Old 04-04-2012, 01:49 PM   #676
dye.sti
Member#: 136297
2012 WRX
OBP w/ Red and Flat Black
Originally Posted by dye.sti View Post
anyway. Im looking to get 17x9 +42 offset Rota Grids can I run my stock 235/45 tires i have currently on my stock wheels without any issues, im currently stock suspension, maybe getting the epic engineering springs.
any help?
dye.sti is offline   Reply With Quote
Old 04-04-2012, 01:56 PM   #677
paterick
Member#: 305207
2012 WRX Sedan
if you're going from a 17x8 to a 17x9, I would consider at least a 245 tire size vs. the stock 235.
paterick is offline   Reply With Quote
Old 04-04-2012, 02:50 PM   #678
Annihilator817
Member#: 296742
'16 STI, '11 WRX,
'96 328i DSP
Originally Posted by kMethod View Post
Beautiful Wheels, were these the flat face, semi-concave or deep concave works???
Originally Posted by sc00by4life View Post
The face is based on width... You don't get to pick.
Nevertheless, it is still a valid question.
Annihilator817 is offline   Reply With Quote
Old 04-04-2012, 04:06 PM   #679
jordanc15
Member#: 276118
2011 WRX
Got my grids yesterday. 17x9 +42 and they look great. Fills the fender pretty nice but not enough to cause any rubbing. Im lowered on Tanabe DF210 springs and I have no fitment issues. The tire is the oem Dunlop SP01 (235/45/17). So its a slight stretch. I think if I have 255 they might need some rolling in the rear. My camber specs are Front:2.25 and Rear: 2.5 so if your using the factory settings these wheels will look a little more flush.
jordanc15 is offline   Reply With Quote
Old 04-04-2012, 04:43 PM   #680
rkjunior
Member#: 112220
2011 WRX 5DR Premium
Looks awesome. Looks like a 17x9 +42 with a 245 might be perfect for a nice fit without having to touch fenders?
rkjunior is offline   Reply With Quote
Old 04-04-2012, 05:10 PM   #681
jordanc15
Member#: 276118
2011 WRX
Ya especially if your not lowered.
Old 04-04-2012, 05:33 PM   #682
rkjunior
Member#: 112220
how'd you think they'd handle a slight lower? say RCE yellows.
Old 04-04-2012, 05:35 PM   #683
jordanc15
Member#: 276118
2011 WRX
What's the drop on them? My tanabes dropped it roughly 1in for reference by the way
Old 04-04-2012, 11:53 PM   #684
PearlRex11
Member#: 284420
2011 WRX Sedan
Could you post some pics from the side that are further away please. Im very interested in this setup.
PearlRex11 is offline   Reply With Quote
Old 04-05-2012, 02:10 AM   #685
jordanc15
Member#: 276118
2011 WRX
Sure thing. I'll take some tomorrow.
Old 04-05-2012, 03:33 AM   #686
C4pt Insano
Member#: 290990
2011 WRX Sedan
OK, so I've read most of the posts here and got a pretty good idea of what works for my 2011 WRX, but still have many lingering questions. I'm planning on purchasing some 18x8.5 Work wheels very soon but figured I'd make sure I have the whole picture before hand. The specs of my planned, and hopefully ideal, setup are 18x8.5 +47 and i wanted to put 255/35/18 Michelin Pilot Super Sports on them. I don't currently auto x or go to the track but would like to at some point while utilizing this street setup for the time being.
-Is there a better offset for ideal fitment and best steering feel, or is that fine?
-Are 8.5" width wheels too small for 255 width tires?...If not, is it more prone to spongy, less responsive steering/turn in or is it negligible?
Would a 9" wheel absolutely be better, and if so what offset would be ideal for that?
I like the idea of running 8.5" vs 9" because of less weight, a little more cushion over the sidewall on the 8.5" compared to the 9" spreading it out more (makes sense in my head at least), cost, possibly less chance of rubbing, and closer to stock offset choices.
-are these valid assessments?
My main concerns are- I really prefer not to roll the rears(at least at this time); best fitment for steering feel(i keep hearing wider=worse steering feel); and how harsh the 35 sidewall will be on the wheel and on my back compared to the stock 235/45/17 as i have no experience with anything more aggressive than stock. I don't want too little cushion on my wheels for when i hit a pothole on the crappy New England roads after the winter, so if anyone can comment on that it would be nice.
I will be on stock suspension for the foreseeable future but do plan on lowering eventually, most likely with some good coil overs (slight drop only 1"or so).
-If i get coil overs sooner will rolling likely be necessary?...with added camber?
I was also considering a 245/40/18 tire, only because of fitment (although I heard 255/35 are actually easier to fit because of their height) or ride comfort, which i would definitely run on an 8.5" wheel. But I like the idea of the 255 giving me better gearing and that extra grip. Any other tire suggestions are welcome, I'm primarily concerned with best wet/dry grip for daily driving, but tire wear and noise are a slight concern too, I'm just unfamiliar with which tires run wide/skinny and if they would affect fitment. So if anyone could clear up my questions so i can order wheels that would be super, thanks.
C4pt Insano is offline   Reply With Quote
Old 04-05-2012, 04:12 AM   #687
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
I think the steering feel isn't an issue. I was worried when I was putting on my 18x10 ET35 and 285/30/18's, but the steering is very light and responsive. I can do 3 point turns with 1 finger and honestly can't feel much difference between these and the 16x6.5 ET55 and 205/60/16's they replaced. Any offset that doesn't require rolling your fenders will be fine.
