Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Old 07-16-2002, 02:18 AM   #1
THAITEA87
Member#: 21424
02 wrx soon
i want black
Post All Bout Turbos
ok wat i wanna know is wat does vf,gt,t,and all that other stuff for classifyin turbos mean ??? for example whats the diff between a vf 30 and a vf 34???? is a vf 34 bigger than a t 34?? is a t60 and a gt 6235 or watever the same thing?!?!?!?!
SOME ONE PLEASE HELP MEH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
THAITEA87 is offline   Reply With Quote
Old 07-16-2002, 03:58 AM   #2
mitch808
Member#: 10228
2002 Subaru WRX
The VF34 has a ballbearing center section whereas the VF30 has a bushing. Supposedly a bushing will last longer, but the ballbearing spools slightly faster... Your choice
As for others, names like PE, VF, etc... They are all brands/models. VE or IHI, and PE or Power Enterprise( I think) and isn't a Txx a turbonetics?
mitch808 is offline   Reply With Quote
Old 07-16-2002, 09:42 AM   #3
Division By Zero
Member#: 7555
The T series and the GT series are both Garrett.
The PE, as mitch808 pointed out is the Power Enterprises line. The PE's, from what I know use IHI turbos and modify them to their specs. Hence PE1818. PE may use other turbos besides the IHI units but I'm not for certain.
The VF is a series from IHI, i.e. VF22, 23, 24, and so on. Just becasue one has a larger number than the other doesn't necessarily mean that it is larger than another. As in the VF30 vs VF34, same turbos but different bearing types.
And, I also believe that HKS or one of those companies utilizes Garrett turbos and modifies them to their specs. They call them GT as well.
If anybody can correct me please do. That's what I knew them as.
Division By Zero is offline   Reply With Quote
Old 07-16-2002, 10:31 AM   #4
STEALTH-WRX
Member#: 7822
Multi layer snot green
t series does not automatically mean big ass turbos. there are plenty of tiny turbo's that run in the t series. ie : t-18, t-25. but generally speaking we refer to the t series as being big. but dont forget the little guys.
STEALTH-WRX is offline   Reply With Quote
Old 07-16-2002, 11:28 AM   #5
Division By Zero
Member#: 7555
Ok I edited my first post and took out "big ass" being synonmous with the T series. Sorry for leaving out all of the little guys
Old 07-16-2002, 12:25 PM   #6
THAITEA87
Member#: 21424
02 wrx soon
i want black
Default t60
sum guy in a nothor thread aid a wrx with a T60 and NOS ran 10s.
i thought a t60 wasnt possible for the new generation rex??????
There is a WRX here with 551hp @ all four. It ran a 10.48 @ 141mph -- I believe it had a T66 with NOS to spool it up but can't remember for sure.
Old 07-17-2002, 12:20 AM   #7
Conduit
Member#: 6162
MBP, 1st WRX Ever in FL.
Um, shouldn't you be asking this in one of the technical engine forums where there are people there who can answer you?
Also, why do you think a T60 won't work? That doesn't make any sense.
Conduit is offline   Reply With Quote
Old 07-17-2002, 04:33 PM   #8
THAITEA87
Member#: 21424
02 wrx soon
i want black
i thought a t60 wouldnt fit.wats the spool time 4 a t60 ne ways
Old 07-17-2002, 08:13 PM   #9
STEALTH-WRX
Member#: 7822
you could probably fit almost any turbo on a subaru impreza. the problem is that it is not bolt on. many now have made or cut their up pipe and made then fit other turbos such as garrett or turbonetics. its just not easy and it takes someone who knows what they are doing and alot of time. anything can be done. its just the $$$$$$$$$$.
for all non-turbos that want to be turbo (ebay inside) ArmOinAwRx Off-Topic 22 11-25-2007 05:42 PM
all bout turbos THAITEA87 Newbies & FAQs 1 07-16-2002 09:34 AM
Turbo Question for all you turbo people out there Jimmy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 05-14-2001 01:30 AM
Turbo Setup Idea For all you Turbo designers!!!! Everyone tell me what you think Turk General Forum Archive 14 07-18-2000 08:39 AM
Turbo Setup Idea For all you Turbo designers!!!! Everyone tell me what you think Turk Technical Forum Archive 3 07-17-2000 09:24 AM
