Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 08-20-2012, 03:32 PM   #1026
rkjunior
Member#: 112220
2011 WRX 5DR Premium
how much tire stretch do you get with the 245's on the 9" tire?
rkjunior is offline   Reply With Quote
Old 08-20-2012, 03:39 PM   #1027
texascanuck
Member#: 317045
2012 WRX Hatchback
Originally Posted by jacjac3 View Post
Anyone have 17x8 +42 offset on a 2011 wrx? I'm getting tc105n. Just wondering if that would be too flushed in.
The stock WRX offset is 53mm. So your tc105n wheels would be pushed out by an extra 11 mm.
texascanuck is offline   Reply With Quote
Old 08-20-2012, 04:06 PM   #1028
texascanuck
Member#: 317045
2012 WRX Hatchback
Default 17x9, 5x100, 56.1 mm
Are there any available wheels that meet these specifications ????
17x9
5x100
56.1 bore
offset between +40 to +50 mm
weight < 22 lbs
in silver, gunmetal, or black
Its for a stock 2012 WRX hatch.
Old 08-20-2012, 04:34 PM   #1029
Improbus
Member#: 278439
2011 WRX 306HP/333TQ
Wingless Sedan OBP
17x9
5x100
56.1 bore
weight < 22 lbs
Mach V Awesome
this is about as close as you're gonna get.
Improbus is offline   Reply With Quote
Old 08-20-2012, 06:06 PM   #1030
devil13
Member#: 80559
2011 WRX
Some but not too bad. If you are worried about stretch then you should roll your rears and go with 265/35's.
Paul
devil13 is offline   Reply With Quote
Old 08-20-2012, 06:31 PM   #1031
texascanuck
Member#: 317045
2012 WRX Hatchback
Default bullseye
Originally Posted by Improbus View Post
Mach V Awesome
Improbus - thats not close, thats freaking dead on!
And those 5-spokes should make it easy to clean off the dust from the track pads!
Old 08-20-2012, 06:37 PM   #1032
ColdFyre
Member#: 297096
2011 WRX Limited 5dr
Satin White Pearl
Originally Posted by devil13 View Post
Wheels: Work Emotion XD-9 18x9 +38
Tires: Pirelli P Zero Nero 245/40/18
Suspension: RCE Blacks and GTWORX/Bilstein Kit
Fenders: Stock
Camber: Stock
Rubbing: ZERO
Devil, could you post some shots from the front and back?
Thanks!
ColdFyre is offline   Reply With Quote
Old 08-20-2012, 06:57 PM   #1033
sc00by4life
Member#: 97135
It really depends on the brand/model.
Feds and star specs will be pretty square (hell, 235/40 Feds are square on a 9" wheel) where others might be slightly stretches (Falken 512/yoko s.drive).
sc00by4life is online now   Reply With Quote
Old 08-20-2012, 10:26 PM   #1034
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
17x9
5x100
56.1 bore
weight < 22 lbs
You can also go with
Work Emotion CR-Kai
17x9" +44 5x100
60mm bore though.
Available in gunmetal or bronze.
gsrcrxsi is offline   Reply With Quote
Old 08-20-2012, 10:28 PM   #1035
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
What's the bore in the Mach V Awesome? Says it fits the STi and WRX. Doesn't the STi have larger hub bore?
Old 08-20-2012, 11:01 PM   #1036
sc00by4life
Member#: 97135
No. The sti has a larger pcd on the hub, but the bore remains the same.
Old 08-20-2012, 11:04 PM   #1037
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
pcd?
(more characters for reply limit)
Old 08-20-2012, 11:28 PM   #1038
sc00by4life
Member#: 97135
pcd?
Bolt circle.
Old 08-20-2012, 11:50 PM   #1039
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
i kind of figured that, just wondering what PCD stands for
Old 08-21-2012, 02:48 AM   #1040
sc00by4life
Member#: 97135
pitch circle diameter.
Old 08-21-2012, 07:50 AM   #1041
animigan
Member#: 282967
2011 wrx ltd (5door)
Who has run into problems with inboard clearance with their setup? If so, what setup?
animigan is offline   Reply With Quote
Old 08-21-2012, 10:56 AM   #1042
mightyatom
Member#: 250679
2011 wrx premium
grayer as the years go by
pulling the trigger on a set of enkei rijan's with star specs soon, 18x8 +45 offset... anyone with a '11 wrx running ss's on stock suspension??? was planning on 245(or255's)/40/18's and don't want to roll fenders (front or rear)...
mightyatom is offline   Reply With Quote
Old 08-21-2012, 11:03 AM   #1043
Improbus
Member#: 278439
Wingless Sedan OBP
Originally Posted by mightyatom View Post
pulling the trigger on a set of enkei rijan's with star specs soon... anyone with a '11 wrx running specs on stock suspension??? was planning on 245(or255's)/40/18's and don't want to roll fenders (front or rear) if possible...
We need some details if you want our best judgement. The wheel fitment gurus need wheel size, width and offset and then tire size. If you are talking about the 18x9.5" +35 5x114.3 won't fit your wrx without adapters for the PCD. If you are talking about the 18x8 +45 5x100 you are good to go with a 235 or 245 series tire no need to worry about rubbing on stock suspension.
Old 08-21-2012, 11:46 AM   #1044
texascanuck
Member#: 317045
2012 WRX Hatchback
From Yahoo:
PCD stands for pitch circle diameter and is the diameter of a circle drawn through the centre of your wheel's bolt holes. P.C.D. is measured in millimeters and also indicate the number of studs or bolts the wheel will have. For example, the WRX has 5 bolt holes drilled through the centre of an imaginary 100mm circle, or 5x100.
Old 08-21-2012, 12:19 PM   #1045
texascanuck
Member#: 317045
2012 WRX Hatchback
Work Emotion CR-Kai
17x9" +44 5x100
60mm bore though.
Very pretty wheels! But the 5x100 for the 17x9 size will be a custom pcd ... and that may be too much $$$.
Has anyone fitted a larger bore (60mm) to the WRX's smaller bore of 56.1mm??? Pros and cons? Anyone?
Old 08-21-2012, 12:23 PM   #1046
sc00by4life
Member#: 97135
There are plenty of those cr Kai's available in that size.
And yes - you need hub rings. Else the wheel won't center on the hub and can cause vibration at freeway speeds.
Old 08-21-2012, 01:05 PM   #1047
mightyatom
Member#: 250679
2011 wrx premium
post edited... i was referring to the rejin's in 18x8 +45 btw, so the SS's in 245/40/18's should be fine, is what I'm hearing.
Old 08-21-2012, 01:41 PM   #1048
Jdub.csu
Member#: 283784
2013 EVO X GSR
Federal tires? They run wide
Jdub.csu is offline   Reply With Quote
Old 08-21-2012, 02:00 PM   #1049
sc00by4life
Member#: 97135
Think he means star specs, which also run a bit wide.
Old 08-21-2012, 03:06 PM   #1050
mightyatom
Member#: 250679
2011 wrx premium
dunlop star specs... they tend to run a little beefier too though...
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 01:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 10:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 05:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 02:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 03:20 PM
