Old 06-17-2013, 01:50 PM   #251
colorfull
Member#: 136688
2005 Impreza RS
Fairy dust!
Originally Posted by Matt Monson View Post
colorfull is offline   Reply With Quote
Old 06-17-2013, 03:44 PM   #252
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Now that's what I call
*sunglasses*
Panning for gold.
Counterfit is online now   Reply With Quote
Old 06-20-2013, 12:15 PM   #253
PA-Outback2000
Member#: 161832
2000 Outback Limited
i was planning on +1mm valves, but is physically not possible on my heads. should be back next weekend!
PA-Outback2000 is offline   Reply With Quote
Old 06-21-2013, 01:28 PM   #254
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
your heads are just the SOHC ej25 variety yes? Because there are a couple oversized valve options available from delta cams and supertech. And I know that they fit...
Some other reason they won't work?
Zefy is online now   Reply With Quote
Old 06-21-2013, 04:13 PM   #255
PA-Outback2000
Member#: 161832
physically not possible most likely means no bigger valves would fit. the position of the valves within my heads is such that the exhaust valves have no room to go any bigger. i was told that the intake ones were fine, but there is no reason to do half of the valves. the 2000 year of legacys and outbacks were built using 5 or 6 different valve length sizes and 2 or 3 versions of heads. where mine are a pain, another model year may be better.
bigger valves weren't part of the original plan, but chose to pursue them since we were doing a valve job anyway. so, i am back to where i originally planned to be when i started this project.
Old 06-25-2013, 04:46 PM   #256
evilWagon
Member#: 128739
07 2.5i SE Wagon
.....and where's the dyno charts?
evilWagon is offline   Reply With Quote
Old 06-26-2013, 09:55 AM   #257
PA-Outback2000
Member#: 161832
car isn't done yet, so no dyno runs. i will post when i get them. hopefully in the next month or so i will have time to dyno it.
i will post my initial feel of the car when i get it back. should be interesting.
Old 06-27-2013, 03:34 PM   #258
evilWagon
Member#: 128739
07 2.5i SE Wagon
Arent you getting it tuned when you get the parts installed?....
Old 06-28-2013, 09:42 AM   #259
PA-Outback2000
Member#: 161832
road tuned. they don't have a chasis dyno.
Old 07-29-2013, 02:23 PM   #260
PA-Outback2000
Member#: 161832
cams are in and car is done!
there is definitely a noticeable difference in performance than before. don't forget... the car is now 13 years old and has 198k miles on it!
mod list for this upgrade:
xcceleration .445 cams
stronger springs
titanium retainers
new valve job, new OEM valves w/seals, and new valve guides
(also added stiffer front springs to the coilovers and perrin brake master cylinder brace)
Old 07-29-2013, 03:42 PM   #261
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Titanium springs? You sure you don't mean titanium retainers? The only use of titanium springs I've ever heard is no-holds-barred race engines (like Top fuel dragsters).
Old 07-29-2013, 04:04 PM   #262
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
"Notable difference in performance"="It lost so much power in the daily driving range that it now feels super-powerful on the top end when it finally comes on-cam where I can't use it"
Old 07-29-2013, 04:40 PM   #263
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
it has stronger retainers... pay attention...
Noticeable difference in performance eh? is your butt dyno SAE corrected or...?
seriously... when dyno...?
Old 07-31-2013, 09:28 AM   #264
PA-Outback2000
Member#: 161832
dyno will come. i may try to do it over the labor day holiday.
power in daily driving range is fine.
Old 08-05-2013, 02:58 PM   #265
PA-Outback2000
Member#: 161832
1 week update...
with 93 octane gas and the cams, i got 26mpg highway with the A/C blasting on the ride home from picking it up and around 18mpg city, mostly because i like how the car feels in 1st and 2nd gear.
i would guess that if i drive it normally, i would get around 20mpg city and maybe 28-30mpg highway without A/C on.
Old 11-28-2013, 09:46 AM   #266
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
Bump.
1 week update...
Also, those mileage figures are ridiculous...ly farcical.
tibug is offline   Reply With Quote
Scorpion cam. Cow cam. Coyote Cam. Frog cam. Jessie James Off-Topic 3 08-31-2009 01:50 PM
Cams, Cams, and More Cams impr25rs Normally Aspirated Powertrain 35 03-25-2008 08:31 PM
turbo cams or n/a cams flent Normally Aspirated Powertrain 19 04-02-2001 09:00 AM
Cams? Anybody put in race cams? RoscoePColetrain General Forum Archive 2 09-26-2000 03:09 PM
