Mid Atlantic Impreza Club
Closed Thread
Old 12-11-2011, 10:57 AM   #1601
mrjcotten
Member#: 241953
02 hybrid/6speed
01 2.5 RS sedan
^^ Josh also assembled my short block for my hybrid. I happen know all of the guys down there.
Josh and Ray are both very good techs.
Why did you replace the intake manifold? Just curious.....
mrjcotten is offline
Old 12-11-2011, 11:01 AM   #1602
DurtyB
Member#: 292699
2011 WRX Sedan DGM
Stg1+ SF
Back from the woods.....spent 4 days freezing my ass off and never even saw a deer....hunting is for the birds if you ask me!
DurtyB is offline
Old 12-11-2011, 04:03 PM   #1603
alforester
Member#: 71670
2005 LGT
ABP
Originally Posted by DaveyPetey View Post
In other news all sorts of small stuff is starting to give me troubles on my whip. Clock is out, CC is out, Passenger side window controls rarely work, FL parking bulb needs replacing, etc.... But the adjustable speed and single pull wipers not working anymore has to be the most annoying one. Can anyone point me in the right direction?
Not sure on what might be going on.. but check my FS thread, I've got passenger side window controls and a wiper stalk for sale. Not sure if they'll fix your problem, but your welcome to see if swapping those out will work.
alforester is offline
Old 12-11-2011, 05:31 PM   #1604
mrjcotten
Member#: 241953
02 hybrid/6speed
01 2.5 RS sedan
Clock fix is right here. did the same on my bugeye and a couple foresters.
http://subarudiymodifications.blogsp...ard-clock.html
What is the CC? Cruise control?
Old 12-11-2011, 07:29 PM   #1605
Smurftastic
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
I had previously applied some Calyx coating to my intake mani, but really wanted a powdercoated STi-style mani. Bought one on the side, ported it, and am happy with the results
Smurftastic is offline
Old 12-12-2011, 12:15 PM   #1606
Boogalo
Member#: 77435
04 WRX Wagon Stg2
'94 Miata Project
gforce is having a fire sale again. $80 for 10 races or $99 for 14. starts friday and goes through the weekend.
Boogalo is offline
Old 12-12-2011, 01:04 PM   #1607
DaveyPetey
Member#: 239944
2002 WRX Sedan
Yeah. Cruise control. I hear/read that just some little plastic tab is prone to fall out. Anyone had this happen? What are you jamming in their to fix it?
Just got it back from the body shop. Those stupid pinch welds. All kinds of rust in in the wheel arch now gone. Now I just need to save up to do the other side.
DaveyPetey is offline
Old 12-12-2011, 01:15 PM   #1608
DaveyPetey
Member#: 239944
2002 WRX Sedan
Also does anyone have any experience with Peacock here in town? I would like to go to Cole's but he they can't take my car until Wednesday and tomorrow is my only day off for a few weeks. Or should I just figure out how to make it work with Cole's? It's some of the 90k check up I haven't got to and swapping out rotors and pads (stuff I haven't had the time to get to).
Old 12-12-2011, 02:42 PM   #1609
MSP608
Member#: 149631
ST-3 STi
2.3L Evo
Don't goto Coles. Ask Barry about them.
MSP608 is offline
Old 12-12-2011, 03:03 PM   #1610
Smurftastic
Member#: 243697
02 | BLOD Founding
I would go to High Speed Auto over Peacock for a 90K mile service simply because High Speed had a history of working on Subarus. No idea of Peacock does or not.. better to know than hope
Old 12-12-2011, 03:30 PM   #1611
scprs
Member#: 172359
2005 STi
Originally Posted by Smurftastic View Post
I will have to look through the work notes to confirm, but I think it may have been Josh, the same guy who put Sam's hybrid together. Whomever it was managed to pull out the intake manifold, TGVs, and TMIC - switch over all the fuel lines, the TGVs, and the throttle body to a new intake manifold, fix the fuel line recall, and re-install everything in roughly two hours.
It's not an easy recall to do, and I was told Brown doesn't do a lot of them, so I suppose it speaks to the competence of some of thier Subaru technicians.
Yessir glad it went smoothly for you and didn't cost you a dime! Those guys love when modded subarus come in because they usually see the same thing everyday. And the service there gets there bad rep because of up front not in the shop josh and ray have helped me out a lot over the years and are very straight up guys.
How did you get SOA to do this? I get the smell from time to time, but only on really cold mornings. I thought VA wasn't covered in the recall. My 02 spent it's first 4y in UT (Interestingly NOT covered nor is CO) and then 4 in upstate NY.
Im pretty sure SOA turned the "fuel seepage recall" into an issue with all the 02-03 wax's. Daves was pretty bad off. If you pm me your vin number I can check to see if its available for your car. All that stuff also just seems electrical switches tend to go bad over time unless you have some sort of electrical short.
scprs is offline
Old 12-12-2011, 03:53 PM   #1612
Mxbarry
Member#: 146837
2004 WRX STi WRB
98 Eclipse GSX
Almost sounds like you have a connector problem somewhere in the steering column since the cruise control and wiper controls aren't working. Power for the passenger windows is fed from the driver's door control pod, so there might be a loose connection there.
