Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 10-14-2012, 10:45 PM   #1226
sc00by4life
Member#: 97135
Originally Posted by johnmkv
by some work you mean a good roll? or hard pull? or you mean new lower control arms? and is this coming from personal experience with a wide setup like this?
suspension work is going to include coils, either Feal 441 or Fortune auto 500 series with swift springs and camber plates and bolts. With this set up and a mild drop would i be looking at more than 3 degrees?
You'll definitely need a roll, how much you have to pull depends on how much tire you want to run and how low you are. Same with the camber.
Get the feals. Those coils suck.
Old 10-15-2012, 08:03 PM   #1227
johnmkv
Member#: 300848
2012 WRX
LR
Thanks for the reply im wondering if anyone else has input about the 10 inch setup im looking at
And just to clarify in your opinion fortunes or feals are terrible???
johnmkv is offline   Reply With Quote
Old 10-15-2012, 09:21 PM   #1228
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
I think he meant the fortunes
Counterfit is online now   Reply With Quote
Old 10-15-2012, 09:58 PM   #1229
sc00by4life
Member#: 97135
there is no other input.
you got what you needed to know.
now search, there ARE cars running that same setup.
how much work you want to do is dependant on what type of setup you want to run.
Old 10-16-2012, 09:55 AM   #1230
motown
Member#: 308483
2013 WRX SWP HATCH
RIP 2011 WRX-SANDY VICTIM
Hey Guys Found A Guy On Craigslist W/ A Set Of 16" Steelies From A 2000 Outback. Will These Fit My 2011 Wrx? Couldnt Find Much Info On Here So Please Dont Yell.....
motown is offline   Reply With Quote
Old 10-16-2012, 01:02 PM   #1231
mw1484
Member#: 239546
2011 WRX TP Stg2+AEM
Spark Silver Sedan
yep, they're 5x100 too. You'll just wanna check offset to ensure they clear the brakes but I dont think it would be an issue.
mw1484 is offline   Reply With Quote
Old 10-17-2012, 06:19 PM   #1232
johnmkv
Member#: 300848
2012 WRX
LR
One more question anyone have an idea how much inner clearance we have?
Ohh and before i get flammed i know i could go and measure myself but its raining right now and dont feel like gettin wet was hoping for a quick anwser
Old 10-17-2012, 06:54 PM   #1233
High 0ctane
Member#: 158676
2010 STI
Alright a quick question.
I understand that a 10 inch wheel is a bit overkill and will need fender work as in roll but will pull be neccessary? I am specifically talking about the work xd9 18x10 38+ 3 inch lip... I know they make a 9 inch wheel that would fit no problem but i love the large lip and couldnt find any pictures showing the lip on the 9 ich wheels compared to 10 inch... Also about how much camber can i be expecting?
I was looking at that set-up too, but I'm pretty sure I read that you'll need a 15-20mm spacer to make those wheels clear the brakes. So essentially, you need to buy the 18x10 +18 if you don't want to run spacers.
High 0ctane is offline   Reply With Quote
Old 10-17-2012, 08:07 PM   #1234
jordanc15
Member#: 276118
2011 WRX
18x10 +18 won't fit very well. My wheels are 17x9 +17 and they poke a lot. Now account for an extra inch roughly a 12mm lower offset would essentially fit like if my wheels had a 5mm offset. Unless you plan on slamming it and are willing to run massive amounts of camber to make it fit they won't work. My tires clear the rear by about 1-2mm and that's with a 235/45 tire. I had front and rear fenders rolled with minimal pull. You could squeeze a few mm out of the fenders for sure but your going to need tiny tires to make those fit and they will look really odd if its not slammed.
jordanc15 is offline   Reply With Quote
Old 10-17-2012, 08:18 PM   #1235
johnmkv
Member#: 300848
2012 WRX
LR
The wheels are 38+ offset a bit easier to fit than 18+ dont you think so?
