Welcome to the North American Subaru Impreza Owners Club Monday March 2, 2015
Old 07-15-2002, 11:16 PM   #1
TheShadowWRX
Member#: 11654
2002 WRX Sedan
WR Blue
Default Horrible Gas Milege on 1997 Legacy
Hey guys,
My friend has a 1997 Subaru Outback Legacy which gets b/t 12 and 14 mpg... 16 on a good day lol.
Could anyone offer some ideas or what to look for under the hood to see what could be wrong?
Thanks,
Mike
TheShadowWRX is offline   Reply With Quote
Old 07-17-2002, 06:27 PM   #2
TheShadowWRX
Member#: 11654
2002 WRX Sedan
WR Blue
bumb....
Any ideas?
Old 07-17-2002, 06:33 PM   #3
imprezadan
Member#: 6935
1999 Impreza 2.5RS
Rally Blue
Bad 02?
imprezadan is offline   Reply With Quote
Old 07-17-2002, 06:48 PM   #4
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
Is the car stock?
How many miles?
Have you been following the maint. sched? When was it last tuned up and what was done at the last tune?
NC
Reciprocity is offline   Reply With Quote
Old 07-17-2002, 06:49 PM   #5
TheShadowWRX
Member#: 11654
2002 WRX Sedan
WR Blue
Yea the car is stock.
it has 85k miles and hasn't been tuned since he got it - bought used at 71k miles or so.
Don't know how much that helps though.
Mike
Old 07-17-2002, 07:03 PM   #6
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
Well, it's just shy of 90K miles...and since you don't know the maint history prior...I would do a major engine tune including...
Replace plugs
Replace spark plug wires
Replace air fliter
Replace fuel filter
Replace PCV valve (if equiped)
Change oil
Check tire pressure
Those are all the things I can think of that would effect gas mileage. But there are many other things I would do as well including...
Rotate tires
Inspect and clean suspension
Check spare tire pressure
Flush and replace coolant
Replace rear diff oil
Replace tranny oil
Give the underside of the car a good cleaning
Give the engine bay a good cleaning
Wash and 3 step wax
Inspect wiper blades for replacement
Inspect clutch fluid (if hydrolic...I don't think a 97 is)
Inspect power steering fluid
Inspect brake fluid
Check brakes
But then I am an anal freak.
NC
Old 07-17-2002, 11:06 PM   #7
Keith99RS
Member#: 9243
05 Nissan Titan
06 B9 (hers)
Default How checking???
How is your friend checking his mileage?? Tell him to be sure his gas gauge reads correctly. My fiance's '97 Legacy Outback Wagon's gauge reads a 1/4 tank when in actuality there is still close to a 1/2.
Keith99RS is offline   Reply With Quote
Old 07-17-2002, 11:59 PM   #8
TheShadowWRX
Member#: 11654
2002 WRX Sedan
WR Blue
he fills up the tank, resets his trip odometer, then when he fills it up next time he writes down how many gallons he got and then does the number of miles over the number of gallons he just bought.
That is the right way to do it right?
Mike
Old 07-18-2002, 11:26 PM   #9
jhuang76
Member#: 1284
2005 Legacy GT
Royal Blue Pearl
That's an accurate way of measuring fuel consumption - for better accuracy, make sure to use the same gas station since different stations can have different length pump.
Dcrawford has given good suggestions, esp. if one plans to keep the car running!
Still, my bet would be on the O2 sensor. For a quick first step, have the ECM cleared out and see if that helps. Check the tailpipe of the car and see if it is really black (sign of very rich combustion). I've seen this done - wipe the exhaust with a rag (make sure it's not hot!!!) really well, drive it around for a few days, then using another rag wipe it again to see how much unburnt hydrocarbons come off. If it's really black again, very good chance it's a bad O2.
jhuang76 is offline   Reply With Quote
Old 07-19-2002, 01:58 AM   #10
TheShadowWRX
Member#: 11654
2002 WRX Sedan
WR Blue
Ok Thanks a lot guys.
Ill keep you up to date on what happens...
Mike
Opinion on 1997 Legacy 2.5GT nick9871 General Community 3 08-20-2009 09:57 PM
F/S 1997 Legacy 2.2L gas saver foolio Private Vehicle 'For Sale' Classifieds 0 07-06-2008 11:29 AM
What's your record gas mileage on your Legacy? Wiscon_Mark Legacy Forum 52 04-03-2006 10:06 PM
cobb stage 2 and gas milege RexSpeed Engine Management & Tuning 16 07-25-2005 06:09 AM
