Old 03-20-2011, 01:08 PM   #1
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
Default 2012 BMW 1 Series Prototype Testing In Munich
Old 03-20-2011, 06:44 PM   #2
Hites
Member#: 138997
0000 Nothing
Is "bastardized" the word?
Hites is offline   Reply With Quote
Old 03-20-2011, 06:53 PM   #3
SoapBox
Member#: 204578
S54 E46, N54 E82,
N55 E84, AKA REX8
Explanation?
SoapBox is offline   Reply With Quote
Old 03-20-2011, 07:14 PM   #4
Wrgb
Member#: 169096
2009 DGM STi Hatch
2000 2.5RS *Gone*
Looks like a crappy version of the mazda 3 sport.
Wrgb is offline   Reply With Quote
Old 03-20-2011, 07:20 PM   #5
Scoobie Doogie
Member#: 9805
2009 Bimmah 135 eye
Silvuh
Like a Mazda 3 is a looker?
Scoobie Doogie is offline   Reply With Quote
Old 03-22-2011, 09:21 PM   #6
Ysidro
Member#: 197418
07 WRX Ltd
The Mighty Evo;Fun CRZ
The shape of this car is just really ugly. I know, I know, its not the final version yet so give it a chance.
Ysidro is offline   Reply With Quote
Old 03-22-2011, 09:41 PM   #7
NismoSkylineGTR
Member#: 94622
throw in the 335 TT engine and make it under 40!!!
NismoSkylineGTR is offline   Reply With Quote
Old 03-22-2011, 10:34 PM   #8
Mariano
Member#: 56
Chapter/Region: PRSIC
1999 RS-T (Stage V)
2005 LGT LTD
+1...
Mariano is offline   Reply With Quote
Old 03-22-2011, 11:03 PM   #9
Hites
Member#: 138997
0000 Nothing
You guys do realize this is going to be FWD, right?
Old 07-14-2011, 04:15 AM   #10
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
Default BMW 120d review
What is it?
BMW’s second-generation 1-series five-door hatchback. It goes on sale in the UK this September priced from just under £20,000, although a 120d like the one we tested will set you back closer to £25k.
With limited practicality, mediocre material quality, curious styling and a flawed and uninvolving drive, the old BMW One never really earned its stripes in BMW’s habitual class-leading sense. Despite being four grand cheaper than an equivalent 3-series, it was consistently outsold in the UK by the bigger BMW saloon, not to mention most of its key rivals – and that’s in its second largest global market.
So, after a complete redesign and restyle and a through engineering overhaul, can the new 1-series stamp greater authority on what’s become Europe’s most important market segment for premium brand players?
What’s it like?
The new 1-series is a car that looks as if it’s been steered, albeit carefully, in the right direction. The press material talks less about dynamic rear-driven handling, and at reassuring length about enhanced comfort and accommodation, improved efficiency and new-to-the-class technology. Which is a good start.
Longer than the old car by 85mm, the new One has a wheelbase that’s been enlarged by 30mm, with 21mm of that extra inter-axle length gone to additional rear legroom. Both tracks have been widened too, by a natch over 40mm at the front axle, and over 60mm at the rear.
Although it’s grown, the new car is 30kg lighter than the old one: would have been 60kg, but climate control now comes as standard. And a thorough structural redesign means the car’s body-in-white is now more than 30 per cent more torsionally rigid across the front bulkhead. That’s good news for ride and handling, too.
Adrian van Hooydonk’s styling update hasn’t cured the ungainly proportions of BMW’s smallest model, but the net effect is a clear improvement. The new car looks lean, more aggressive than the last. The biggest aesthetic bugbear remains the car’s profile, though. Short, tall and backward leaning, it still looks awkward: like a gangly pup that’s had the carpet pulled out from under its paws.
Developed in tandem with the new 3-series, the new 1-series, like the last, has all-independent suspension: MacPherson struts up front and a five-link rear end. The car will be sold exclusively with turbocharged engines: two flavours of directly injected, twin scroll turbocharged 1.6-litre petrol power will be offered from launch (135bhp for the 116i and 168bhp for the 118i), and three 2.0-litre commonrail diesels (ranging from the 115bhp 116d up to the 181bhp 120d).
With 280lb ft of torque from 1750rpm, performance from the 120d is as strong as you’d hope: 60mph comes up in around seven seconds. The powertrain’s all the more exceptional because, fitted with ZF’s excellent eight speed automatic gearbox as an option and BMW’s Efficient Dynamics fuel-saving ancilliaries as standard, the car emits less than 120g/km of CO2. This is a car capable of bettering both 140mph and 60mpg; not at the same time, of course, but remarkable from the same car.
