Old 08-21-2012, 02:08 PM   #1051
mightyatom
Member#: 250679
2011 wrx premium
grayer as the years go by
Originally Posted by sc00by4life View Post
Think he means star specs, which also run a bit wide.
yup, should have read that first
mightyatom is offline   Reply With Quote
Old 08-22-2012, 11:10 AM   #1052
animigan
Member#: 282967
2011 wrx ltd (5door)
Sorry to bring this fittment up again, but I'd like to hear what more people think of how close this will be:
te37sl 5x100 +45 on 255/35/18
Stock coilovers.
I know the diameter of the wheel/tire is 1.19% smaller than stock, it's more the fender rolling question and suspension clearance that I'm worried about.
animigan is offline   Reply With Quote
Old 08-22-2012, 11:14 AM   #1053
Jdub.csu
Member#: 283784
2013 EVO X GSR
Stock coilovers.
18 x what wheel? Details sheesh
Jdub.csu is offline   Reply With Quote
Old 08-22-2012, 11:21 AM   #1054
Improbus
Member#: 278439
2011 WRX 306HP/333TQ
1997 Legacy Outback EJ25
I believe that iteration of Volk's are 18x9 5x100 +45. At stock height with a 255 you might rub a bit in the rears but other than that you should be fine. If you go lower expect to roll the rears. The fronts should be fine.
Improbus is offline   Reply With Quote
Old 08-22-2012, 11:33 AM   #1055
Jdub.csu
Member#: 283784
2013 EVO X GSR
255 seems wide for a 9. Wouldn't a 245 be more suitable?
Old 08-22-2012, 11:35 AM   #1056
sc00by4life
Member#: 97135
not at all. you can run up to a 275 comfortably on that width (more fender mods required though :P).
Old 08-22-2012, 01:19 PM   #1057
animigan
Member#: 282967
Gaaah, yes sorry - 18x9". Had it in my first post, but overlooked it this time. I don't mind rolling the rears a bit if I have to, but was hoping to avoid it until I upgrade the suspension...
Old 08-22-2012, 01:55 PM   #1058
sc00by4life
Member#: 97135
1.) if you have to roll fenders, why does it matter if you do it before or after you get your suspension sorted?
2.) if you are scared of fender mods, stop looking at 9" wheels.
Old 08-22-2012, 09:48 PM   #1059
animigan
Member#: 282967
Too late - i'm looking at them. Why would I pay thousands of dollars to go 8.5" wide when stock is 8"?
Old 08-22-2012, 11:33 PM   #1060
mw1484
Member#: 239546
2011 WRX TP Stg2+AEM
Spark Silver Sedan
^Not a very good argument... There are lots of implications of going bigger... one being fender work, and another being camber. there are lots though...
mw1484 is offline   Reply With Quote
Old 08-23-2012, 01:35 AM   #1061
sc00by4life
Member#: 97135
This.
If you are NOT interested in doing fender mods, you flat out don't need wheels that wide. Besides, lets be realistic....anything over stock isn't needed for a daily anyways.
either way, if you are looking at 18x9 +45, even with 255's, it isn't all that bad. You'll probably need to roll if you went lower, but you should be OK at stock height - but be prepared to roll (even though you SHOULD be ok).
Old 08-23-2012, 09:50 AM   #1062
animigan
Member#: 282967
Thanks - i really appreciate the advice, especially this: "You'll probably need to roll if you went lower, but you should be OK at stock height - but be prepared to roll". I'll keep you posted!
Old 08-23-2012, 11:09 AM   #1063
Yoshii
Member#: 286384
I just got some 18x9.5 +38 with 265/35 ties as suggested. Rear fenders rolled but there's slight rubbing in the rear, is it cause I'm too low or should I be running a little more negative camber in the rears. Currently have around half a finger gap between wheel and fender on KWv3's.
Yoshii is offline   Reply With Quote
Old 08-23-2012, 11:30 AM   #1064
Jdub.csu
Member#: 283784
2013 EVO X GSR
Camber, and how much did you drop it?
