Old 08-10-2012, 10:05 AM   #1001
Improbus
Member#: 278439
2011 WRX 306HP/333TQ
1997 Legacy Outback EJ25
Ok I think I have made a decision and I just want to triple check everything here. I've read the thread multiple times and I think the setup below will fit no problem.
Wheels: ROTA Grid 18x9.5" +38 Hyper Black
Tires: Sumitomo HTR ZIII 245/40R18 (I know this is a little stretch but I am ok with that)
Lugs: Muteki SR48 Open Ended Lug Nuts 12x1.25mm Thread Pitch Black
Suspension: I have the BC BR Coilovers with a 1 finger gap.
Now here is the real question. Based on other people in this thread I should be good with just a roll in the rears but I was reading some other sources that said a roll and pull might be needed on all four corners. Can anyone comment on this?
Improbus is offline   Reply With Quote
Old 08-10-2012, 06:21 PM   #1002
jaydee818
Member#: 328225
Does anyone know a good brand for Black Chrome rims that are affordable?
jaydee818 is offline   Reply With Quote
Old 08-10-2012, 06:37 PM   #1003
sc00by4life
Member#: 97135
Even if lowered, you should be fine with a rear roll, if that.
This ain't the thread for that. Google, members
Car gallery, etc.
Old 08-13-2012, 11:52 PM   #1004
EmWhyit
Member#: 317576
2012 Sedan STI
I am looking at the Rota D's 18X9.5" +40 flat black. Tire size will be 265/40/18. As for suspension I have Eibach Pro-Plus kit (front and rear sways and Pro Kit spring which are about a 1" drop from stock. Part Number 7723.880). Will this setup work?
EmWhyit is offline   Reply With Quote
Old 08-13-2012, 11:54 PM   #1005
Jdub.csu
Member#: 283784
2013 EVO X GSR
Your def gonna roll the rears I can tell you that
Jdub.csu is offline   Reply With Quote
Old 08-14-2012, 08:06 AM   #1006
EmWhyit
Member#: 317576
2012 Sedan STI
Im a total noob when it comes to rims and tires... Is there a set-up for those rims that would work better? I dont mind rolling the fenders but i do want to avoid tire rub as much as possible.
Old 08-14-2012, 02:56 PM   #1007
Dka67
Member#: 296721
11 5door
Originally Posted by J_Maher_WRX
The OEM, 15 spoke gunmetal wheels on the 2011+ wrx is a 17x8 wheel, and has a 53mm stock offset. Putting that wider tire on the stock wheel is perfectly fine. The stock diameter of the OEM wheels + tire is 25.3". With that 255/40 wheel, you are actually at 25.0" diameter. It will fit fine with 0 issues fitment wise.
I was thinking the same. Would a 265/40 or 265/35 fit?
Dka67 is offline   Reply With Quote
Old 08-14-2012, 03:53 PM   #1008
Nawratil
Member#: 306659
2012 Impreza WRX
Obsidean Black Pearl
Could a 275/40 fit? Mustang guys do it sometimes I've heard...
Nawratil is offline   Reply With Quote
Old 08-14-2012, 04:14 PM   #1009
sc00by4life
Member#: 97135
On an 8" wheel will be extremely sloppy.
Old 08-14-2012, 04:27 PM   #1010
Dka67
Member#: 296721
11 5door
And as far as 265 on the 11 wrx own rim
Old 08-14-2012, 05:01 PM   #1011
sc00by4life
Member#: 97135
Same. I wouldn't go wider than a 245. Honestly, for DD'ing, there is absolutely no need for a 265+ tire.
Old 08-14-2012, 06:45 PM   #1012
Guz
Member#: 280109
2011 WRX
That's right my mustang had 265 in the 17x8 stock rims.
Guz is offline   Reply With Quote
Old 08-14-2012, 06:53 PM   #1013
Dka67
Member#: 296721
11 5door
Mustang? What thread is this?
Old 08-14-2012, 10:04 PM   #1014
animigan
Member#: 282967
2011 wrx ltd (5door)
Ok, more of the same:
18x8.5", +49 (SSR type C) - would this fit with a 265 tire with stock on suspension (without rolling rear fenders)?
animigan is offline   Reply With Quote
Old 08-14-2012, 10:05 PM   #1015
sc00by4life
Member#: 97135
You'll have problems with inboard clearance, as in running on the suspension.
Old 08-14-2012, 10:09 PM   #1016
animigan
Member#: 282967
^ So 255 would be the widest I could go...
Old 08-15-2012, 08:44 AM   #1017
dcorn
Member#: 107573
2012 WRX hatch
Ice Silver
265/35/18 is a great size for a 9 or 9.5" rim. I had 275/35's on my mustang and they fit great on a 9.5" rim with a slight bulge.
265/40 will be too much of a sidewall and look funny. I think M3's have that size on the back and they are bulky as hell.
Pretty sure no mustangs came with a 265 tire on a 17x8 wheel. 03 Cobra's had 275/40 on an 17x9" wheel, but when you go up to 18's, you want a bit less sidewall.
dcorn is offline   Reply With Quote
Old 08-15-2012, 09:21 AM   #1018
jhaddock07
Member#: 262954
2005 Super Slow STI
Edit wrong thread!
jhaddock07 is offline   Reply With Quote
Old 08-15-2012, 07:58 PM   #1019
Nawratil
Member#: 306659
2012 Impreza WRX
I wasn't saying they came with it, just that the mustang guys do put 265s and even 275s on the 17x8.
This is just the other end of the wrong fitment thing, bulge instead of stretching.. both hinder performance, some just prefer meaty rubber
Old 08-16-2012, 03:55 AM   #1020
jacjac3
Member#: 268811
2011 WRX Base
Anyone have 17x8 +42 offset on a 2011 wrx? I'm getting tc105n. Just wondering if that would be too flushed in.
jacjac3 is offline   Reply With Quote
Old 08-16-2012, 01:25 PM   #1021
cliff_11WRX
Member#: 275586
2011 WRX Sedan
290whp 340wtq Cali 91oct
that's the same size as the stock wrx wheels just 10mm lower offset. Yes it'll still be sunken in
cliff_11WRX is offline   Reply With Quote
Old 08-20-2012, 08:56 AM   #1022
Improbus
Member#: 278439
Thanks for the input man. Do you think Rear Camber Plates would be needed or should I be good without them? Also, Will any fender well modification need to be done to account for bump travel?
For Reference - 18x9.5" +38 245/40R18 1 Finger Gap all around.
Edit: Answered my own question. "Do you think Rear Camber Plates would be needed or should I be good without them? " Rear camber plates don't work on the new suspensions because they are double arm. The only way to have camber adjustments in the rear is adjustable control arms.
Old 08-20-2012, 01:03 PM   #1023
devil13
Member#: 80559
2011 WRX
Wheels: Work Emotion XD-9 18x9 +38
Tires: Pirelli P Zero Nero 245/40/18
Suspension: RCE Blacks and GTWORX/Bilstein Kit
Fenders: Stock
Camber: Stock
Rubbing: ZERO
devil13 is offline   Reply With Quote
Old 08-20-2012, 01:13 PM   #1024
rkjunior
Member#: 112220
2011 WRX 5DR Premium
nice setup, devil. that looks perfect. think you could get away with a 255 tire with still no rub?
rkjunior is offline   Reply With Quote
Old 08-20-2012, 01:54 PM   #1025
devil13
Member#: 80559
2011 WRX
It would be close.
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 12:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 09:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 04:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 01:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 02:20 PM