Open the driver’s door, lift your feet over the raised sill, and one or two signs of sophistication begin to show themselves. Material quality’s that bit more consistent in here than it used to be; the plastics around the door pulls, storage cubbies and steering column look much less cheap. Elsewhere the mix of trim on the fascia is varied and attractive – with one exception. Our ‘Urban’ spec car came with glossy white plastic highlights on the centre console, door handles and dashboard that look like offcuts from Apple’s iMac storage cupboard. Thankfully the same trims are available in gloss black, which would certainly compliment the rest of the interior better.
It’s still no packaging marvel, but the second-gen 1-series has enough head- and kneeroom for average-sized adults to sit line-astern in the two rows. You can be well over six feet tall and sit comfortably in the front. Getting in and out of the back is still something of a contortion routine, but once aboard bigger passengers can find reasonable comfort provided the front seats are sympathetically positioned. In short, a VW Golf is a considerably more practical car, but the 1-series may now be big enough to put up with – just.
Would it matter, though, that this new car was bigger, faster, classier and more efficient, if dynamic-centric BMW hadn’t also made it significantly better to drive? Well, the new 1-series is a notably more accomplished dynamic performer than its predecessor, for sure. But it’s still no class-leader.
Conjure up the memory of the last 1-series - of heavy steering shot through with understeer, and a tame chassis that lacked both balance and poise - and this new BMW seems a big achievement. Even on standard springs and passive dampers, it remains a fairly firmly sprung car. It still feels a little short of wheelbase and relatively tall of body at times; has a tendency to gently pitch fore and aft over larger lumps and bumps in a way that a car with a lower, longer profile wouldn’t. But it’s not without decent bump absorption or compliance, and equipped with BMW’s adaptive dampers set to ‘Comfort’ mode it’s softer still, yet only loses Munich’s trademark feeling of tautness on the worst surfaces.
Even with an electromechanical power-assisted rack the new 1-series steers with less effort and greater fluidity than the old car, and turns into corners more keenly. Those wider tracks have dialled out a lot of body roll along with some understeer. And there are more improvements besides.
So why no overall ringing endorsement? Because – and this is the bit that BMW really needs to heed – even counting the ‘perfect weight distribution’ and ‘standard drive’, we could name a dozen front-driven hatchbacks that each offer a much more involving at-the-wheel experience.
The original 1-series’ mechanical layout added almost nothing to the car’s handling; this new 1-series may feel more precise, more composed and less remote than the last, but it suffers with the same fundamental problem. It’s too tame, too unengaging to properly represent its maker’s perennial universal selling point. Its course through a fast bend isn’t responsive to adjustment via either brake or throttle pedal. Up your pace on a twisting backroad and, while other rear-drivers come alive, this one remains docile and inert.
Should I buy one?
BMW says that 70 per cent of 1-series buyers are new to the brand, and if that’s true, maybe the car’s main failing isn’t so critical. More rounded dynamics, greater refinement and usability, some great powertrains and a more appealing driving environment make this a 1-series that’s much easier to recommend against its peers, after all.
But it’s still not a great-driving BMW; doesn’t distinguish itself from other cars in the class with the entertainment you expect from a car with a blue-and-white propeller on the bonnet. And now you wonder if an ordinary 1-series hatch ever will.
Old 07-14-2011, 06:54 AM   #11
tylerzero
Member#: 112397
'06 non-turbogasm
wagon
I'm not sure the "net" in that statement takes into account that infinitely more 'meh' front end.
tylerzero is offline   Reply With Quote
Old 07-14-2011, 10:17 AM   #12
Masterauto
Member#: 198376
STI E30 M3
Nissan GT-R 15
There was an old woman who drove a car that looked like a shoe )))
Masterauto is offline   Reply With Quote
Old 07-14-2011, 10:25 AM   #13
samagon
Member#: 26859
of TXIC
I also like (oYo)!!!!
No, you were right to scorn, it looks like someone **** on a log and threw a badge on it.
Old 07-14-2011, 10:30 AM   #14
arghx7
Member#: 232940
definitely looks like an earlier Mazda 3 hatch with BMW front
arghx7 is offline   Reply With Quote
2012 BMW 3-series Adds a Turbo Four, Hybrid, and Hatchback to the Range Tea cups Non-Subaru News & Rumors 22 06-25-2009 03:22 PM
Bmw 1-Series Supersport coming in 2012 AVANTI R5 Non-Subaru News & Rumors 20 03-14-2009 12:40 AM
Preview: 2012 BMW 3-series crossover (V3) AVANTI R5 Non-Subaru News & Rumors 5 04-23-2008 05:56 PM
Spy Video: BMW’s PAS caught testing in Munich AVANTI R5 Non-Subaru News & Rumors 4 01-11-2008 01:10 PM
New BMW 5 Series Prototype Caught Again in Munich NYCshopper Non-Subaru News & Rumors 12 12-22-2007 01:53 PM
