Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 05-18-2011, 09:57 PM   #101
Vossatron
Member#: 276634
2011 4dr WRX
SSM Whale Tail
Originally Posted by nhat View Post
i don't know what they are but they're geared for OEM struts and i based it off that.
I havent put the springs on yet cause I am waiting to get koni yellow inserts. I got the springs before I realized that its highly advised to upgrade struts when doing springs. It also clearly states that H&R highly advises struts be upgraded. So how are these springs geared toward OEM?
Vossatron is offline   Reply With Quote
Old 05-18-2011, 10:44 PM   #102
sc00by4life
Member#: 97135
Hes talking about OEM springs being geared for OEM struts, aftermarket springs do not take the OEM struts into consideration.
Old 05-19-2011, 08:04 PM   #103
jpinto516
Member#: 260074
2011 WRX
Looking to fit 18X9.75 +20 on a stock body 2011 wrx planning on a bc coilover set up as well... do you guys think i will run into any issues
jpinto516 is offline   Reply With Quote
Old 05-19-2011, 08:21 PM   #104
RafCarre12
Member#: 274425
2011 WRX
white
are you planning on putting tires on them wheels?
RafCarre12 is offline   Reply With Quote
Old 05-19-2011, 08:24 PM   #105
nhat
Member#: 140163
03 STi
hellaflunctional
before posting again, please do some research.
Old 05-19-2011, 11:38 PM   #106
jpinto516
Member#: 260074
2011 WRX
i have been looking, its just i am not seeing anyone with 2011 with +20 offset on a 18X9.75 and i really don't know what would be the best tire size
Old 05-20-2011, 03:33 AM   #107
Fleet Admiral
Member#: 249156
11 SWP WRX Hatch
Cobb Stage 2
Use some common sense...
Originally Posted by Mach V Dan View Post
From experience, a 9.5" wide wheel will work at around +40 (give or take a couple of mm). The lower offset allows decent tire clearance on the inside. Steering feel is slightly worse from the lower offset, but it's not terrible. A 265/35R18 tire happens to be within 0.1% of the stock size, and that fits pretty well. (You may have to do minor fender rolling at the back if the car is lowered. It depends on the tire...not all 265/35R18 are created equal.)
Now look at what you selected (xxr, I'm sure.. shtty offset and random width). You're 20mm closer to the fender and a 1/4" wider... "Am I going to run into any problems?" LOL what do you think.
Fleet Admiral is offline   Reply With Quote
Old 05-20-2011, 09:58 AM   #108
Mach V Dan
Member#: 12029
This.
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
Old 05-22-2011, 04:03 PM   #109
builthatch
Member#: 185105
2009 C63 AMG
Palladium Silver
Eibach Pro-Kit R&D does - it is based on OE damper compatibility. that is a fact.
unless i am misunderstanding your post/point.
OP, this is a great thread. i'm glad i stumbled into it.
builthatch is offline   Reply With Quote
Old 05-25-2011, 10:59 PM   #110
IBREW
Member#: 281724
2011 WRX
Satin White Pearl
Just wondering but how wide of a tire could you fit on a 17x8 rim with a +45mm offset?
IBREW is offline   Reply With Quote
Old 05-27-2011, 11:15 AM   #111
Mach V Dan
Member#: 12029
You're going to be limited mostly by how much "bulge" you want to have. A 235 width is a good match for an 8" wide wheel. If you wanted to go with something wider, like a 255, it would start to look kind of plump on the wheel.
Here's a 255 on a an 18x8" +48 wheel:
That's not TOO bad, but I probably wouldn't go any wider.
Any of those widths will have no problems with clearing the suspension and fenders.
--Dan
Mach V
FastWRX.com
Old 05-27-2011, 01:13 PM   #112
_davin
Member#: 260501
2003 miata SE
Blurple
With a wider than recomended tire like that would it create some play when cornering, what I mean is there any performance downside to it?
_davin is offline   Reply With Quote
Old 05-28-2011, 08:45 AM   #113
Mach V Dan
Member#: 12029
Yes. If the tire is a lot bigger than the wheel, you can get some rolling under hard cornering, which can feel a little funny. You do get more grip at the limit, though. Some road racers and autocrossers squeeze very wide tires onto very narrow wheels because their rules restrict the wheel size, but not the tire size...
--Dan
Mach V
FastWRX.com
Old 05-30-2011, 01:09 PM   #114
lp87
Member#: 284237
2015 wrx
ism
Sorry if this question has been asked but I'm kind of confused on this topic. I have a 2011 wrx sedan and want to upgrade the wheels to 18x9 rota g force with a 35 offset. I also am installing epic lowering springs which lower the car 1.2-1.3 inches, do you all think the fenders should be rolled for me not to run into problems? Thanks for the writeup
lp87 is offline   Reply With Quote
Old 05-30-2011, 04:03 PM   #115
Midevil
Member#: 175065
2011 SWP WRX
INTERNET TOUGH GUYS? LOL
Yes, rear fenders definately.
Midevil is offline   Reply With Quote
Old 05-30-2011, 04:31 PM   #116
lp87
Member#: 284237
2015 wrx
ism
how much does fender rolling usually cost for the rears? The fronts wont need to be rolled?
Old 05-30-2011, 08:21 PM   #117
nhat
Member#: 140163
03 STi
hellaflunctional
find a local shop and ask how much they charge. that's not something we can answer.
if the fronts need to be rolled, he would have said so...
Old 05-30-2011, 10:27 PM   #118
TheBigBadYeti
Member#: 180503
2008 WRX 5 Door
Spark Silver Metallic
Ok, sorry to beat a dead horse but I want to get this right the first time.
Proposed wheel specs : Volk TE37Sl 18x9 +45.
I also plan on installing the gt worx/bilstein suspension and don't want to have to roll fenders. I was thinking a 255/35-18 would be an ideal tire size. Do you see any issues with this setup Dan?
TheBigBadYeti is offline   Reply With Quote
Old 05-31-2011, 09:06 AM   #119
nhat
Member#: 140163
03 STi
hellaflunctional
0 issues
Old 05-31-2011, 02:53 PM   #120
TheBigBadYeti
Member#: 180503
2008 WRX 5 Door
Awesome!
Old 05-31-2011, 03:29 PM   #121
lp87
Member#: 284237
2015 wrx
ism
if i upgrade my stock 2011 wrx's rims to 18x9 rota g forces with 225x40x18 federal ss595 tires will I need to re-calibrate my odometer and speedometer?
Old 05-31-2011, 03:46 PM   #122
nhat
Member#: 140163
03 STi
hellaflunctional
if you're worried about the speedometer and odometer, don't change the OD of your tires...
Old 05-31-2011, 04:07 PM   #123
Pandasex!
Member#: 258762
2009 Subaru impreza
Hi there what r the risk of running 225/45/18 up front and 235/45/18 rear will it really damage my awd on a 09 wrx sedan
Pandasex! is offline   Reply With Quote
Old 05-31-2011, 04:12 PM   #124
SCRAPPYDO
Member#: 873
2014 GLK/allroad
Datsun 71 240Z & 68 2000
You cannot be serious...
or are you....
SCRAPPYDO is offline   Reply With Quote
Old 05-31-2011, 04:18 PM   #125
lp87
Member#: 284237
2015 wrx
ism
how do i calculate whether my OD is changed or not?
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 12:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 09:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 04:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 01:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 02:20 PM
