Old 03-19-2011, 09:39 PM   #1
f575gtc
Member#: 267839
2011 STI
Default Help installing Bazooka Tube
I purchased a 10 inch 250 watt self powered bazooka tube for the car because I had heard them before and they were really powerful for what I want, the thing is I ran the install to the rear speakers off the harness and the tube has very little bass nothing compared to what I had heard.
if I turn up the bass on the radio and sub and fade the speakers to the rear I get alot more bass but still not what I was expecting.
Is this an issue with the factory radio? that it doesn't allow as much power through the rear speakers? even then though the sub should amplify it.
if so how does the Kicker 10 inch sub they released for 2011 work?
I have a 2011 STI non navi unit btw.
any input here?
f575gtc is offline   Reply With Quote
Old 03-19-2011, 09:54 PM   #2
863JOE
Member#: 271079
Ok, my first question is are you using a Line out converter for the RCA's to hook into?
863JOE is offline   Reply With Quote
Old 03-19-2011, 10:09 PM   #3
f575gtc
Member#: 267839
2011 STI
I am not using the RCAs I am using plain speaker wire to go into the left and right rear speakers on the harness back to the grey/green connectors on the sub, it has both RCA and plain speaker wire connections.
Old 03-19-2011, 10:14 PM   #4
863JOE
Member#: 271079
Ok, I strongly recommend the use of a line out converter. The line out converter taps into a speaker of your choice, plus you can amplify the signal on the converter with it's gain controls. The reason you're getting bad and little sound is the bazooka tube is most likely getting a weak signal from the speaker alone. Go to your local audio shop and ask them for a Scosche LOC80.
http://ak.buy.com/PI/0/500/90119264.jpg
That, SHOULD do the trick. There are other possibilities, but from what you're describing I think this is your solution.
Old 03-19-2011, 10:27 PM   #5
f575gtc
Member#: 267839
2011 STI
what I do not understand is the amp on the tube should be doing this no?
I have a direct wire from the radio to the sub and the sub has its own gains and xover built into the amp on it.
if I install the converter you mentioned it would just tweak the already weak signal I am getting.
something has to be up here, I looked at the kicker 10 inch by Subaru and its basically the same thing a harness so you don't have to tap into the wires and regular line wires to the back of the sub where it plugs into its built in amp.
I appreciate the advise though.
Old 03-19-2011, 10:44 PM   #6
roof_rack
Member#: 257866
OT, but you ever cruise through monroe? pretty sure ive seen your car a few times haha
roof_rack is offline   Reply With Quote
Old 03-19-2011, 10:47 PM   #7
f575gtc
Member#: 267839
2011 STI
sometimes on weekends.
Old 03-19-2011, 10:51 PM   #8
863JOE
Member#: 271079
You're missing what I'm saying. Your RCA's pretty much " send music " to the amp to play. RCA's also carry voltage, when you have low voltage in your RCA's it will affect your sound significantly. Your amp CAN boost the RCA signal, but it will give a unclean and distorted signal for your sub to play and will sound bad. The LOC will boost the signal from the source so you will be getting a clean signal to begin with, then the bazooka tube amp will only have to worry about powering the sub so to speak since it isn't trying to push a sub while boost a weak RCA signal.
Old 03-20-2011, 01:41 AM   #9
f575gtc
Member#: 267839
2011 STI
Ok so after speaking to Bazooka it sounds like the sub is "out of phase"
meaning both channels are canceling each other out and I was advised to reverse the polarity on one of the channels
ok great, but won't that blow out the sub?
Old 03-20-2011, 02:46 PM   #10
BBarnes1
Member#: 228774
15 WRX
Lightning Red
Line converter wont help either. Your problem is that the OEM hu doesn't turn up bass with volume. It pulls bass to protect the speakers. You need a processor, JL cleansweep or MTX RE-Q5. Those will even out the EQ so your bass volume will increase proportionally.
BBarnes1 is offline   Reply With Quote
Old 03-20-2011, 02:53 PM   #11
iyzmi
Member#: 150004
2002 18g WRX
WRB 310hp/285tq
On my old 2.5i, I had a Boss 8" under-seat amplified sub with the stock head unit. I used a LOC to tie into the rear speakers and set the gain on it to the middle setting; the sub sounded great (for what it is). My current car came with the stock HU and a set of 2 12" subs in the trunk, also running through a LOC tied into the rear speakers. Sounded very loud....too loud for my tastes actually. I don't think you need a sound processor to run a basic bazooka tube setup, just get a LOC for <$20 online and see if it helps. I got mine for like $16 on ebay for my old car.
iyzmi is offline   Reply With Quote
Old 03-20-2011, 03:07 PM   #12
typhoonk
Member#: 259497
1998 legacy L Wagon
Green/Grey
sounds like the sound coming to the rear speakers are already filtering out sub frequencies.
