Old 09-14-2011, 03:15 PM   #301
speedbagger
Member#: 289736
2016 WRX Base
Originally Posted by nhat View Post
attitudes like this are far more amusing than the hellaflush "fad"
offense taken to your mach v comment. he doesn't push people one way or another nor does he criticize others for their choices, all he does is offer help unlike many others.
never said he pushes people one way or the other and don't have an issue with what he's doing. in fact, if i was him i'd be doing the same thing. and if someone wants put a wheel/tire on with questionable or borderline fitment let'em.
however, unless you're on his jock or on his payroll it's pretty naive to think he's here just to 'offer help'. his job is to sell.
bringing up weight for a daily driver is laughable. .
thanks. i'll make a mental note of that gem of engineering advice.
please keep it to technical information and not opinion. if you want to voice your displeasure, go to member's car gallery. better yet, keep it to yourself.
i'd be glad to.....as soon as this thread moves here:
the style fitment thread: form > function
http://forums.nasioc.com/forums/show....php?t=2208775
speedbagger is offline   Reply With Quote
Old 09-14-2011, 06:52 PM   #302
AngryPanda
Member#: 253849
great write up!
AngryPanda is offline   Reply With Quote
Old 09-15-2011, 11:17 AM   #303
Mach V Dan
Member#: 12029
If I was just out to sell stuff, I'd spend a lot more time typing "Wednesday bump!" and a lot less time on this thread.
Originally Posted by AngryPanda View Post
great write up!
Thanks!
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 09-15-2011, 01:00 PM   #304
nhat
Member#: 140163
03 STi
hellaflunctional
Old 09-17-2011, 07:09 PM   #305
Stu_Gotti
Member#: 270392
2011 WRX Limited
WR Blue
Thanks Mach V! Here are some pics of the car cleaned up... 18x9.5" Rota D-Force +40 wrapped in 265/35/18 BF Goodrich G-Force's.
Stu_Gotti is offline   Reply With Quote
Old 09-18-2011, 04:12 AM   #306
jtc4313
Member#: 273611
2011 WRX Premium
Stu_Gotti looks good man! I'll be running the same setup next summer. Are you running the stock suspension? Have you had to roll the rears? Looks great!
jtc4313 is offline   Reply With Quote
Old 09-18-2011, 11:53 AM   #307
Stu_Gotti
Member#: 270392
2011 WRX Limited
WR Blue
Thanks!
Yes it's still, and probably will remain, stock suspension. The rear fenders were rolled and a great job was done with that as well.
Old 09-20-2011, 10:25 AM   #308
J_Maher_WRX
Member#: 290307
Originally Posted by Stu_Gotti View Post
Thanks!
Looks incredible man, im looking at getting the same wheels for my WRB wrx sedan, same car homie
With stock suspension tho have you found that you rub at all if you hit any hard bumps or push the car hard??
J_Maher_WRX is offline   Reply With Quote
Old 09-21-2011, 08:03 PM   #309
Stu_Gotti
Member#: 270392
2011 WRX Limited
WR Blue
No problems at all actually, I'm very pleased with Mach V's work and the wheel/tire combo I chose. Thanks for the comments, man!
Old 09-22-2011, 07:38 PM   #310
z-logic
Member#: 288551
2011 STI
White Sedan
What offset is recommended. 2011 sit yamaha black 18x9 for fender being flush.
Stock 245/40/18 for now with stock suspension. Eventually 255 or 265/35 with bc coil overs
G force, p45r, grid.
Thanks
z-logic is offline   Reply With Quote
Old 09-23-2011, 10:34 AM   #311
Mach V Dan
Member#: 12029
Stock 245/40/18 for now with stock suspension. Eventually 255 or 265/35 and BC coil overs.
Thanks
Okay, so now people are getting lazy. I'd like this thread to be a reference thread -- we can supply examples here of various sizes/offsets of wheels and tires, and future generations can look at this thread and decide what they want to do.
What I don't want is for this to be a "Ask Dr. Wheel Fitment" thread, where people just skip straight to the bottom and repeatedly ask the same questions. That doesn't make for an educational thread for posterity.
Read through the thread. There are many, many examples of 18" wheels on 2011 WRXs on here, all with complete data on tire size, wheel size, and wheel offset. The answers are in here.
