Old 07-11-2012, 09:55 PM   #951
J_Maher_WRX
Member#: 290307
Originally Posted by joeyp
Read everything. couldnt find this set up. Will a 18x9.5 +38 RPF1 with 255/35/18 fit without rubbing on stock suspension? I plan on lowering the car later down the road but don't want to deal with rolling the fenders for the time being. or what a 245/40/18 be better? Thanks!!
You clearly haven't read a page of this thread.
J_Maher_WRX is offline   Reply With Quote
Old 07-12-2012, 04:54 AM   #952
Gregor91
Member#: 259434
2012 wrx sedan
SOLD :/
i guess i will add to the fitment! 18x8.5 +35 private akzents with 245/35/18 michelin pilot sports oh and on eibach pro kit springs! i did have to roll the rears due to the fat tire
Gregor91 is offline   Reply With Quote
Old 07-14-2012, 09:51 PM   #953
vikramaditya1986
Member#: 281606
2011 WRX
Hi Dan,
I have a 2011 WRX with fully stock suspension (for now), and I'm looking to get some 17" wheels for the summer, AutoX and maybe tracking. I'd rather not have my fenders rolled, and after bouncing around the thread I've figured I can get away with 17x9 rims (with at least a 35mm offset) running my OEM Dunlop 235/45/17s. I intend on using up the Dunlops and then putting on the widest tire I can on the 17x9 rim without rolled fenders. Assuming a 17x9 +35 rim, my math tells me the rim will stick out an extra ~31mm (1/2” from rim + 53-35 offset change). Will I (maybe) need to roll my fenders with this rim AND the following tires?:
a) OEM Dunlop 235/45/17s ?
b) brand-TBD 255/40/17s ?
c) 265-anything?
Also, I am planning suspension and brake upgrades in a couple of years (GTWORX/RCE or coilovers; Wilwood or used Brembo brakes), and I’d like to know if these will work with my above tire/rim choices without rolling fenders. FYI the rims I’m eyeing are the Rota IK-R and your own Mach V Awesome.
Thanks in advance for the info, and for this comprehensive (and HUUGE) thread. I referred to post #459 in particular for my question.
-Vik
vikramaditya1986 is offline   Reply With Quote
Old 07-15-2012, 09:00 PM   #954
Mach V Dan
Member#: 12029
Originally Posted by vikramaditya1986 View Post
Assuming a 17x9 +35 rim, my math tells me the rim will stick out an extra ~31mm (1/2 from rim + 53-35 offset change). Will I (maybe) need to roll my fenders with this rim AND the following tires?:
c) 265-anything?
Because of the low +35 offset, I think you'll have to roll with anything larger than 235/45R17, and you MIGHT have to roll even with the 235 once the car is lower. For an easier time fitting larger tires, get a higher offset wheel. (+42 would be better, hint, hint.)
--Dan
Mach V
FastWRX.com
Mach V Dan is online now   Reply With Quote
Old 07-15-2012, 10:28 PM   #955
vikramaditya1986
Member#: 281606
2011 WRX
Thank you Dan, I'll look for 17x9s with higher offsets and consider rolling my rear fenders next year. Just to confirm, I will NOT need to roll my fronts with a tire size less than 265-wide?
Old 07-15-2012, 11:38 PM   #956
rokjitt
Member#: 307331
2011 WRX
Here is my 2011 wrx w/ Rota MXR Hyper black 18x9.5 +38, 245/40 18
rokjitt is offline   Reply With Quote
Old 07-17-2012, 12:51 AM   #957
0BlueSTi4
Member#: 98955
2011 WRX Hatch
Nice rims... but just cant stop wondering that tires are too narrow for such wide wheels. You can run this wide tire on a stock rim - kinda defeats the purpose of having such a wide wheel.
0BlueSTi4 is offline   Reply With Quote
Old 07-17-2012, 09:50 AM   #958
g26er
Member#: 317770
2012 WRX
WR Blue
For the stretch. I prefer this over a meaty looking setup. Everyone's different.
g26er is offline   Reply With Quote
Old 07-17-2012, 02:48 PM   #959
zergling
Member#: 195573
2012 WRX
I think rokjitt's tires are the Dunlop SP600 that come stock with the 08+ STi's. So he's probably using it until its done, then move on to the tire size of his choice.
zergling is offline   Reply With Quote
Old 07-24-2012, 01:09 AM   #960
jacjac3
Member#: 268811
2011 WRX Base
I'm getting a set of RPF1 17x8.5 +40 along with 255/40/17. Should I just get th +30 offset or the +40 is fine? This will be my dedicated track set. I'm concerned about damaging my hubs and axle with my current heavy a$$ 18x9.5 +35 (rotas). Any thoughts? I also plan on getting brembos F/R.
