Old 03-20-2011, 10:57 PM   #1
mclmk8d
Member#: 4493
2002 WRX Wagon
Blue (what else!)
Default Widest tires for +0 on 2002 WRX wagon
I have an extra set of 16" 1998 RS goldies (16X7) that I want to use for the occasional HPDE track weekends. I'd like to put some race tires on, and don't want to roll fenders on my wagon, which is at stock height. I know that +0 is 225/50-16. What wider tire can I use on the wheels that would still fit without rubbing. Any help is much appreciated...thanks in advance.
mclmk8d is offline   Reply With Quote
Old 03-21-2011, 12:08 AM   #2
mmiller2002
Member#: 159286
2002 WRX Wagon,Com-C
RCE wgn sprngs/Konis/H6
I wouldn't go wider than 225 on the 7" for the track.
mmiller2002 is offline   Reply With Quote
Old 03-21-2011, 07:01 AM   #3
KC
Member#: 442
16 SS
00 S2000
This ^^^. If you're looking for additional grip, can you run r-compounds? I'd suggest doing that in 225/50-16 before looking at bigger tires. Why? You'd need a new wheel (see below) in the very least to put on r-comps in the 245/45-16 size, because they run wider than typical 245's and *will* rub.
It's the rears where you'll run into a bigger issue with the wider tires. I did have 245/45-16 Falkens on my '02 wagon for a bit, but those were on properly sized 16x8 Volk Gram Lights with a 43 offset to move the center of the tire/wheel where it needed to be to avoid rubbing and a rolled fender... and it was *close* on both sides. I don't think you're going to be able to get it done with wider tires on the RS wheels, on the back of your wagon without new wheels in the very least.
--kC
KC is offline   Reply With Quote
Will 2002 sti stuts with lowering spring fit straight on 2002 WRX wagon? Martin.dean1981 Brakes, Steering & Suspension 2 01-23-2011 11:47 AM
will 2007 WRX Sedan TBE fit on 2002 WRX Wagon? schiarelli General Community 11 11-05-2009 04:51 PM
Widest tire for 18x8 on 06 wrx GregsblueRex Tire & Wheel 5 02-22-2006 12:50 PM
Perrin Tunersport Springs on 2002 WRX Wagon SpeedWagon41 Brakes, Steering & Suspension 10 10-04-2005 06:03 PM
Socal: Gauging Interest on 2002 WRX Wagon Suspension hey1 Private 'For Sale' Classifieds 57 06-19-2005 04:49 AM
