Old 01-17-2013, 03:25 PM   #1426
sc00by4life
Member#: 97135
Originally Posted by ANR62NV View Post
Oh lord ^^^^ your one of those ....
usually its the other way around.
star specs on xxr's.
sc00by4life is online now   Reply With Quote
Old 01-17-2013, 11:54 PM   #1427
nygbrc
Member#: 320003
2011 WRX
Post
Hey guys, have a 2011 wrx sedan. Read a bunch of the thread and its awesome. Want to get an opinion on the right size tires to get for my ride:
Getting Falken RT-7M Wheels 18x9 5x114.3.
http://www.fkwheels.com/wheels/rt-7m
Getting wheel adapters to convert to the 5x114.3
Stock Suspension (might lower in future, doubt it)
The Falkens come in +40, +35 & +20 offsets. Which offset should I get to make the tires flush with the outside of the fender? Thinking 1" wheel adapter with a +35 or +20 offset but cant decide.
As for tires I am torn between 245/40 & 255/35.
Will I have enough room in the fender wells to avoid any modifications if I go with the 245/40 or 255/35? I dont want to roll the fenders but not objected to it.
Thanks in advance.
nygbrc is offline   Reply With Quote
Old 01-18-2013, 12:31 AM   #1428
ANR62NV
Member#: 283589
2011 Impreza WRX
Red
^^^^ wheel adapters ? Hubs From an STI ?
I hear it's not that easy to do....
ANR62NV is offline   Reply With Quote
Old 01-18-2013, 12:53 AM   #1429
sc00by4life
Member#: 97135
Thanks in advance.
A spacer of that size with ANY of those offsets means the wheels will be sticking OUTSIDE the fenders, and certainly not with that much tire.
Stop thinking, and start reading.
Old 01-21-2013, 02:13 AM   #1430
zolaman
Member#: 299059
12 WRX hatchback
Originally Posted by texascanuck View Post
I like the red lug nuts ... thinking of doing the same.
Which ones are they?
Muteki Spinal Lugs 12x1.25
zolaman is offline   Reply With Quote
Old 01-21-2013, 07:23 AM   #1431
_davin
Member#: 260501
2003 miata SE
Blurple
http://www.fastwrx.com/wrwhbopaad.html
_davin is offline   Reply With Quote
Old 01-21-2013, 02:33 PM   #1432
Subaman2012
Member#: 339205
2012 WRX
WR Blue
Default I'm new, be kind please
Just want to get a definitive answer. I have a 2012 WRX and want to definitely go with 18" wheels. I'm thinking 18x8.5 +44 because there are a lot of options for colors and what not. I wouldnt be opposed to 18x9.5 +38 unless there are fitment issues.. What would be the best tire size for the 18x8.5 +44. I DO NOT want to roll fenders or anything else and don't want the tire stretched or anything like that, just a good fit. If the 18x9.5 +38 is an option then tire suggestions?
Thanks in advance guys
Subaman2012 is offline   Reply With Quote
Old 01-21-2013, 03:49 PM   #1433
johnmkv
Member#: 300848
2012 WRX
LR
18x9.5 +38 you will most likely need a roll unless you stretch a narrow tire on there stay with the 8.5 if your againts the fender work
johnmkv is offline   Reply With Quote
Old 01-21-2013, 04:01 PM   #1434
Jdub.csu
Member#: 283784
2013 EVO X GSR
Or he can get Fast WRX Mach V awesome wheels 18x9.5 + 42 (hubcentric so no rings) with 265/35R18 and have no fitment issues
Jdub.csu is offline   Reply With Quote
Old 01-21-2013, 04:33 PM   #1435
johnmkv
Member#: 300848
2012 WRX
LR
This i agree^^^ to correct myself you can get 9.5 but with a higher offset
Old 01-21-2013, 05:02 PM   #1436
Mach V Dan
Member#: 12029
The absolute minimum offset I would get would be +40, but even with our thinnest 15mm bolt pattern adapter, you're still at +25. That's way-stick-out territory. It only gets worse from there if you wanted to go with a lower offset and/or a thicker spacer.
At +25 I'd probably go for the 245, to avoid to much grinding of the fender into the tire. The 255/35 is slightly shorter, but it's (obviously) wider.
At +25 you will have to roll the rear fenders for sure.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 01-23-2013, 12:02 PM   #1437
NoGraffix
Member#: 276209
I am Rub
Function>Form
I have a 2008 wrx (ie no widebody) and I'm looking into getting a set of Rota Options 18x9.5 + 38 (hubcentric) with 265/35R18. I understand I'll have to rol fenders and I have a set of coilovers (BCs) so camber is adjustable in the fronts. How difficult will fitmet be of these wheels? I daily drive this car (60 miles 5 days a week to work and back) so I can't really have something that has an insane amount of rubbing, camber (2* or so max), or toe in, otherwise I'll be going through tires like none other. I've got a feeling that I'm just thinking a little wider then is possible for the car.