I haven't been to Cole's in ages, but they certainly had issues getting the timing belt installed correctly on my '98 Eclipse 4G63...screwed it up twice, in fact!
High Speed Auto did my clutch, and it seems okay, but they did forget to tighten the bolts for the driveshaft carrier bearing. One bolt fell out completely, and the other bolt was almost out. I've also had hydraulic issues with the clutch since it was replaced, but that might not be High Speed's fault.
So...I've had issues with almost every shop I've patronized around here. If I only had a garage so I could do the work myself...sigh.
Mxbarry is offline
Old 12-12-2011, 04:06 PM   #1613
DaveyPetey
Member#: 239944
2002 WRX Sedan
Thanks for all the advice everyone. This (sub)forum rules. I am moving to Seattle in the spring and have been frequenting their forum a little...seems really douchey compared to here which is a bummer.
It's a pretty straight-forward service so I think a drive to Barboursville might not be worth it. I'll give Peacock a shot.
Old 12-12-2011, 04:15 PM   #1614
Smurftastic
Member#: 243697
02 | BLOD Founding
Tell us how it is. High Speed has some good mechanics, but I think the issue boils down to them being too busy to pay attention 100% of the time.
One SAMCO hose and belt tensioner later...
Old 12-12-2011, 04:43 PM   #1615
DurtyB
Member#: 292699
2011 WRX Sedan DGM
Stg1+ SF
Hey Boog I might be down for this Wednesday...gotta check with the ol lady. How much is it again?
DurtyB is offline
Old 12-12-2011, 06:35 PM   #1616
2005 Suby STi
Member#: 169322
2005 STi
CGM
^ You are correct sir. Ray did a excellent job putting my power steering pump on after my screw up. The manager at the time even let my suby stay inside the garage for a few days while parts were ordered. The suby guys that know me around c'ville, know that my suby doesn't see any bad weather lol
2005 Suby STi is offline
Old 12-12-2011, 09:29 PM   #1617
Smurftastic
Member#: 243697
02 | BLOD Founding
The litmus test for covering the recall was the raw fuel smell. If you got it you KNOW IT!
Old 12-12-2011, 10:00 PM   #1618
Mxbarry
Member#: 146837
2004 WRX STi WRB
98 Eclipse GSX
I agree, Dave. The mechanic worked way into the night to get my car ready for me after the clutch replacement, and I appreciate that, but I almost wish they'd have taken their time and done it right.
It's supposed to be quite cold in the morning, so you'll know if it's fixed!
Mxbarry is offline
Old 12-13-2011, 08:32 AM   #1619
DurtyB
Member#: 292699
2011 WRX Sedan DGM
Stg1+ SF
OBP 11 wrx hatch pulled up next to me around 8 this morning on 29 and Boulders...had a red NASIOC sticker on the back window, but didnt give me the time of day to exchange nods or waves.....found that odd
DurtyB is offline
Old 12-13-2011, 08:39 AM   #1620
Mxbarry
Member#: 146837
2004 WRX STi WRB
98 Eclipse GSX
Headed to IIHS this morning to get a tour, and to watch them crash a Nissan Versa. Sweet!
Mxbarry is offline
Old 12-13-2011, 11:18 AM   #1621
Boogalo
Member#: 77435
04 WRX Wagon Stg2
'94 Miata Project
it would be about $50. membership + 3 races
Boogalo is offline
Old 12-13-2011, 11:23 AM   #1622
DurtyB
Member#: 292699
2011 WRX Sedan DGM
Stg1+ SF
Sounds good...Im in. When and where you want to meet?
DurtyB is offline
Old 12-13-2011, 12:20 PM   #1623
GEE-OTTO
Member#: 201277
2009 Legacy GT
They should crash everyone of those damned boxes as they roll off the assembly line. Rented one last weekend and had to stop at the Lube place on 29 and rio to get the check engine light looked at says it had a bad coolant sensor with 1912 miles on the clock curse Enterprise hahah
GEE-OTTO is offline
Old 12-13-2011, 01:23 PM   #1624
Mxbarry
Member#: 146837
2004 WRX STi WRB
98 Eclipse GSX
Actually, they were testing a frame replacement/repair on a Toyota Tundra V8, so they crashed one of those. They gave us a tour of their operations, and some of our GE controls operate the stuff in the crash hall, so we got to see that equipment too after the crash test. All I can say is, WOW! What a fun day!
And who own the WRB wagon there?
Mxbarry is offline
Old 12-13-2011, 01:50 PM   #1625
Boogalo
Member#: 77435
04 WRX Wagon Stg2
'94 Miata Project
YGPM5
Boogalo is offline
Closed Thread
Charlottesville crew: check in Boogalo Mid Atlantic Impreza Club -- MAIC 5932 03-17-2011 07:47 PM
Cobb Accessport V2.0 in stock @ GNV -- ready to ship! GNV Motorsports Engine/Power/Exhaust 15 01-16-2007 01:12 PM
Cobb Tuning AccessPorts V2.0 In Stock !!!, Get them before XMAS !!! RallySport Direct Engine/Power/Exhaust 0 12-19-2006 02:06 AM
1 Cobb Accessport for 2006 STi in stock -- brand new. Not V2.0 GNV Motorsports Engine/Power/Exhaust 2 11-13-2006 12:09 PM