--Dan
Mach V
FastWRX.com
Old 09-23-2011, 11:03 AM   #312
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
^ this is correct. Mach V FTW
smeerone is offline   Reply With Quote
Old 09-23-2011, 06:49 PM   #313
z-logic
Member#: 288551
2011 STI
White Sedan
I ordered p45r 18x9.5 in 30 offset. I hope I understood.
1.496" = 38mm offset
1.181" = 30mm offset
Old 09-25-2011, 05:15 AM   #314
_davin
Member#: 260501
2003 miata SE
Blurple
If I got a 1" lift kit for my car, but stuck with an 8" wheel and 245/40/18 tire, what is the lowest offset that you would be comfortable with? Assuming that I could pick any number. Also going out flush with the fender, do you think I could get away without rolling them if it was lifted?
_davin is offline   Reply With Quote
Old 09-25-2011, 05:29 AM   #315
sc00by4life
Member#: 97135
hold on. flush with the fender completely negates ride height when you want to run such a large tire.
Stick with something "proper" fitment, because when you get into taller tires they WILL bulge out from the wheel more (or have more "overhang" from the wheel).
Also - why are you doing 245/40's when you run a lift kit? why not get some 30" small truck tires. Hellaflush is obviously not what you are looking for.
Old 09-25-2011, 07:58 PM   #316
_davin
Member#: 260501
2003 miata SE
Blurple
Such a large tire? That is the stock sti tire size. I'm not planing on a lot of off-roading, just would like a little more clearance. I would also like the wheels to be a little more flush, and I figure if I was going to lift it anyways I could probably get away with a low offset without rolling the fenders.
Old 09-30-2011, 11:12 AM   #317
Mach V Dan
Member#: 12029
If you're not going to be doing a lot of off-roading, I wouldn't bother with the trouble of lifting the car. It's not as simple a proposition as just putting new springs on. Models like the Outback have a re-positioned steering rack, among other changes.
--Dan
Mach V
FastWRX.com
Old 09-30-2011, 01:59 PM   #318
_davin
Member#: 260501
2003 miata SE
Blurple
http://www.subtle-solutions.com/prod...roducts_id=105
This looks pretty simple.
I probably won't end up actually doing it but it's tempting. We'll see how this winter goes, if I manage to avoid cracking my bumper on a chunk of snow when it's -40.
Old 10-02-2011, 04:05 PM   #319
Dirtbiker6015
Member#: 296517
I have a 2002 impreza ts it's stock height nothing modified an I was wondering if 235x45-17 would fit without any issues. And if so what offset would I need?
Thanks mike-
Dirtbiker6015 is offline   Reply With Quote
Old 10-05-2011, 12:46 PM   #320
Mach V Dan
Member#: 12029
Thanks mike-
Please ask in another thread. This is about the 2011+ WRX.
--Dan
Mach V
FastWRX.com
Old 10-05-2011, 01:21 PM   #321
subezero
Member#: 207614
2008 WRX Hatch VF52d
SSM
please delete..cat hit the quick post button somehow.
subezero is offline   Reply With Quote
Old 10-05-2011, 06:04 PM   #322
shawzito
Member#: 296873
Hi -
I recently bought a 2011 WRX 5-door. I was wondering, for winter wheels, would it be ok to go with a +55 offset, or should i stick with a +53 offset for my winter wheels. My buddy has a set of wheels that will fit the WRX, but they're +55 offset.
Thanks!
-Aaron
shawzito is offline   Reply With Quote
Old 10-05-2011, 06:18 PM   #323
n2oiroc
Member#: 141952
03 11 wrx/13 brz
Originally Posted by shawzito View Post
Hi -
Thanks!
-Aaron
+/- a few mm either way doesnt matter. as long as they clear the calipers and suspension, slap them on!
n2oiroc is offline   Reply With Quote
Old 10-06-2011, 02:21 PM   #324
ajp11
Member#: 175821
2011 x5 diesel
All right, so bestbsize winter tire? Stock 2011 rims
ajp11 is offline   Reply With Quote
Old 10-06-2011, 04:07 PM   #325
_davin
Member#: 260501
2003 miata SE
Blurple
...stock tire size, 235/45.
I'm running 245/45, not much difference.
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 01:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 10:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 05:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 02:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 03:20 PM
