Old 06-12-2012, 12:47 AM   #901
Dova
Member#: 315989
2012 WRX hatchback
Satin White Pearl
I might have missed it but are there any alignment specs I should follow after mounting a set of 265 or 275/35/18 18x9.5 38-44 et ? I'm not planning to lower the car. Thanks
Dova is offline   Reply With Quote
Old 06-12-2012, 10:58 AM   #902
Mach V Dan
Member#: 12029
You should use factory alignment settings (or something close to them) if possible, for best long-term tire wear. In my opinion, running crazy alignment settings just for the purpose of tire fitment is a mistake.
Originally Posted by D0uglassss
for a 2012 wrx im looking to keep the stock suspesention which size and tire combo woulld would you recommend. I dont really want to roll or pull the fenders.
17x8 +45 or 17x9 +35
17x8 +45, with a 235/45R17 tire. If you want to run a wider tire, a 17x9 wheel is good with something like a 255/40R17, but at a higher offset. +35 is too low.
Please, please take the time to read through the thread before posting new questions like this. Many of these questions have now been answered multiple times.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 06-13-2012, 06:48 AM   #903
Subbie-2011
Member#: 301149
2011 STI Limited DMG
DMG
Couple quick questions. Looking for people with first hand experience for correct fitment. Widest rim and tire that fits on an 11 STI WITHOUT any suspension or fender modification. Just a straight swap of stock wheels. Thanks!!
Subbie-2011 is offline   Reply With Quote
Old 06-13-2012, 11:01 AM   #904
Improbus
Member#: 278439
2011 WRX 306HP/333TQ
Wingless Sedan OBP
Dan do you guys still have the Rota D 18x9.5 5x100 +40 in Flat Black in stock? I have a 2011 WRX OPB lowered on BC BR's with about a 1 finger gap and now the wheel wells are kind of swallowing the 17x8's so I'd like to stuff some meat under there. Do they come with the flat centercaps? I'm not a fan of the raised centercaps. I am trying to stay at a +40 or better offset with a 9-9.5" rim so there is little difference in suspension center line and null turn in while at the same time filling the well and bringing the wheel farther out for aesthetic purposes. The D's look like they would be a good choice. Let me know. Great thread.
Improbus is offline   Reply With Quote
Old 06-13-2012, 08:19 PM   #905
honestabe
Member#: 261730
2011 WRX hatch
I didn't see this anywhere in this thread so I wanted to ask you about hub-centric rings. I'm looking at 18x9.5 + 40 NT-03s which have a bore diameter of 73mm. You've stated the wrx has a diam of 56.1mm. Do you suggest using rings on a pure DD? Why or why not?
honestabe is offline   Reply With Quote
Old 06-13-2012, 10:32 PM   #906
CopperTopNWOR
Member#: 295724
2013 BRZ Limited
Yes use hub centric rings.
CopperTopNWOR is online now   Reply With Quote
Old 06-13-2012, 11:17 PM   #907
FerdSimao
Member#: 280691
2012 WRX Ice Silver Sedan
Ok sorry guys cell pics is all i got now!!! but i know some people asked to see the pics.
and keep in mind i have 4 wheels and tires in the back..
work emotion xd9 18x9+38 on 265/35/18 sotck suspension til next week, stock fenders til next week as well..
FerdSimao is offline   Reply With Quote
Old 06-15-2012, 01:56 PM   #908
Mach V Dan
Member#: 12029
Yes.
Yes.
--Dan
Mach V
FastWRX.com
Old 06-16-2012, 03:45 PM   #909
FabCruz
Member#: 299797
2012 STi Sedan
just wondering in Work Emotions XD9 18x9 +20 would fit 2012 STi sedan.
Can i get by with just a fender roll?
FabCruz is offline   Reply With Quote
Old 06-16-2012, 03:52 PM   #910
sc00by4life
Member#: 97135
depends on tire size. don't expect to run much more than a 235/40.
You'll also need some form of camber control f+r.
