Old 05-15-2012, 12:05 PM   #26
HonduhPowa
Member#: 269076
2012 Wrx
Originally Posted by trev762
It isn't your waste gate cuz your waste is to regulate boost under wot throttle. Most likely would be your heat shield or shifter linkage rattling does it sound like metal on metal or something else if u could record the sound and post it we would be able to help u out alot better
I just posted a video above you reply lol
It sounds like a putting sound like a leak, I thought maybe the wastegate arm is loose causing the flapper to "flap"
HonduhPowa is offline   Reply With Quote
Old 05-15-2012, 12:39 PM   #27
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Yes seen it just after I posted lol but cant really distinguish an unfamiliar sound besides sounding like a go pro lol. Even if your waste gate arm was loose wouldn't cause that bc its spring loaded and if anything wouldn't open properly. Check your hangar bearing make sure it isn't a little loose and I mean little cuz if it was loose u would sure as **** know it
trev762 is offline   Reply With Quote
Old 05-15-2012, 12:48 PM   #28
tudball13
Member#: 285973
2008 WRX
black
I've got the same sound too. It started after I put my DP on I took it to my tuner and he said its my wastegate and not to worry.
tudball13 is offline   Reply With Quote
Old 05-15-2012, 01:44 PM   #29
Andrewxxcarlson
Member#: 316415
2006 WRX
Originally Posted by 06AspenWhite
Its probably the wastegate fluttering.. Pretty common I hear
This ^^^ mine does the same, I can mostly hear it when I'm drivin next to a median with the window down.
Andrewxxcarlson is offline   Reply With Quote
Old 05-15-2012, 02:50 PM   #30
HonduhPowa
Member#: 269076
2012 Wrx
That's exactly when I hear it, passing walls or other cars, or when takin off from a stop. It's only under low rpm.
If you watch the video I posted you can hear it when I take off from the light. You could hear it more before I uploaded to YouTube
Old 05-15-2012, 08:34 PM   #31
bluepearlrex12
Member#: 310184
2012 WRX
Blue Pearl
I have this same issue. I just installed invidia dp and catback. It sounds like an exhaust leak at low rpm but then starts to whistle and flutter under boost. Almost like a baby EWG lol if that makes sense. All gaskets are new and not leaking. Figured it was from the bigger dp. Idk but it drives me insane.
bluepearlrex12 is offline   Reply With Quote
Old 05-15-2012, 08:49 PM   #32
Ernest
Member#: 45076
2004 Stg2 Wagon 4eat
Got the same sound since stage 2. Wastegate flutter. I thought I had a leak checked everything no leaks.
Ernest is offline   Reply With Quote
Old 05-15-2012, 10:10 PM   #33
HonduhPowa
Member#: 269076
2012 Wrx
I'm very close to ordering new exhaust manifold and up pipe gaskets but this makes me worry I'll waste money lol.
There has to be a way to fix the sound, I've never heard another wrx with the sound I have.
Old 05-15-2012, 10:12 PM   #34
HonduhPowa
Member#: 269076
2012 Wrx
It does kind of sound like a baby Ewg haha, drives me bonkers!!
My tuner buddy said its probably caused by the open downpipe and small turbine that spins so easily. He said if I got a bigger turbo the sound should disappear but I say it's an exhaust leak..
Old 05-15-2012, 10:45 PM   #35
stephens
Member#: 124581
To be honest, I can't hear anything "abnormal". Throw your OEM downpipe on and see if the same sound appears. If you don't hear the same sound then I would suggest leaving the stock pipe on and sticking with it.
stephens is offline   Reply With Quote
Old 05-16-2012, 12:52 AM   #36
HonduhPowa
Member#: 269076
2012 Wrx
I don't have the stock downpipe and I'm cobb dyno tuned on my setup so I'm not removing parts
Old 05-16-2012, 03:50 AM   #37
Andrewxxcarlson
Member#: 316415
2006 WRX
Yea man! I heard! But it hasn't really bugged me yet! Hopefully it doesn't get to that point!
Old 05-16-2012, 05:09 PM   #38
9-2 wrx
Member#: 225759
2006 Saab 9-2X Aero
What turbo is everyone who is having this problem running? TD04?
After I installed a Cobb Catted Downpipe I had a tiny exhaust leak that drove me crazy. When I upgraded to a VF39 I found the source of the leak; the downpipe and TD04 don't line up exactly and there is a small point on the bottom right corner where the gasket doesn't get properly sandwiched and you end up with a tiny exhaust leak. Everything lined up perfectly on the VF39 and no more exhaust leak!
