Tire & Wheel Forum sponsored by The Tire Rack |
12-06-2012, 08:39 AM | #1351 |
Member#: 302898
Vehicle:2008 Evo X Graphite Grey |
a 255/40 Tire would probably be the best. On stock suspension you should be fine.
12-06-2012, 11:22 AM | #1352 |
Member#: 321728
Vehicle:2011 WRX Limited DGM |
12-07-2012, 07:41 PM | #1353 |
Member#: 156526
NESIC
On Sunday I have to travel a few miles with 17x8 +32 and 235/45/17 tires... wondering if anyone knows if this will be a prob or not. Stock ride height.
12-07-2012, 08:31 PM | #1354 |
Member#: 283589
SCIC
Vehicle:2011 Impreza WRX Red |
^^^ your fine
12-08-2012, 09:32 AM | #1355 |
Member#: 156526
NESIC
Sweet, thx!
12-09-2012, 05:59 PM | #1356 |
Member#: 284237
Vehicle:2015 wrx ism |
this may have been answered but i can't find the answer to it. Do I need to run extended studs on my '11 wrx sedan if I run 5mm spacers all around?
12-09-2012, 06:44 PM | #1357 |
Member#: 276118
SCIC
Vehicle:1969 VW BUG Rust? |
I ran 5mm spacers without extended studs and I was fine. But really. It's always a good idea to have extended studs. I think people say 5mm is the biggest you can go without new studs but it ultimately comes down to what you feel comfortable with. The more you can thread on your lug nuts the better.
12-09-2012, 07:32 PM | #1358 |
Member#: 284237
So theres no real danger? Thanks for the response
12-09-2012, 07:59 PM | #1359 |
Member#: 97135
NWIC
the rule of thumb is anything over 3mm you should use extended studs.
12-10-2012, 11:26 PM | #1360 |
Member#: 307797
Vehicle:2011 WRX WRB |
okay ive got 18 by 9.5 rota grids + 38, i cannot decide between 255/35 or 245/35, im on bc coils and i have a whiteline rear camber kit, and fenders will be rolled, i want there to be no wheel gap and maybe a little bit lower, can someone help me make the decision...
12-10-2012, 11:35 PM | #1361 | |
Member#: 283589
SCIC
Just based off what I've seen on wheeldude.com Fitment and stance seem to be really good |
12-11-2012, 10:33 AM | #1362 | |
Member#: 317045
Vehicle:2012 WRX Hatchback SWP |
I would go with the 255/35-18 tires. Since you plan to roll the fenders, you should clear with 255. The 255 will be closer in diameter to the OEM stock size with better tire patch and grip - less odo error too. 255 will just look better too. The 245 size will give you better steering feel but more odo error since it is much smaller in diameter than the stock size. But the 245 will be better for shooting off the line and out of corners because of the smaller diam. Perhaps lighter and cheaper too - but be aware that the sidewall is really short which will affect ride comfort (among other things). Look at all the tire choices in both sizes and that may help you make a decision too. Not everything is available in the 255/35-18 size. Roll first then decide. |
12-11-2012, 11:02 AM | #1363 |
Member#: 307797
i plan on going with the bfgoodrich gforce kdws 2, which are made in both sizes
12-11-2012, 12:50 PM | #1364 | |
Member#: 289786
Vehicle:2011 WRX Hatch |
12-12-2012, 12:38 AM | #1365 |
Member#: 323242
Vehicle:2012 sti ice silver |
I'm considering some gram lights 57 extreme for my 2012 sti hatch with stock suspension (will probably upgrade to rce t2s or gtworx in the future.). Any thoughts on fitment and handling between the 18x9.5+40 and the 19x9.5+43 with ad08 265s (/35 vs /30)? Weights for the wheels are roughly 2.5 lbs different and tires are roughly 1 lb.
Thanks. |
12-13-2012, 05:21 PM | #1366 |
Member#: 340531
Vehicle:2011 Wrx dark gray metallic |
Hello all.. After bouncing around this thread for a while and running wheel after wheel after wheel through my head, I've come to the conclusion that my summer wheel and tire setup is going to be Miro 111 wheels 18X9.5 +40 with 265/35/18 tires. probably nitto nt555's or hankook ventus v12's. Does anyone have anything they want to tell me before I go through with this? I am sitting at my stock ride height and probably won't be dropping her for some time... All responses/comments/opinions appreciated. Thanks
12-13-2012, 05:27 PM | #1367 |
Member#: 97135
NWIC
dont get the hankooks.
you'll need to roll the rears. have fun. |
12-13-2012, 06:10 PM | #1368 |
Member#: 313194
BAIC
Vehicle:2011 WRX GV WRB |
This was definitely insightful! Thanks Dan! Exactly what I needed!
12-14-2012, 09:05 AM | #1369 |
Member#: 287038
Vehicle:2006 Impreza WRX STI World Rally Blue |
Whats up guys. I got Rota MXR 18x9.5 +38 currently with 225/40 and they look just awful. I have coils, rolls and shaved. I want to go with a meaty flush look and get out of this stance garbage I have now. 245/40 still look slightly stretched from pictures I have seen in google. Would 255/40 or 255/35 work without many issues? 2006 STI. I normally buy Hankook Ventus series.
12-14-2012, 10:53 AM | #1370 | |
Member#: 317045
Some tires to try include: Michelin Pilot Sport PS2, Toyo Proxes R1R, Bridgestone Potenza RE11. The 265/35-18 is the correct diameter compared to stock WRX tires. But be aware that your steering feel will be 'diminished'. |
12-14-2012, 12:15 PM | #1371 | |
Member#: 290307
If you want a track only tire, the Advan Neova AD08 would be the best choice. |
12-14-2012, 12:39 PM | #1372 |
Member#: 306393
NESIC
Vehicle:2017 GTI DSG '99 Corvette FRC |
I would not agree with the AD08 as a 'track only' tire. I've had these. They are a great performing street tire. Also good for auto-x if in the appropriate class.
12-14-2012, 12:40 PM | #1373 | |
Member#: 306393
NESIC
12-14-2012, 03:37 PM | #1374 | ||
Member#: 97135
NWIC
You guys really need to read KentuckyFriedSTI's post. |
12-14-2012, 08:32 PM | #1375 |
Member#: 340531
Thanks for not recommending the hankooks. I know I need to roll the rears.. I asked this question after "reading" the entire thread. Then I actually read the whole thread and everything that pertained to the wheel and tire setup I am looking to get. Sorry for not mentioning that..still learning. I gotta say though reading this thread has been the best thing for me. Before I was almost set on a set of xxr's 18X9.75 with 215s...I've seen it on clubwrx but realized how highly unintelligent that would be after reading this thread. And why do you say have fun??
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L | acetmi | Private 'Wanted' Classifieds | 0 | 06-14-2006 12:43 PM |
need somewhere to get wheels and tires asap | bubba03wrx | Southern California Impreza Club Forum -- SCIC | 22 | 04-02-2004 09:14 PM |
Wider wheels and tires in the rear | SilveRexy03 | Tire & Wheel | 14 | 11-04-2003 04:49 PM |
WEre is a good place to buy wheels and tires | MilfordSubaru | Mid West Subaru Owners Club Forum -- MWSOC | 4 | 05-25-2002 01:14 PM |
Where to buy wheels and tires? | wilddave1 | Brakes, Steering & Suspension | 4 | 03-21-2002 02:20 PM |