Old 08-23-2012, 11:34 AM   #1065
Yoshii
Member#: 286384
Not real sure, but from ground to fender its about 24.5 inches
Old 08-23-2012, 01:13 PM   #1066
Subie_Noob_Brian
Member#: 288037
2015 LightingRed WRX
11' WRX sold**14' XV sold
Havent posted here in awhile and dont see too many pictures so here are some more to look at!
Wheels: Enkei NT-03 +M 18x9.5 +40
Tires: General G-Max AS-03 265/35-18
Suspension: BC BR coils slightly lowered
Fenders: Rear rolled
Camber: Front camber plates maxed. Rear non-adjusted.
Rubbing: Front rubs with really tights turns on a decent or bump.
Subie_Noob_Brian is offline   Reply With Quote
Old 08-23-2012, 02:07 PM   #1067
markanups
Member#: 259861
Have a Nice Day?
right now im really confused. according to this thread 18x9.5 et38 is best paired with 265/35r18 and with a small amount of fender roll it will avoid rubbing, i've read the entire thread but no results with that tire and wheel specs plus fender roll PLUS STOCK SUSPENSION. will those specs require me to get a stiffer/harder suspension? or it will be just fine with the fender roll only ?
markanups is offline   Reply With Quote
Old 08-23-2012, 02:28 PM   #1068
Subie_Noob_Brian
Member#: 288037
You should not rub with a good roll on normal driving.
Old 08-23-2012, 03:02 PM   #1069
Improbus
Member#: 278439
While its true not many of us run stock suspension here is how I look at it. If you do the roll yourself its free and who cares if it needs to be done. If a shop does it its only like $125 for a roll and refinish and they don't care if you roll a lot or a little. So if you are going to spend $2000 on wheels, tires, and lugs you might as well make the full commitment and get the rears rolled so in the future if you plan to go lower you are covered. If you are afraid of rolling period stick to the 8.5"-9" wide wheels with a 235/245 which is a stretch but it will save you from rolling on stock height.
Subie_Noob_Brian Enkei's look great man. I'm going with the chrome look on my OBP Sedan. I have some Titanium Chrome Grids in 18x9.5" +38 on the way
Old 08-23-2012, 03:23 PM   #1070
Subie_Noob_Brian
Member#: 288037
Reading his post it sounds like he plans to roll but stay stock suspension. With the floating stock springs he is still worried e might rub. Like I said I don't think he would with a good roll.
Thanks, I've never seen that color in grids. Should look nice!
Old 08-23-2012, 03:36 PM   #1071
Improbus
Member#: 278439
I think so too. I know the Grid Style is a little played out but I wanted something I could clean easily and with the 2011 Sedan having chrome accents, badges, and window trim I thought it would make the car pop nicely. The Black on Chrome is kind of a classic look but you don't see it on WRX's too much. Just something different.
Here is the color via Wheeldude:
Old 08-23-2012, 04:51 PM   #1072
markanups
Member#: 259861
yup im going to roll my fenders, another question whats the difference with 265 and 255? :-? 10mm?
Old 08-23-2012, 05:12 PM   #1073
sc00by4life
Member#: 97135
Depends on brand, but yes somewhere in that area.
Old 08-24-2012, 10:37 AM   #1074
texascanuck
Member#: 317045
2012 WRX Hatchback
Assuming 18 inch tires ... here are some comparisons:
For 265/35-18 (approx width of tire is 265)
sidewall height = 92.8 mm
diameter = 642.7 mm
For 255/35-18 (approx width of tire is 255)
sidewall = 89.3 mm
diameter = 635.7 mm
Stock WRX is 235/45-17
sidewall = 105.8 mm
diameter = 643.3 mm
Stock Sti is 245/40-18
sidewall = 98 mm
diameter = 653.2 mm
Of course, as mentioned, different tire brands will have slightly varying specs for the same tire size.
texascanuck is offline   Reply With Quote
Old 08-24-2012, 11:17 AM   #1075
markanups
Member#: 259861
alright! got it now thanks
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 12:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 09:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 04:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 01:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 02:20 PM