Old 06-16-2012, 05:08 PM   #911
dye.sti
Member#: 136297
2012 WRX
OBP w/ Red and Flat Black
Went with 17x9 +42 flat black rota grids using the stock wrx 235/45 tires and it came out looking great dropped on epic engineering springs.
dye.sti is offline   Reply With Quote
Old 06-16-2012, 05:42 PM   #912
J_Maher_WRX
Member#: 290307
Armor all Tire shine is your friend
J_Maher_WRX is offline   Reply With Quote
Old 06-16-2012, 09:34 PM   #913
sabruns02
Member#: 260014
2010 Wrx Premium
White Pearl
Just ordered some hub rings and locking lugs from you Dan
Ill be in this thread this week, 18x9.5 +38 11r flat black, 265/35 on a PBP sti sedan
sabruns02 is offline   Reply With Quote
Old 06-17-2012, 06:58 AM   #914
Tack762
Member#: 261845
2011 WRX
Silver EFI logics stg 2
LOL was thinking the same thing.
Tack762 is offline   Reply With Quote
Old 06-17-2012, 07:16 AM   #915
Tack762
Member#: 261845
2011 WRX
After reading this thread I think this setup will be golden as I will not have any rubbing issues......I hope. 2011 wrx 5 door.
-Whiteline rear swaybar / Kartboy endlinks (Nothing to do with tire clearance)
-Swift sport springs - 0.6 inch drop
-17x9 +35 enkei RPF1s
-245/40/17 Dunlop Direct Stars
Old 06-17-2012, 12:18 PM   #916
sc00by4life
Member#: 97135
You will probably need to roll the rears.
Old 06-17-2012, 01:08 PM   #917
Nawratil
Member#: 306659
2012 Impreza WRX
Obsidean Black Pearl
^not with that offset
Nawratil is offline   Reply With Quote
Old 06-18-2012, 10:53 AM   #918
TKNPODsTi
Member#: 247519
2012 STI
I'll add my recently installed set up on 2012 STi:
19x9.5 +45 Volk ce28n bronze w/ 265/35 mich super sports.
Mach V crew did the install. Right now stock suspension. First, these wheels did not clear the front brembos. Required a 10mm spacer up front. None in back. No roll yet but it does rub with people in back or real hard dips in the road. Bc of the spacers had to get extended studs up front.
Going to have Mach install swift springs and rear fender roll this week. Even with the 19s there is still wheel gap. Dan took some pics of the original install I'll get pics up shortly. Bring on the 19 haters. I think they look great.
TKNPODsTi is offline   Reply With Quote
Old 06-18-2012, 10:56 AM   #919
J_Maher_WRX
Member#: 290307
May look great, have fun having slower acceleration and worse braking distances :P
Old 06-18-2012, 04:23 PM   #920
TKNPODsTi
Member#: 247519
2012 STI
Cool broski
Old 06-18-2012, 08:51 PM   #921
sabruns02
Member#: 260014
2010 Wrx Premium
White Pearl
18x9.5 +38 work emotion 11r and 265/35 bridgestones. tein flex coilovers.
Old 06-19-2012, 01:13 AM   #922
neth
Member#: 323242
2012 sti
ice silver
2012 sti hatch, daily driver in rainy Seattle. I'm shooting for reasonably stock handling but a bit more flush look would be nice. I really like advan rg-d's but saw in earlier posts in this thread that 18x9+45 don't clear the break calipers. With stock tires, how do the fitment issues of the 18x9+35 compare to the handling of 18x9+45 with 5mm spacers for these wheels?
neth is offline   Reply With Quote
Old 06-19-2012, 03:09 PM   #923
C4pt Insano
Member#: 290990
2011 WRX Sedan
Alright so I just got my wheels but didn't order from tirerack or anything so I didn't get tires at the same time...so where are you guys getting tires mounted? because no place around here (western ma) will touch them. Thanks.
C4pt Insano is offline   Reply With Quote
Old 06-19-2012, 03:38 PM   #924
Mach V Dan
Member#: 12029
Originally Posted by TKNPODsTi View Post
Cool broski
Okay, these posts do not have anything to do with the topic. The topic is what wheels fit on the 2011+ WRX. Please refrain from posting about other topics here!
Plus, for the record, the 19x9.5 CE-28N weighs 19 pounds -- 1.5 pounds lighter than the factory STI BBS wheel.
--Dan
Mach V
FastWRX.com
Old 06-19-2012, 09:09 PM   #925
animigan
Member#: 282967
2011 wrx ltd (5door)
My choice: Volk TE37SL 18x9 +45. Hot.
animigan is offline   Reply With Quote
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 12:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 09:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 04:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 01:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 02:20 PM
