Welcome to the North American Subaru Impreza Owners Club Saturday December 3, 2016
Old 08-01-2015, 08:27 PM   #1
Bahaa425
Member#: 384641
Default Rich AF Learning view
Hey would you all mind looking at my learning view? from what it looks like to me, i have a boost leak somewhere causing it to advance timing and run rich. The iam is at 11, might be because I've only put 40 miles after reseting the ecu but i dont know. Also the tune calls for 17psi but the waste gate is currently at 14.5psi (not sure if that makes a difference). The car spools fast, and pulls strong, the spool is crazy loud and almost becomes a sort of whistle at wot. It could be the port and polish or i could have a boost leak. The insides of the housings were where mirror like. If you all have any insight on what i should do next in my tune it would be greatly appreciated!
The cars is as followed
jdm ej20t
catless upipe, downpipe, midpipe
Spt cai
Spt catback
silicone inlet
PNP td04
XPT stage 2 flash
https://drive.google.com/file/d/0B0K...Y3QXhTVTA/view
Bahaa425 is offline   Reply With Quote
Old 08-02-2015, 10:25 AM   #2
Bahaa425
Member#: 384641
Hopefully you guys with experience will see this and let me know if I've gone wrong somewhere
Old 08-02-2015, 03:47 PM   #3
Bahaa425
Member#: 384641
Seeing anything?
Old 08-03-2015, 04:17 PM   #4
fenix-silver
Member#: 231700
2004 WRX Wagon
That doesn't look very good. Your fuel trims indicate that the ECU is removing fuel due to the tune being rich. And at 40 miles, the IAM should have gone up I believe. If you have a post MAF air leak, your ECU would be adding fuel, not removing it. FYI, I had an XPT stage 2 tune and my car hated it. Got an e-tune instead. Way better.
fenix-silver is offline   Reply With Quote
Old 08-03-2015, 04:18 PM   #5
Bahaa425
Member#: 384641
Old 08-03-2015, 04:18 PM   #6
Bahaa425
Member#: 384641
Yea im not really liking this tune, who should i contact about the etune?
Old 08-04-2015, 10:26 AM   #7
fenix-silver
Member#: 231700
2004 WRX Wagon
If you look around the forums you should be able to find some highly rated tuners. FYI, I have similar mods as you and I was pretty much maxing out the stock injectors, so you may want to upgrade to some higher flowing ones (the 565cc injectors from the later WRX/STIs are pretty cheap used). Also, an EBCS would be a decent idea as well since it is better at controlling boost. I run about 20 PSI on my TD04.
Old 08-04-2015, 10:42 AM   #8
Bahaa425
Member#: 384641
I would totally consider bigger injectors if I thought that'd help, but from looking at my learning view it seems it's removing fuel because there is too much.
Old 08-04-2015, 03:35 PM   #9
fenix-silver
Member#: 231700
2004 WRX Wagon
Injectors have nothing to do with what you are seeing in LV. If you have the 440cc injectors in there now, once you get a good tune, you will likely be pushing the limits of them. For reference, I was hitting 105% duty cycle on my stock injectors. Not a great place to be.
