Old 03-18-2011, 01:43 PM   #1
20SubieDude05
Member#: 127380
2011 WRX Sedan
Obisidian Black Pearl
Default Debadging 2011 OBP WRX Premium, got questions!
Hello all,
I am planning on debadging my WRX today, the sun is out so why not? I have done this on my 2009 WRB WRX Base and the imprints showed up a little. Since I have a 2011 OBP WRX now, I am afraid the imprints will show up even more since it's black. Any suggestions? I used floss before, but I will do fishing line this time and would WD-40 work well on it? I used that on the 2009 WRX, and seemed to do the trick. Just looking for more effiecient ways to do the debadging this time. Thanks!
P.S. I will post before and after pics.
20SubieDude05 is offline   Reply With Quote
Old 03-18-2011, 02:19 PM   #2
20pvwrx11
Member#: 271144
2011 Wrx
Satin White Pearl
I had the dealership do mine and actually the salesman did it haha. It looks great on the white and cant tell there were badges at all. Good luck!
20pvwrx11 is offline   Reply With Quote
Old 03-18-2011, 03:01 PM   #3
FLDY10
Member#: 263503
'11 STI
I did mine with a hair dryer fishing line and a little instant detailer to take the residue off. Took all of 15 minutes.
FLDY10 is offline   Reply With Quote
Old 03-18-2011, 03:08 PM   #4
smitty24
Member#: 272671
2011 WRX 5dr
fishing line and goo-gone
you wont see a thing.
smitty24 is offline   Reply With Quote
Old 03-18-2011, 03:13 PM   #5
dsmtweaker
Member#: 265405
2013 Audi
Did both front and rear in about 10min. Used the wifeys hair dryer, and a blockbuster card. Pulled of most residue with fingers, then used a damp cloth to get the rest. Finished it off with a car wash. Cant tell it ever had badges now...
dsmtweaker is offline   Reply With Quote
Old 03-18-2011, 03:24 PM   #6
Yellow_Feva
Member#: 269659
04 Forester STI
Very nice, clean.
Good job.
Yellow_Feva is offline   Reply With Quote
Old 03-18-2011, 03:38 PM   #7
20SubieDude05
Member#: 127380
2011 WRX Sedan
Wow, those pictures look amazing! Check mine out! Took me longer than 30 minutes, but oh well. Looks super clean!
Pre-Debadge:
Debadging in progress:
Post-Debadge:
Old 03-18-2011, 03:53 PM   #8
20SubieDude05
Member#: 127380
2011 WRX Sedan
How did you do the front? Looks clean as well, might want to do that to mine as well.
Old 03-18-2011, 06:46 PM   #9
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
I hear if you have your car towed and you don't have your AWD badge you can't press charges if they tow your car incorrectly and damage something :\
xabre1200 is offline   Reply With Quote
Old 03-18-2011, 07:11 PM   #10
brandonk_5
Member#: 268700
I'm going to go on a limb and say if you're that worried either leave a note or tell them yourself. If you're too lazy to make sure that they know it's awd then it semi deserves to happen. Just leve the awd badge on then.
brandonk_5 is offline   Reply With Quote
Old 03-18-2011, 08:27 PM   #11
mrkyle3
Member#: 272675
2011 WRX
2004 Miata
I debadged mine a few days after I got it. I just used some dental floss, nothing else, no goo gone or anything. I guess the adhesive didn't really have enough time to set fully, I would just get the letters started and then I could peel them and the adhesive off with my fingers. I just wiped the area with my sleeve really quick and there were no marks left.
mrkyle3 is offline   Reply With Quote
Old 03-19-2011, 10:52 AM   #12
dsmtweaker
Member#: 265405
2013 Audi
The front is kind of tricky. I took out the 4 screws on top, so I could lean the grill forward. Then I reached in and pushed the badge forward while holding the back plate.
FYI you will most likely destroy the badge while removing it. I know many have myself included.
