Old 07-16-2002, 08:09 AM   #1
allwheeldrive
Member#: 14800
2000 2.5RS--->VQ35
Default Amsoil VS K&N
i dont know if this is the right place for it but i just wanted to know how is amsoil air filter compared to K&N who has the better air flow ?? and which one last longer ? can anyone tell me thanks
also i would like to know abought amsoil oil as well if anyone knows abought that too thanks
allwheeldrive is offline   Reply With Quote
Old 07-16-2002, 09:33 AM   #2
LordBass
Member#: 3266
2006 Jetta 2.0T 6MT
2009 Jamis Aurora Elite
IMO, both are basically equal, with the Amsoil being the preferred brand, tho I can't explain why. I believe the K&N is recommened for more-frequent recharges. I really like my Amsoil and would recommend it highly. My review is here.
A search of "Amsoil" and "K&N" in this forum should yield more info than you need. Don't spend much time on it, it's just a drop-in air filter.
lb
www.trancelab.com
LordBass is offline   Reply With Quote
Old 07-16-2002, 01:14 PM   #3
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
I've used both (but not in the same cars). It isn't going to make a lot of difference really...both are good. Like LordBass said one isn't going to be that much more effective vs the other...so I'd get the one you can get the cheapest.
NC
Reciprocity is offline   Reply With Quote
Old 07-17-2002, 08:58 AM   #4
allwheeldrive
Member#: 14800
2000 2.5RS--->VQ35
thanks for the post guys i think i'll go with the amsoil just coz of the lesser recharge save more money in the long run
Old 07-17-2002, 09:41 AM   #5
cakes25rs
Member#: 1024
2000 S2000
White/Red
amsoil needs to be cleaned and reoiled once a year or every 25000 miles, which reminds me.
k&n needs "recharging" every 10k i believe.
cakes25rs is offline   Reply With Quote
Old 07-17-2002, 11:05 AM   #6
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
The amsoil made a huge difference in my wifes car (02 Sentra SE-R). I like the fact you need to recharge it way less, and the filter seems more durable in general.
DanzBorin is offline   Reply With Quote
Old 07-17-2002, 06:30 PM   #7
PeterJ
Member#: 14727
2002 impreza RS
Default question
I just installed an Amsoil and was told that it would get clogged really quick, since I usually drive in really dusty conditions... the person said that if you were to stretch out a paper filter and compare that surface area to the "random" pores in the spunge-like Amsoil, the K&N and stock filters would be superior. Sounds like a fair argument, but my stocker was caked black to the point where I could hear and feel the engine choking after just 8K miles. Anyway, he never specifically researched air filtration either. I change my oil every 2K, so I guess I might have to clean the Amsoil as well. We'll find out. I say, go with what is more convienient for you.
By the way, beware of the small metal chips that are in the perforated sheet in the Amsoil. I found two on mine. Its dangerous since the metal side faces the throttle body.
PeterJ is offline   Reply With Quote
Old 07-17-2002, 11:37 PM   #8
DanzBorin
Member#: 7131
2015 Outback - Croc
Actually the amsoil filters better than K&N, and goes longer between charges...
Old 07-18-2002, 01:37 AM   #9
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
The oiled foam Amsoil filter actually performs well in dirty dusty conditions, and the more dirt it collects the better it filters dirt while still flowing well.
This is because while the holes in the foam are larger, the filter is deeper with more total potential dirt-collecting surface area, yet flow doesn't suffer when it collects dirt because of the size of the holes.
AMSOIL FILTERS
ImprezaRS dot com is offline   Reply With Quote
Old 07-23-2002, 01:34 PM   #10
BlkRexWagon
Member#: 20587
'02 WRX Wagon
Midnight Black
A good foam filter will almost always be better than a K&N, and Amsoil makes a terrific product. I have seen a few cars equipped with K&N filters with gunk starting to build up in the intake... I have yet to see that with an Amsoil but to be fair I have also seen a lot less cars with the Amsoil.
BlkRexWagon is offline   Reply With Quote
Amsoil vs Mobil 1: wow, what an improvement Amsoil is over M1 scooterforever Service & Maintenance 30 07-03-2007 09:43 AM
redline Vs. amsoil Vs. mobile1 OREnative Normally Aspirated Powertrain 8 10-19-2005 05:58 PM
Amsoil or K&N? CrazyMike13 Off-Topic 8 12-28-2003 05:01 PM
Amsoil vs. K&N mike270 Normally Aspirated Powertrain 2 05-10-2003 09:43 PM
K&N vs. Amsoil vs. ITG Yebisu69 Normally Aspirated Powertrain 4 01-04-2002 08:22 AM