Any advice or opinions?
Side note: I do plan to go to the track but have also considered picking up a set of wheels dedicated to track use if these are completely inapproiate. Would also love some advice on that too. For the past year I've been running a set of 17x8 +45 NT03s on 245/45/17s that have worked pretty much all around (track/autox/DD), but I'd really like something wider and more aggressive.
NoGraffix is offline   Reply With Quote
Old 01-23-2013, 12:13 PM   #1438
johnmkv
Member#: 300848
2012 WRX
LR
Wrong thread sir prepare to be flammed lol
Old 01-23-2013, 12:25 PM   #1439
NoGraffix
Member#: 276209
I am Rub
Function>Form
My bad will post in the correct one
Old 01-23-2013, 02:16 PM   #1440
ANR62NV
Member#: 283589
2011 Impreza WRX
Red
^^^ I think your question is relevant to this thread .... Fire away ....
Old 01-23-2013, 02:41 PM   #1441
sc00by4life
Member#: 97135
No it isn't....he'll get more relevant responses in the appropriate thread.
Old 01-23-2013, 03:07 PM   #1442
ANR62NV
Member#: 283589
2011 Impreza WRX
Red
Ok just cause he has on 08' ? You guys swear ...
Old 01-23-2013, 03:10 PM   #1443
J_Maher_WRX
Member#: 290307
This is the 2011+ thread... The cars are significantly different. What don't you understand? Not a difficult concept lol
J_Maher_WRX is offline   Reply With Quote
Old 01-23-2013, 03:15 PM   #1444
ANR62NV
Member#: 283589
2011 Impreza WRX
Red
School me then ....
Couple things different that pertain to wheel fitment besides the fact that one of them is wide body ...???
And OP knows and understands that his isn't wide body and he will have to roll ....
He's asking how difficult it will be to run this setup ....
Old 01-23-2013, 03:51 PM   #1445
J_Maher_WRX
Member#: 290307
School me then ....
Yeah... One is a widebody. Therefore the dimensions in relation to the wheel and various suspension components, including the fenders, is drastically different than ours..
Yeah he did ask a simple question... And he'll find more useful information and advice in the proper thread. It's like asking about wheels in an engine/powertrain thread... Whether he asked a simple question or not, scooby is 100% right in saying that it is not relevant to this thread. Even the OP agreed and moved on. But I'm done feeding the troll..
Old 01-23-2013, 07:33 PM   #1446
ANR62NV
Member#: 283589
2011 Impreza WRX
Red
It's like asking about wheels in an engine/powertrain thread.....
He's asking about wheel fitment in a "guide to wheel fitment thread ..."
Same idea and concept ....
And no I'm not trolling ... Just sick of people trying to be some sort of admin trying to control the forums .....
If people can't ask open questions then what more is there to discuss in a fitment thread that has over 50+ pages in it .... I'm sure everything has been discussed and answered ... I'm done ... Close this thread ....
Old 01-23-2013, 07:48 PM   #1447
J_Maher_WRX
Member#: 290307
It's not 'open' for questions of any kind, it is specific to 11+ models. And its not the 'same idea same concept'. Get a ****ing clue. No one is trying to be an admin, it was simply pointed out that he would find his answers in a different thread, and he agreed. Don't know why you are being so anal about it. If you want a thread where you can ask any questions for any type car, go to the general forums... You can't seem to understand simple concepts.
EDIT: Someone asked a question, he was pointed in the correct direction so that he may find the answer he's looking for. You're argument is completely irrelevant.
Old 01-23-2013, 07:48 PM   #1448
johnmkv
Member#: 300848
2012 WRX
LR
Guide and wheel fitment thread for 2011+ wrx sir does not apply im sure that most people here dont have an 08 and 11 so we wouldnt have any sort of first hand expirance with agressive fitments. Now gtfo lol
Old 01-23-2013, 07:52 PM   #1449
J_Maher_WRX
Member#: 290307
+ 10183830198283781818
Haha I thought it would be too rude for me to say GTFO, glad someone else did it for me
Old 01-23-2013, 08:06 PM   #1450
NoGraffix
Member#: 276209
I am Rub
Function>Form
Sucks that I posted in the correct thread but still have no answers =\
At least here I was told to go somewhere else lol.
For the record I do feel I posted my question in an inappropriate thread which is why I moved to a different one. Although if you can help of appreciate a response either here or in the appropriate thread where I asked the same question.
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 12:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 09:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 04:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 01:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 02:20 PM