9-2 wrx is offline   Reply With Quote
Old 05-16-2012, 07:09 PM   #39
HonduhPowa
Member#: 269076
2012 Wrx
Yeah this is with a td04 and 4" TurboXS downpipe.
Old 05-16-2012, 10:07 PM   #40
bluepearlrex12
Member#: 310184
2012 WRX
Blue Pearl
I have vf52-INVIDIA DP. I am 99% positive I do not have an exhaust leak. I Have been wrenching for years now and know how to install/diagnosis a leak. I kinda like it. Kinda whistles and shhshhshh hahah. Datalogs are solid, and car runs great. So for now I don't care.
Old 05-16-2012, 11:55 PM   #41
HonduhPowa
Member#: 269076
2012 Wrx
We're not talking about the turbo whistling and spooling sound.
Old 05-17-2012, 12:35 PM   #42
9-2 wrx
Member#: 225759
2006 Saab 9-2X Aero
Here are some pics that show it perfectly. This is a brand new OEM gasket.
This is the VF39 turbo. Notice the gasket opening is larger than the turbo flange ensuring a good seal.
Now the TD04. Notice in the bottom right corner that the turbo flange is larger than the gasket opening and if that pinched steel ring doesn't get crushed just right you will have a small leak.
Old 06-07-2012, 10:07 AM   #43
HonduhPowa
Member#: 269076
2012 Wrx
Well I replaced my giant 4" turboxs downpipe with an invidia v2 downpipe, and replaced my up-pipe to turbo gasket as well and the exhaust leak sound I was experiencing is virtually gone!
Old 06-13-2012, 12:35 AM   #44
aepilot
Member#: 318713
I will go record that I'm experiencing this sound and it has gotten me going crazy trying to figure it out. I'm glad I found this in the search results. I just installed a cobb catted dp on my '07 wrx and like everyone is saying the sound only occurs low rpm's. On my factory installed boost gauge the flutter is prominent right before it hits 0. I installed a grimmspeed gasket with the dp check for leaks and nothing.
Honduh... I'll look into getting a gasket for my UP to turbo. Hopefully that'll help.
aepilot is offline   Reply With Quote
Old 06-16-2012, 10:42 AM   #45
08fg2
Member#: 281219
2012 wrx hatchback
satin white pearl
I have the same noise on my 2012!! Invidia catless dp q300 exhaust. Noticed it about 2-3 months after putting on the mods when I put my windows down. Scared me at first. Anyways here is my video...
Do is it really just gaskets??
08fg2 is offline   Reply With Quote
Old 06-16-2012, 12:11 PM   #46
aepilot
Member#: 318713
^^^ I haven't touch the UP, so I'm sure if it is that or not. I had my car over at TiC last night and they said it was fine. I don't know
Old 06-16-2012, 02:53 PM   #47
08fg2
Member#: 281219
2012 wrx hatchback
satin white pearl
Just like op said the noise is only present on lower rpms above 3k it just fades away...
Old 06-16-2012, 03:51 PM   #48
chachas
Member#: 306733
2016 Forester 6MT
I've got the same sound on my 2007 WRX, stage 2 protune, invidia catted DP. I was concerned when I noticed the sound, so I brought it to my tuner and we took a spin around the block. He said it's normal, nothing to be concerned about, just the wastegate flapping a little.
chachas is offline   Reply With Quote
Old 06-19-2012, 11:48 AM   #49
aepilot
Member#: 318713
08fg2- That's the same case here. Let me know if you figure anything out.
chachas- I had my my suspension put in last week over at TiC. Went for a drive to test everything out and they said the same thing.
Old 06-19-2012, 11:59 AM   #50
08fg2
Member#: 281219
2012 wrx hatchback
satin white pearl
I'll be taking a closer look this coming weekend. Taking things off and looking for something...
sub is broken? or its normal silver-RS Car Audio, Video & Security 1 11-16-2006 08:02 AM
Exhaust leak? Or am I paranoid BurtonCR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-16-2004 09:32 AM
Exhaust Leak or Blown turbo?? ScreaminFast Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 09-16-2003 02:39 PM
Exhaust leak or paranoid? turboICE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-13-2003 12:05 AM
Exhaust leak or what? lestion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-14-2002 12:26 AM
