Mid Atlantic Impreza Club
Closed Thread
Old 01-25-2013, 03:07 PM   #2951
cvillesti
Member#: 286843
whos going to cars and coffee tomorrow?
cvillesti is offline
Old 01-25-2013, 03:36 PM   #2952
Boogalo
Member#: 77435
04 WRX Wagon Stg2
'94 Miata Project
workin
not that I would go anyways. so early!
Boogalo is offline
Old 01-25-2013, 03:55 PM   #2953
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
you guys are invited to meet us at RVA CnC, then we're tripping to jspec to look at their new digs and see what jdm goodies they have.
we'll leave Cars and Coffee little after 10 and
visit j-spec saturday jan 26th
10:30a.new location 8590 Sanford Dr. Richmond, VA 23228.
http://www.jspecauto.com/default.aspx
CnC:
http://www.facebook.com/groups/194801907239997
New Times: *8-10am
Boychik's Deli
4024 Cox Road, Glen Allen, Virginia 23060
mhoerath is offline
Old 01-25-2013, 06:18 PM   #2954
Mxbarry
Member#: 146837
2004 WRX STi WRB
98 Eclipse GSX
You're going with all of the salt on the roads?!?
Mxbarry is offline
Old 01-26-2013, 02:05 PM   #2955
DurtyB
Member#: 292699
2011 WRX Sedan DGM
Stg1+ SF
Coils on ...big thanks to Jeremy for the install!
DurtyB is offline
Old 01-26-2013, 06:02 PM   #2956
cvillesti
Member#: 286843
looking good.
Old 01-26-2013, 06:07 PM   #2957
Smurftastic
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
all you need now is more cowbell
Smurftastic is offline
Old 01-26-2013, 06:25 PM   #2958
DurtyB
Member#: 292699
2011 WRX Sedan DGM
Stg1+ SF
And moar low
DurtyB is offline
Old 01-26-2013, 10:47 PM   #2959
Mxbarry
Member#: 146837
2004 WRX STi WRB
98 Eclipse GSX
Looks good!
Changed my cabin air filter today. New one was $21.00 from NAPA. I can't believe how dirty and clogged the old one was!
Mxbarry is offline
Old 01-27-2013, 09:16 PM   #2960
Smurftastic
Member#: 243697
02 | BLOD Founding
Anyone want serious snow wheels/tires? Just found this locally...
http://charlottesville.craigslist.or...504019831.html
Old 01-27-2013, 09:24 PM   #2961
mrjcotten
Member#: 241953
02 hybrid/6speed
01 2.5 RS sedan
Yeah man I saw those. Do 14 steelies even fit over wrx brakes ?
mrjcotten is offline
Old 01-27-2013, 09:25 PM   #2962
DurtyB
Member#: 292699
2011 WRX Sedan DGM
Stg1+ SF
Saw those a couple days ago...he was asking $250. Looks like a beast deal now.
DurtyB is offline
Old 01-27-2013, 11:06 PM   #2963
mrjcotten
Member#: 241953
02 hybrid/6speed
01 2.5 RS sedan
Well after some quick searching I discovered that the 14 inch wheels won't even clear wrx brakes. Darn... would have bought just for the super traction novelty. Lol
Old 01-28-2013, 03:39 PM   #2964
DurtyB
Member#: 292699
2011 WRX Sedan DGM
Stg1+ SF
Looks like Ill be heading up to Mach V on Monday the 11th to get the new wheels on, roll and alignment. If anyone has the day off and wants to roll and doesnt mind leaving early (appointments at 9:30), let me know!
DurtyB is offline
Old 01-28-2013, 09:46 PM   #2965
Mxbarry
Member#: 146837
2004 WRX STi WRB
98 Eclipse GSX
I believe I saw Jeremy this evening on Pantops. Unfotunately, I didn't see him until he has gone past...then I waved.
Mxbarry is offline
Old 01-28-2013, 11:22 PM   #2966
alforester
Member#: 71670
2005 LGT
ABP
Just finished replacing my RacerX FMIC with a Process West TMIC on my LGT. Loaded the base map from Infamous and ran a couple logs. Hit 18-19 PSI (18 is the target) and everything seemed fine besides a slight high pitched whining noise coming from the passenger side near the turbo starting at about 5 psi. Sounded like a small leak. Still hit boost fine.
Cleaned up the garage, loaded up tools and parts into the car and started home. Noticed while idling at a light that the boost gauge was just reading "0", no vaccum. Tried to get into boost a bit and the car would not boost at all... no extra power, no change on the gauge. Instead of the turbo spooling noise (stock catback is on again, so I can hear the engine quite clearly) there is a deep and dull humming noise as RPMs increased. Noise comes from the passengers side near the turbo...