If the cd player has a sub out function (but you just don't have the factory sub), I'd use that output to tap into.
or
try tapping into the front speakers (if they play more bass then the rears this could be better).
typhoonk is offline   Reply With Quote
Old 03-20-2011, 03:21 PM   #13
teiva-boy
Member#: 22825
Some factory units also as the volume is turned up, the loudness setting is lowered. factory EQ'ing is a tricky beast.
teiva-boy is offline   Reply With Quote
Old 03-20-2011, 03:23 PM   #14
f575gtc
Member#: 267839
2011 STI
you are right, the fronts are definitely more "bassy" than the rear, could it be that the built in amp on the radio filters bass to the rear so they don't have as much power?
also something very odd, I checked the sub to make sure it was in phase and it wasn't so I fixed that but the bass didn't improve, what was going on though every time I increased the volume past 35 on the radio the audio would cut out, I biased the speakers to the rear +4 and it stopped.
and the bass POUNDS at 40 which is the max, but at 25-30 where I usually listen it's just not there, I wonder if I should have gone to the front speakers to begin with.
teiva-boy I know what you are saying, I have seen that in factory radios with a built in sub, at max volume the bass is REALLY present and it was shaking my mirrors where I couldn't see out of them, so I don't think the factory impreza radio does that.
Old 03-21-2011, 12:04 PM   #15
f575gtc
Member#: 267839
2011 STI
can anyone confirm that the front speakers are white/black - blue/orange for the left and green/ brown - green/ yellow for the right?
Old 03-21-2011, 01:13 PM   #16
863JOE
Member#: 271079
Look on the speakers, they should still have a + and -
Old 03-21-2011, 01:21 PM   #17
BlackonBlueSubaru
Member#: 222448
04 WRX
Default ------
get rid of the factory HU and get an after market with RCA's out , and an Ipod interface... much better imo ...
BlackonBlueSubaru is offline   Reply With Quote
Old 03-21-2011, 01:57 PM   #18
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
any input here?
Connect your sub to your front speaker outputs and see what happens...
You do not need a LOC, the tube has both RCA and speaker level inputs..
Old 03-21-2011, 02:03 PM   #19
f575gtc
Member#: 267839
2011 STI
I fixed it! woot now I have some bass!
for anyone thinking of doing a bazooka tube use the front speakers not the rear
we got a nice 3 inches of snow here in CT today and all the bass cleaned the snow right off the car!
Old 03-21-2011, 02:08 PM   #20
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Fixed due to my post? or fixed because you where switching the wires as I typed out my post?
Good show man, I knew it was simple... SOMETIMES, the forum can't see the forest for the trees...
Old 03-21-2011, 02:11 PM   #21
silvercookie
Member#: 180033
2005 WRX
The tubes have a built in converter.
silvercookie is offline   Reply With Quote
Old 03-21-2011, 02:29 PM   #22
mdecker79
Member#: 274988
2011 STI Sedan
PBP
I just installed the 10" 250 tube this weekend and had the same issue. We jumped off the rear and had like zero bass. Figured out that the stock HU is only sending mids and highs to the rear for some reason. Re tapped off the fronts and it hits hard.
I have a clarion cx501 on order and will be installing it next week or so.
mdecker79 is offline   Reply With Quote
Old 03-21-2011, 02:43 PM   #23
mdecker79
Member#: 274988
2011 STI Sedan
PBP
OP..
Where did you mount yours?
I pulled the floor carpet back right as it goes up and mounted mine sideways against the rear seat. The straps screw right into the metal there and looks great. Then when I let the floor carpet go back it creates its own wall so to say which just looks like the trunk and it totally covers the tube. You can't even see it with the trunk open.
Old 03-21-2011, 03:01 PM   #24
f575gtc
Member#: 267839
2011 STI
I mounted mine with its back up against the rear seats and the front sub part towards the hatch door
it fits in there perfectly front to back also I have a bungie net in the back that holds in in place and used the strap it came with to loop it to the other net hooks in the car it doesn't slide anywhere.
I only read your post now, sorry. I spoke with Bazooka yesterday on the forums and they told me to go off the front speakers instead its where they recommend it
and yes for a 10 inch 250watt sub it hits VERY hard!
now even at 15 volume I have good bass at 30+ my side mirrors vibrate
Old 11-19-2012, 02:02 PM   #25
amanMaphia
Member#: 177368
2011 wrx
Did you use a Line output converter or the sub harness to get RCAs for your tubes?
amanMaphia is offline   Reply With Quote
I Need Help Installing a Powered Bazooka Bass Tube mzdrati Car Audio, Video & Security 14 03-30-2006 11:39 AM
Help with troubleshooting Bazooka tubes... Hank3 Car Audio, Video & Security 7 08-29-2004 07:24 PM
A pair of Bazooka Tubes Aphex28 Tri-State Area Forum 0 10-01-2002 05:27 PM
Bazooka tube install and stock head unit question Silky Car Audio, Video & Security 1 08-30-2002 04:40 AM
Looking for used bazooka tube GM991 Car Audio, Video & Security 7 03-02-2002 12:01 PM
