Old 03-17-2011, 08:41 AM   #1
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
Default Shockwave-Generating Wave Discs Could Replace Internal Combustion Engines
Michigan researchers have built a prototype of a new auto motor that does away with pistons, crankshafts and valves, replacing the old internal combustion engine with a disc-shaped shock wave generator. It could slash the weight of hybrid cars and reduce auto emissions by 90 percent.
The generator is about the size of a saucepot, and would replace the 1,000-pound power train in most cars — no transmission, cooling system, emissions regulation or fluids needed. Norbert Müller and colleagues at Michigan State University showed off the new motor prototype at a meeting with the Department of Energy’s Advanced Research Projects Agency.
It consists of a rotor carved with wave-like channels. Fuel and air enter through central inlets, and the rotor spins to block their exit through a separate outlet. The sudden build-up of pressure generates a shock wave, compressing the mixture. Then it’s ignited, and as the rotor keeps spinning, the outlet opens again to let the hot gases escape. New Scientist explains in further detail.
The novel generator would use about 60 percent of fuel for propulsion, according to MSU. This is a dramatic improvement over typical car engines, which use only 15 percent of fuel for forward movement. The system could also make cars 20 percent lighter, improving fuel economy even more.
MSU received a $2.5 million ARPA-E grant to develop the technology. Müller said he hopes to have an even larger 25-kilowatt prototype by the end of this year.
[Next Big Future]
need5
Old 03-17-2011, 09:36 AM   #2
samagon
Member#: 26859
of TXIC
I also like (oYo)!!!!
this probably has less torque than a rotary. would be interesting to see what the plan is, use this to generate electricity, and then use electric motors to power the wheels?
Old 03-17-2011, 09:50 AM   #3
SCRAPPYDO
Member#: 873
2014 GLK/allroad
Datsun 71 240Z & 68 2000
Riiiiight. I will believe it when I see it. This reeks of one of those engines works on a CFD model. Let me see it in real life and I may believe it. If it is too good to be true, then it probably is.
SCRAPPYDO is online now   Reply With Quote
Old 03-17-2011, 09:58 AM   #4
Hites
Member#: 138997
0000 Nothing
Sounds like a rotary gimmick, and 1,000lbs? LMAO!
Hites is offline   Reply With Quote
Old 03-17-2011, 11:48 AM   #5
HipToBeSquare
Member#: 119958
1992 SVX LS-L
His next invention on the market will be nuclear-fusion powered impulse drive.
His anti-matter warp core is still in prototyping.
HipToBeSquare is offline   Reply With Quote
Old 03-17-2011, 12:03 PM   #6
Yotsuya
Member#: 935
Jack Soo Fan Club
Just from the article it doesn't look like something that would be direct drive, but a decent power source for an electric car needing additional range.
Yotsuya is offline   Reply With Quote
Old 03-17-2011, 12:30 PM   #7
Obsessive
Member#: 77302
damn well better
bail me out of this ****
Isn't this almost like the concept of antilag on a turbo, except that the cold side wheel is removed and replaced with a torque shaft and used to power a gearbox/generator?
Obsessive is offline   Reply With Quote
Old 03-17-2011, 12:54 PM   #8
Mechie3
Member#: 120152
Read teh article. It's for an electric generator.
Mechie3 is offline   Reply With Quote
Don’t Rule out the Internal Combustion Engine AVANTI R5 Non-Subaru News & Rumors 13 06-11-2010 11:40 PM
How many internal combustion engines do you own? ANZAC_1915 Off-Topic 60 09-28-2009 04:58 PM
New BMW internal combustion engine cleans air AVANTI R5 Non-Subaru News & Rumors 19 04-17-2008 09:46 AM
the thermodynamics of internal combustion engines Guerilla_Gorilla General Community 51 08-13-2007 07:55 PM
New internal combustion engine! Anyone seen this? RacerinLSL Off-Topic 11 01-11-2006 04:37 PM