I'm hoping its just a vacuum line that popped off, could that be causing these issues? Any particular ones to check?
Does this sound like it could be a blown turbo? Please advise.
Jeremy I'll be in touch with you tomorrow, might try to get the car over to your this week so you can look it over if you have the time.
alforester is offline
Old 01-28-2013, 11:57 PM   #2967
alforester
Member#: 71670
2005 LGT
ABP
A little more background..when driving to my buddys garage before beginning the instal,l the CEL came on with cruise control blinking. Read the code with the AP and it was an evaporative emissions code, and in parenthesis said (loose gas cap). I checked it, it was on tight so I thought nothing of it.
After completing the install and loading the base map, I gave it a little gas to drop the rpms. RPMS dropped almost all the way to 400 and a high pitched whining noise was present on passenger side of engine bay. Sounded like a belt making noise but in retrospect it could have been coming from the turbo.
Old 01-29-2013, 08:35 AM   #2968
mrjcotten
Member#: 241953
02 hybrid/6speed
01 2.5 RS sedan
Hmmm that doesn't sound good. Even if a vacuum line came off you should still hear the turbo spooling. I had a hose come loose off of my wastegate on thanksgiving weekend (somebody forgot the ziptie on that one) and it was severely over boosting since the wastegate was never opening.I was hitting over 30 psi suddenly lol. Also if your boost gauge is reading no vacuum then it must have come disconnected. With no vacuum your engine would not idle most likely.
You should definitely go over the whole install particularly the throttle body coupler, and the boost control hoses for the wastegate, compressor outlet and boost gauge.
It doesn't sound too promising but you gotta go over the basics.
I would be glad to take a peek at it for you though. Hope its not the turbo.
Old 01-29-2013, 09:16 AM   #2969
alforester
Member#: 71670
2005 LGT
ABP
Yeah I have had a vacuum line come off before and my only symptom was a very rough idle and a weird fluttering noise. I should clarify that the boost gauge not only wouldn't read vacuum, it wouldn't read positive pressure at all either, just "0", which is very odd. I heard a dull hollow noise when accelerating and no turbo rush or increase in power.
I plan to look everything over tomorrow to the best of my ability, but I'm not great at troubleshooting these type of things. Also hoping its not the turbo..
Old 01-29-2013, 09:21 AM   #2970
derilict
Member#: 236549
2007 WRX Wagon STish
I have a set of (4) 14" 5x100 5 spoke Legacy wheels, just need to be blasted/painted. Would look nasty on the RS with some serious rubber
Yeah, I already tried to fit them on my WRX, no dice. Maybe they fit the '02-'05 brakes?
derilict is offline
Old 01-29-2013, 09:28 AM   #2971
derilict
Member#: 236549
Those do look gnarly. If anyone does pick them up, check state law..... I feel like I heard that studded tires are illegal in VA.... but who knows.
derilict is offline
Old 01-29-2013, 10:56 AM   #2972
mrjcotten
Member#: 241953
02 hybrid/6speed
01 2.5 RS sedan
They are legal between the dates stated in the Craigslist ad. I looked into it a while back. Its on the va law website.
Old 01-29-2013, 11:23 AM   #2973
mrjcotten
Member#: 241953
02 hybrid/6speed
01 2.5 RS sedan
Alex, one thing for sure, if its a bad Turbo the less you drive it the better. If the center cartridge has grenaded then there is metal in the oil.
Old 01-29-2013, 11:26 AM   #2974
derilict
Member#: 236549
Haha, oops, I'm like a kid, I only looked at the pictures.
derilict is offline
Old 01-29-2013, 11:50 AM   #2975
cvillesti
Member#: 286843
if it is the turbo, tom has a wrx turbo for sale for 200. and maybe we could work something out for my sti turbo haha..depending on how long you can have the car down for..an sti turbo wont work for your car will it..Im ignorant. sorry.
Closed Thread
Charlottesville crew: check in Boogalo Mid Atlantic Impreza Club -- MAIC 5932 03-17-2011 07:47 PM
Cobb Accessport V2.0 in stock @ GNV -- ready to ship! GNV Motorsports Engine/Power/Exhaust 15 01-16-2007 01:12 PM
Cobb Tuning AccessPorts V2.0 In Stock !!!, Get them before XMAS !!! RallySport Direct Engine/Power/Exhaust 0 12-19-2006 02:06 AM
1 Cobb Accessport for 2006 STi in stock -- brand new. Not V2.0 GNV Motorsports Engine/Power/Exhaust 2 11-13-2006 12:09 PM