Old 03-19-2011, 11:36 AM   #13
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
did mine with dental floss and rubbing alcohol
Nimbus09 is offline   Reply With Quote
Old 03-19-2011, 01:00 PM   #14
20wrx09
Member#: 207417
2009 WRX
td06sl2-20gtx 413/423
get one of these and problem solved
20wrx09 is offline   Reply With Quote
Old 03-20-2011, 07:36 AM   #15
JeanetteWrx
Member#: 275753
2009 Impreza WRX
Satin White Pearl
Did mine with fishing line an nail polish remover. Had to really get at the adhesive tho. Will post before and after pics in a few hours for those interested. White 09 wrx.
JeanetteWrx is offline   Reply With Quote
Old 03-20-2011, 07:46 AM   #16
NMZ_WRX
Member#: 198280
2007 BLACK MONSTER
WINGLESS
heatgun blowdry first
use dental floss and use the heatgun
once the adhesive is heated u should be able to rub it off easily with your finger
NMZ_WRX is offline   Reply With Quote
Old 03-20-2011, 05:08 PM   #17
JeanetteWrx
Member#: 275753
2009 Impreza WRX
Satin White Pearl
here are some pics
EDIT;one of the pics didnt show up
Old 03-20-2011, 05:13 PM   #18
bbun
Member#: 184554
02 ghettoFABness
bugeye rolling.
hm wheres the end
bbun is offline   Reply With Quote
Old 03-20-2011, 05:16 PM   #19
gianspi
Member#: 113006
'01 Suzuki Bandito
1200cc
I have this right above my VIN number on the front windscreen so it is in obvious view:
$7 @ FastWRX
gianspi is offline   Reply With Quote
Old 03-20-2011, 07:15 PM   #20
hom69
Member#: 250143
+1 Exactly what I did for my friend's 11 wrx.
hom69 is offline   Reply With Quote
Old 03-20-2011, 07:19 PM   #21
aboogabooga
Member#: 181127
1999 Civic
Rust
Its on your window...
aboogabooga is offline   Reply With Quote
Old 03-20-2011, 07:20 PM   #22
shaggydog
Member#: 247390
'11 STi
This. I had the wife use her blow dryer while i flossed behind the emblems. Rub off any residue left over. Also make sure you throw a coat of wax where the emblems were. I used an all in one cleaner that waxes while it cleans. Then a month later i had it properly clay bared and waxed.
shaggydog is offline   Reply With Quote
Old 03-26-2011, 05:53 AM   #23
giraff
Member#: 258189
2011 WRX, 5-door
SSM
It might be easiest to take off the bumper first, to have easy access to the clips securing the badge. Taking off the bumper is a piece of cake, and you won't risk damaging your badge while removing it.
giraff is offline   Reply With Quote
Old 03-26-2011, 12:12 PM   #24
piecemealBHC
Member#: 106248
2015 WRX CWP
2000 RS 2.5
It is on older models - the newer models have a chrome badge on the trunk instead though:
piecemealBHC is offline   Reply With Quote
Old 03-27-2011, 10:51 AM   #25
popalotapuss
Member#: 270888
2008 GR STI
mine took 15 minutes
blowdryer + pull off with fingers
blowdryer + rub adhesive off with fingers
denatured alchahol to wipe off residue
clay rub and wax
if you use a heatgun, set it on low so it does not damage the paint
popalotapuss is offline   Reply With Quote
WTB : 09/10 OBP WRX Premium BUMPER COVER tb16ua Private 'Wanted' Classifieds 2 01-13-2011 02:50 PM
FS : 2008 OBP WRX Premium Auto JCharron2005 AKIC Private Classifieds 15 11-06-2010 04:17 AM
fs: 05 obp wrx in socal premium package fdrx7 Private Vehicle 'For Sale' Classifieds 10 05-08-2009 11:33 AM
WTT: OBP debadged STI trunk 4 OBP WRX or RS TRUNK wrxtremeWGN Tri-State Area Private Classifieds 3 02-22-2007 06:37 PM
