Vancouver Impreza Club
Go Back   NASIOC > NASIOC Chapters > Vancouver Impreza Club Forum -- VIC > VIC Vendor Classifieds
Closed Thread
Old 03-17-2011, 01:13 PM   #1
dalesalignment&brake
Vendor Sales Rating: (47)
Member#: 173316
'13 BRZ
Default Racecomp Engineering coilspring and swaybar sales!!!!
We just received a shipment of springs from RCE and I have no room for them, so all models of RCE springs are on sale.
We have Yellows, Regular Guy for GR('08+STI) and GD('02-07 Impreza, WRX and STI) and Wagon('02-07) springs in stock.('02-03 GD require '04+rear tophats)
$329set
Racecomp Engineering GR('08+STI) Yellows
RaceComp’s classic “Yellow” high performance lowering spring is now available for the GR chassis Impreza STI! Following the release of our popular "Regular Guy" springs, RaceComp has produced a more aggressive lowering spring for the 08+ STI. These new springs lower the car approximately 15mm and include new replacement bumpstops to maintain as much travel as possible on the lowering sensitive GR Impreza chassis. Spring rates are an aggressive 330 lbs/in front and 335 lbs/in rear. With a stance to match the performance, these springs utilize the knowledge RaceComp has gained from years of GR chassis set-up experience to maximize handling, retain ride comfort, and improve the look of your Impreza. Racecomp Engineering’s goal was to help cure the crippling understeer that adds to lap times at the track and autocross course. Studying the design of the new GR suspension, a more aggressive performance spring has been produced that retains available bump travel, matches the OEM dampers, and works in conjunction with the new rear motion ratio. The result is a car that handles extremely well from corner entry to corner exit.
Racecomp Engineering GD('02+WRX/STI) Regular Guy springs
The RCE “Regular Guy” Black springs are intended for both the daily driven street driver as well as the autocross and track day weekend warrior. Using similar spring rates as the extremely popular and successful RCE Yellow Springs, but having a much more subtle/mild drop in comparison, these are perfect for STi owners not looking for a ride height much lower then stock, and yet are still looking for increased spring rates. Although, these springs may have a subtle look, you will still be outpacing just about everything on the track and auto-x course. When installing these springs, some addtional NVH may be experienced do to increased spring rate.
RCE Yellow GD chassis
The highly anticipated Super Sport Street/Track Springs, an OEM replacement spring for 2004-2007 Subaru WRX STi from Racecomp Engineering. Designed for use with standard STi inverted struts or Ohlins Fixed Perch Replacement Struts, these springs are intended for both the daily driven street driver as well as the autocross and track day weekend warrior. Finally, after years of being the authority on Subaru suspension options for everyone from the daily driver to the professional racer, Racecomp Engineering can now provide their own solution to owners looking for the ultimate OEM replacement spring for their Subaru Impreza WRX STi. Using the very popular JDM STi springs that we brought to the U.S. market in mid 2003 as the benchmark, Racecomp focused on improving on track and autocross performance, while maintaining acceptable ride quality. Extensive research, design, and testing was performed to develop a completely new spring unlike anything currently available. With springs rates increased approximately 25% stiffer then the popular JDM Pink Springs, the springs are perfect for those with wider tires worried about rubbing, as well those looking for a little more rear spring rate to promote a more neutral handling characteristic. Much care was taken not to exceed the limits of the stock struts. The mildly progressive design and spring rates properly matched with the dampers ensure that ride quality is not diminished over stock. The car is lowered 20mm in the rear and 23mm in the front for an even look.
Wagon springs
Finally, an option exists for Subaru WRX Wagon owners with upgraded struts! Rather then having to choose between spring rates that are too soft, like most wagon specific springs, and a saggy rear end, like most sedan specific springs, Racecomp Engineering is proud to announce an OEM replacement spring for the Subaru WRX Wagon. Designed for use with standard STi inverted struts, Koni Inserts, Tokico D-Spec struts or Ohlins Fixed Perch Replacement struts, these springs are intended for both the daily driven street driver as well as the autocross and track day weekend warrior. Using similar spring rates as the extremely popular and successful RCE Yellow Springs, but having a wagon specific ride height, these are perfect for wagon owners not looking to compromise either ride height or spring rates.
Designed with direct feedback from wagon owners, these are THE solution for Impreza owners looking to prove what a properly set-up wagon with upgraded struts can really do!
add a set of Koni Yellows('04-07 fitment)
$700 set- in stock
RCE GD STI swaybars-$399set
These we're $449set not long ago...
Here are the specs:
Racecomp Engineering 04-07 STI swaybars
We didn't try to reinvent the wheel here, just provide another option for GD STi owners looking for a swaybar set that will work well with stock springs, lowering springs, or coilovers. The settings for the front bar are 25.5 and 28.5mm, rears are adjustable from 25.5, 27.0 and 28.5mm. So you could run these and not have to go to a bar that is actually 27mm thick.
Specifications:
25.5mm physical diameter
4142 Chrome Moly
Heat treated and cold finished.
Ends are hot forged on a 125 ton press.
Front and rear adjustable.
Washer tabs on front and rear to prevent walking
RCE GR('08+STI) swaybars-$429set
These front and rear 25mm hollow 2 position adjustable swaybars are a must have for your 2008 and later Impreza STI. Featuring carefully chosen swaybar rates and a tubular design, these swaybars weigh less than other solid bars with a similar stiffness.
Racecomp Engineering GR Sway bars for the 08+ STI. Rear bar will fit the 2008+ Impreza / Impreza WRX.
We also have:
RCE Tarmac Zero-'02-07 WRX and STI-$1850 in stock
RCE Tarmac 2 '05+STI and '08+STI-$2499 in stock
RCE CF Kool Brake Kit-$419 in stock
GTWorx camberplates
GR('08+STI, '05+ LGT)-$419pr-in stock
GD front/rear-$409pr-in stock
We also have great deals on Whiteline, DBA, Hawk and many other suspension and brake upgrades.
EMAIL me [email protected] to order.
__________________
[CENTER][CENTER][SIGPIC][/SIGPIC][/CENTER][B][I][COLOR="Red"]"We do pricing a little differently. Every price you see includes the shipping cost to our office(Surrey, BC), duties and exchange rate . This creates a built in cost savings, no hidden fees, and less hassles. The best part is we still have a price match guarantee!"[/COLOR][/I] [/B]
[COLOR=black]Service Center: 604 530 9160 [/COLOR] [COLOR=black]Email- [/COLOR]
[/CENTER]
dalesalignment&brake is offline
Old 03-23-2011, 12:22 AM   #2
mrwiggles_04
Member#: 214855
2005 WRX Wagon
WR Blue
rce yellows are my choice. Look great. Wish I had the cash
mrwiggles_04 is offline
Old 03-26-2011, 12:59 AM   #3
jason t
Member Sales Rating: (3)
Member#: 37199
Bump for great pricing
jason t is offline
Closed Thread
FS: Racecomp Engineering Springs and Camber Plates atlxkevinx Suspension/Brakes/Handling 3 09-12-2009 02:45 PM
Racecomp Engineering Suspension and Brake Parts!!! RaceComp Engineering Suspension/Brakes/Handling 35 02-12-2008 12:17 PM