Also, remember that the sidewall thickness is related to the width of the tire and you can't just ask how a 35 sidewall will be. A 235/40/18 and a 265/35/18 both have a sidewall that is 3.7". The brand and model of tire will have more of an effect on how the tires ride and feel as a tire with soft sidewalls will have more give and feel smoother on rough roads. Tire pressure will also have a large impact on how the tires feel. I have tires with squishy sidewalls and I am currently running them at 43 psi front and 41 psi rear which decreased their ride comfort, but also increased their responsiveness.
bluescoobywagon is offline   Reply With Quote
Old 04-05-2012, 06:06 AM   #688
sc00by4life
Member#: 97135
A 255/35 is fine on an 8.5" wheel.
9" vs 8.5" wont effect that size much, meaning the sidewalks won't be too stretched or pinched. The "little more cushion" doesn't make sense. The tire is the same size, and the sidewall height is the same regardless of wheel width. Rubbing depends on offset. Picking a correct offset is based on a wheel width. Just because stock offset is 53 (or whatever) doesn't mean that is the optimal offset for every width wheel.
With an offset that high, you should not have to worry about needing to roll fenders. Getting coilovers doesn't mean you'll need to rolls especially with an offset that conservative. In fact, an offset that high will limit the amount of camber you are able to dial on stock suspension. Personally, for an 8.5" wheel I'd move closer to 40 than 50.
The "35" is a percentage, not a static number (a VERY common misconception....).
If those wheel fitments feel even remotely similar to you, then you obviously don't pay enough attention to how the car really feels.
You can 1-finger 3 point turn? That's power steering.
Old 04-05-2012, 01:52 PM   #689
jordanc15
Member#: 276118
2011 WRX
This what you wanted?
I think on SWP these would look soooo good.
Old 04-05-2012, 04:22 PM   #690
C4pt Insano
Member#: 290990
2011 WRX Sedan
Thanks, I'll just stick with an 8.5 than. Yea i wasn't sure if the wheel width made any difference in feel or if the width stretched or squished the sidewall up or down, thanks for clearing it up, like i said I've only had the stock size. The question about the "35" sidewall was just in reference to my choice of 255/35/18 tires, I understand it is a percentage and would vary as width increased/decreased. I was just looking for observations on how that tire compares with the stock tire as it has something like a 4.3" sidewall compared to the 3.7" or so on that tire, i would assume you would feel more of the road but was just wondering how noticeable it was.
Old 04-05-2012, 10:52 PM   #691
PearlRex11
Member#: 284420
2011 WRX Sedan
Looks sick man. I'm going to have to look into these.
Old 04-06-2012, 03:04 AM   #692
mrfunnni
Member#: 284187
thinking about running te37sl 5x100 18x9 +22 on my wrx, any thoughts? other then that im looking at works vs-xx's no idea on sizing yet for those
mrfunnni is offline   Reply With Quote
Old 04-06-2012, 10:35 AM   #693
honestabe
Member#: 261730
2011 WRX hatch
how wide do star specs run? I'm planning to buy the rota Ds 18x9.5 +40 offset and wrap them in either star specs or Extremecontact DW 265/35/18, I'm worried that the star specs might cause problems. I will be riding on Bilstein+RCE yellows.
honestabe is offline   Reply With Quote
Old 04-06-2012, 11:46 AM   #694
sc00by4life
Member#: 97135
1 size large. You'll already need to roll in the rear with that fitment, you *might* need to roll the front also since you're on yellows.
Old 04-06-2012, 02:21 PM   #695
FerdSimao
Member#: 280691
2012 WRX Ice Silver Sedan
Sorry for the questions guys, but everytime i search i find mixed opinions.
for a 2012 wrx on stock suspension will a 18x9.5 +40 with 255/35/18 be ok. i really dont want to roll my fenders..
i have heard many people say its ok, and others saying the offset is not good. or should i go with 18x8.5 +35 offset
I may or may no lower the car in the future (coilovers) but if i do i dont want too low, i already learned my lesson on lowering!!
any input will be much apprecciated.
thanx
FerdSimao is offline   Reply With Quote
Old 04-07-2012, 01:19 PM   #696
sc00by4life
Member#: 97135
thanx
If you want to avoid fender modification with no question, get a narrower wheel and higher offset.
Old 04-08-2012, 04:35 AM   #697
11redwrx
Member#: 315217
2011 Subaru WRX
Lightning Red
Cool
Originally Posted by bluescoobywagon View Post
FYI
285/30/18's on 18x10 ET35 will poke slightly on stock springs/camber:
Still to come - more camber, more pull, and more RCE Yellow.
more pics please. I like
11redwrx is offline   Reply With Quote
Old 04-08-2012, 11:38 PM   #698
bluescoobywagon
Member#: 14911
Not A Wagon!
I actually went out today and pulled the passenger fender more and flared it.
I had already done the driver's side on friday. I need to do a little cleanup in a few spots and I'm going to need to paint the lips when I'm done, but I'm very happy with how it's turning out. I don't want to mess with the front too much since it hasn't rubbed, but I'm not sure I like how it looks flared in the rear, but not the front.
Here are pics from before it was flared:
[/quote]
Front
Old 04-08-2012, 11:43 PM   #699
jordanc15
Member#: 276118
2011 WRX
I think there just to big. Im not a big fan of the pulled fender. Maybe its just me but I dont like poke. Maybe try getting an aftermarket alignment with more camber. That would bring the tops in a bit more
Old 04-09-2012, 12:03 AM   #700
PearlRex11
Member#: 284420
2011 WRX Sedan
Front[/quote]
That thing looks tough from the back. The front could use some imo. Keep it up!
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 12:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 09:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 04:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 01:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 02:20 PM
