South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 04-27-2015, 09:40 PM   #1
shemoves
Member#: 80663
2005 STi
Default Cost: Rebuild vs Installation of new short block
What is the cost difference on just the labor portions of a short-block rebuild (assume all new internals, hone, and balance) vs. installation of a new short-block?
shemoves is offline   Reply With Quote
Old 04-28-2015, 01:57 AM   #2
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
New shortblock isn't much more costwise. On top of that OEM assembly process typically yields a significantly better product. Unless you want stronger internals (and even then can be botched) I'd go OEM every single time.
Old 04-28-2015, 12:46 PM   #3
Infantry209
Member#: 266895
2014 Thrustmaster TX
Fanatec CSPv2, gated 7spd
Should be the same labor wise. Most shops charge you to pull the motor and to install the motor. Then the build is a separate price altogether.
Infantry209 is offline   Reply With Quote
Old 04-28-2015, 10:20 PM   #4
shemoves
Member#: 80663
2005 STi
Got it. What is the typical labor charge on the rebuild portion?
Old 04-29-2015, 06:50 PM   #5
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Edit: BASIC Rebuild should be $600-1500 depending on many factors.
Labor for install on the motor has to happen regardless of new or rebuild.
Shouldn't you be concerned with new shortblock price vs rebuild price only?
Old 04-30-2015, 12:07 AM   #6
shemoves
Member#: 80663
2005 STi
Yes. That is what I am asking. I will most likely do a pre-built block, unless there is significant savings having my current one rebuilt.
Old 04-30-2015, 12:18 AM   #7
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
If you're staying at or near oem power output there really is no better than oem build quality. I don't care how much you save its not worth it in the end. I'll step off my soapbox.
Don't get some local shop to build it just cause they can save you a couple hundred. The bottom end is and should be expensive when done properly and one of the most important pieces of the puzzle.
It would suck to get a cheap job and have it go in a matter of months. Which happens often it seems.
Old 04-30-2015, 11:54 PM   #8
shemoves
Member#: 80663
2005 STi
I would either do a Rallispec Street Pro (http://rallispec.com/eng_sbl_rssb25p.html) or basically replicate it. It's the closest I have found thus far to "exactly what I am looking for." End goal would probably be in the 350ish whp range (depending on what the stock axles/diffs can handle).
Old 05-30-2015, 09:36 PM   #9
shemoves
Member#: 80663
2005 STi
Are there any good local shops that allow customer supplied parts?