Old 10-17-2012, 08:50 PM   #1236
jordanc15
Member#: 276118
2011 WRX
Ya for sure. Ultimate fitment question now depends on the tire size you want. I really don't know what size to tell you as I've never had larger than a 9in wide wheel. I would guess a 245 or 255 should work since it will still be stretched on that 10 in wheel
Old 10-17-2012, 10:17 PM   #1237
sc00by4life
Member#: 97135
+38 you could run 245-255 easily, esp if you roll the rear.
+18...you need a 225/45 or 235/40 (MAX SIZE).
Old 10-17-2012, 10:23 PM   #1238
jordanc15
Member#: 276118
2011 WRX
Well there's a more confident answer for you! I didn't want to give you bad info but I guess I was right!
Old 10-18-2012, 09:25 AM   #1239
ONIBOY16
Member#: 334868
Hey I'm pretty new to the subi world, and I'm working on lowering my wagon and getting some wheels. It's a 02 wrx wagon and I'm wondering how wide a wheel I can go without having to do fender work
ONIBOY16 is offline   Reply With Quote
Old 10-18-2012, 11:50 AM   #1240
Mach V Dan
Member#: 12029
You have posted this in the thread that's specifically for 2011+ cars. This is the wrong thread for you.
I'd search this forum for "wagon," and read threads like this one.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 10-18-2012, 11:51 AM   #1241
dvrmstrng
Member#: 274717
2011 WRX TP Stg2+
2011 Wrx stock suspension and don't want to roll or pull...
18" wheel preferred in a 8" or 8.5" size.
What would be the preferred offsets for each of those sizes? (Would also like to keep a tire size as close to a 245/35 as possible)
dvrmstrng is offline   Reply With Quote
Old 10-18-2012, 12:12 PM   #1242
BarTmaN
Member#: 235650
2011 WRX
You guys think 17x9.5 +35 or if I go with XXR 17x9.75 +25 (not sure if these will be too much of a hassle to fit) wheels are too small for a good kinda aggressive stance on a 2011 wrx? I'm trying to decide what wheels to go with. Will be getting BC BR coils before anything. Just trying to figure my plan out!
I want it to be pretty low, but a pretty aggressive setup, not sunken in!
Or are 18" wheels a better option?
BarTmaN is online now   Reply With Quote
Old 10-18-2012, 12:48 PM   #1243
sc00by4life
Member#: 97135
save up for some better coils, and dont even bother with the XXR's.
both of those fitments will require a slight bit of work to fit, but you could fit slightly more tire with the 9.5 +35.
Old 10-18-2012, 04:53 PM   #1244
BarTmaN
Member#: 235650
2011 WRX
And 18x9.5 +38 would need some fender work as well, correct? Will a setup like that or the 17x9.5 +35 poke a lot?
Old 10-18-2012, 06:36 PM   #1245
jordanc15
Member#: 276118
2011 WRX
Define a lot. It would poke but in my eyes it look good with the right tire size. I love how my wheels poke
Old 10-18-2012, 07:30 PM   #1246
Tack762
Member#: 261845
2011 WRX
Silver EFI logics stg 2
What are your wheel and tire specs Jordan? Any pics?
Tack762 is offline   Reply With Quote
Old 10-18-2012, 07:54 PM   #1247
jordanc15
Member#: 276118
2011 WRX
17x9 +17 235/45/17. I'll get you a pic later today when I'm home
Old 10-18-2012, 09:15 PM   #1248
BarTmaN
Member#: 235650
2011 WRX
I want poke, but nothing crazy!
Old 10-18-2012, 09:15 PM   #1249
BarTmaN
Member#: 235650
2011 WRX
Yes, def take pics
Old 10-18-2012, 11:16 PM   #1250
Mach V Dan
Member#: 12029
+48 or higher should work great. I would do the 8.5" width, though. 245 is kind of chubby for an 8" wide wheel.
--Dan
Mach V
FastWRX.com
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 01:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 10:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 05:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 02:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 03:20 PM