Thank yoU!
jacjac3 is offline   Reply With Quote
Old 07-24-2012, 02:04 AM   #961
sc00by4life
Member#: 97135
18x9.5 rotas are actually fairly light considering their size.
and the +40 would be better.
Old 07-24-2012, 03:07 AM   #962
jacjac3
Member#: 268811
2011 WRX Base
thanks!
Old 07-24-2012, 12:41 PM   #963
Mach V Dan
Member#: 12029
Hmm. At +35, I can't say that for sure. 255 is probably safe.
--Dan
Mach V
FastWRX.com
Old 07-24-2012, 12:51 PM   #964
rymaggi
Member#: 253442
rymaggi is offline   Reply With Quote
Old 07-24-2012, 06:02 PM   #965
trife86
Member#: 301368
2012 WRX
PBP
Wheels from 2008-2009 wrx will fit a 2011+ correct? I tried searching but mobile app doesn't like it.... I am pretty sure they fit but not 100%
trife86 is offline   Reply With Quote
Old 07-24-2012, 06:22 PM   #966
sc00by4life
Member#: 97135
Yes45.
Old 07-25-2012, 02:58 PM   #967
trickuhhhloww
Member#: 326983
2012 wrx
peral white
Default xxr wheels
i have a 2012 wrx on h&r springs i wanna run xxr 527 18/9.5 +35 what tire should i run with that and how much do i have to roll the rear fender
trickuhhhloww is offline   Reply With Quote
Old 07-25-2012, 10:36 PM   #968
Gumby4Mayor
Member#: 295130
2011 WRX
This information is probably already well known but....
17x8 Drag dr-31 47 offset....265 star specs. Autox purposes only. Yes they fit, no they don't rub, yes they are "pinched"...and yes they perform great...for autox. people run Hoosier A6's 275 and 295 sizes without rubbing or issues as well.
I wouldn't recommend this setup for street or track use, although I am sure they would be fine for either, just not ideal. A 245 would probably be better for those needs on an 8" wheel. On a 9" wheel I would run a 265 all day long.
Gumby4Mayor is offline   Reply With Quote
Old 07-26-2012, 09:39 AM   #969
Mach V Dan
Member#: 12029
Right up above, a few posts back, Gregor91 reported that 18x8.5 +35 with 245/40R18 rubs in the rear and requires rolling. Ignoring differences in wheel width, the same tire at the same offset will give the same result. I would not run narrower than 245/40R18 on a 9.5" wheel, so it sounds like that's your tire, since wider would result in more rubbing. As to "how much rolling," rolling is pretty much all or nothing -- you roll the rear lip and it's done, there's not a more or less. Some people talk about "pulling" the fender for more clearance, which is more drastic and usually results in dimpled or wrinkled body work.
--Dan
Mach V
FastWRX.com
Old 07-26-2012, 10:59 AM   #970
trickuhhhloww
Member#: 326983
2012 wrx
peral white
--Dan
Mach V
FastWRX.com
so say i get 18x8.5 +35 and put a 235/40 it shouldnt rub th e rear
Old 07-26-2012, 11:01 AM   #971
trickuhhhloww
Member#: 326983
2012 wrx
peral white
what tire size would u say to run without rubing the rear fender
Old 07-26-2012, 12:31 PM   #972
trickuhhhloww
Member#: 326983
2012 wrx
peral white
Default Xxr
I have 2012 wrx with xxr 527 18x8.5 +35 Woth h&r springs what tire size could I run without rolling my fenders
Old 07-27-2012, 09:54 AM   #973
honestabe
Member#: 261730
2011 WRX hatch
Wheels: Enkei NT-03, 18x9.5 +40mm 5x100, Flat black
Tires: Michelin Pilot Super Sports 265/35/18
Fender Mods: Roll all around (suggested by IAG)
Suspension: Stock (will be on Feal 441's in a week, approx 1-2" drop)
I really hope the roll I have will be sufficient when I install the coilovers.
honestabe is online now   Reply With Quote
Old 07-27-2012, 01:50 PM   #974
PearlRex11
Member#: 284420
2011 WRX Sedan
That^ looks really good for stock suspension.
PearlRex11 is offline   Reply With Quote
Old 07-30-2012, 10:45 AM   #975
jorge0886
Member#: 269257
2011 STI Limited
yea that does look really good. I would like to do the same but I don't want to roll the fenders
jorge0886 is offline   Reply With Quote
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 12:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 09:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 04:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 01:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 02:20 PM
