc1ds.htm
Old 07-21-2002, 07:30 PM   #21
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
Was that really you? Are you sandiegobidder? This auction ended Jul-16-02 20:55:16 PDT . If so, sorry, but I had to do what I had to do, and I had to counter your high bid with 4 seconds left to snag it.
Old 07-21-2002, 07:32 PM   #22
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
That's the VC1, though, not the VC2. The VC2 is adjustable, the VC1 is fixed.
Old 07-21-2002, 08:40 PM   #23
Andrew
Member#: 1170
2005 STi
if anyone is interested in a programmable map, please shoot me a PM. it will hopefully be for sale soon.
Old 07-22-2002, 12:33 AM   #24
akcel
Member#: 10268
gc8 I ride ride 24s
hah its ok...this girl was bugging me to watch a movie..if i was home you wouldnt have won! ... :P
Old 07-22-2002, 09:21 AM   #25
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
The VC1 = the VC2, you just have to call and ask for the adjustability to be put in (it's like $10 or something for them to solder in the potentiometer). They're exactly the same unit, otherwise.
emanage or split second? MeshmeZ Engine Management & Tuning 5 03-04-2005 04:05 PM
Wiring In A Split Second! spgavin Normally Aspirated Powertrain 1 06-20-2001 07:45 PM
WTB Split Second Timing Controler SubaFastR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-29-2001 07:53 AM
Local Sale: Split Second Boost Guage Revision Mid West Subaru Owners Club Forum -- MWSOC 3 02-20-2001 02:06 PM
Apex S-AFC or Split Second ARM/ARC-1 Kyle Paton Technical Forum Archive 5 08-18-2000 10:58 AM
