Old 05-31-2011, 05:13 PM   #126
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Originally Posted by Pandasex! View Post
Hi there what r the risk of running 225/45/18 up front and 235/45/18 rear will it really damage my awd on a 09 wrx sedan
d000000000000d...yer center diff will die a horrible death within a short time
Old 05-31-2011, 07:34 PM   #127
Pandasex!
Member#: 258762
2009 Subaru impreza
Ok well I guess I'll just buy the rims and sell the tires sepretly
Pandasex! is offline   Reply With Quote
Old 05-31-2011, 10:04 PM   #128
SW21MR2
Member#: 60135
2005 Kona Stink-E
Thinking about running 255/40/17 or 245/45/17 on my 17x8.5" 5 Zigen GN+ wheels. Not sure which one to go with.
SW21MR2 is offline   Reply With Quote
Old 06-01-2011, 09:38 AM   #129
nhat
Member#: 140163
03 STi
hellaflunctional
Originally Posted by lp87
how do i calculate whether my OD is changed or not?
www.miata.net/garage/tirecalc.html
Old 06-01-2011, 10:46 AM   #130
Mach V Dan
Member#: 12029
You've not mentioned the offset of these wheels. And for the tire size, check the tire calculator mentioned above to choose the best diameter. It's best to stay within 2% of your stock diameter.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 06-01-2011, 10:49 AM   #131
Mach V Dan
Member#: 12029
First of all, this thread is for 2011+ cars. Please see other threads for info on a 2009 WRX.
Secondly, as mentioned, you need to run the same tire diameter all around for your AWD system to survive.
--Dan
Mach V
FastWRX.com
Old 06-01-2011, 08:30 PM   #132
SW21MR2
Member#: 60135
2005 Kona Stink-E
--Dan
Mach V
FastWRX.com
5Zigen Pro-Racer GN+ = 17x8.5_ET48
I got these to clear my Brembos.
The 245/45/17 are 1.4% too slow.
The 255/40/17 are 1.2% too fast.
Old 06-02-2011, 10:03 AM   #133
Mach V Dan
Member#: 12029
Either one of those should fit the car easily, and both are within the 2% rule of thumb, so go with whichever tire you want.
--Dan
Mach V
FastWRX.com
Old 06-02-2011, 12:53 PM   #134
Kuipo
Member#: 174586
2011 WRX Limited 5dr
World Rally Blue
I don't think I mentioned it in this thread.. I like this tire calculator a bit better.
http://www.rimsntires.com/specs.jsp?...rw2=9.5&et2=40
It's nice since you can set the values in the URL by hand if you want to setup what the defaults are.
They both get the same information in the end though of course. Pick your poison.
Kuipo is offline   Reply With Quote
Old 06-03-2011, 05:07 PM   #135
TheBigBadYeti
Member#: 180503
2008 WRX 5 Door
Spark Silver Metallic
Ok, so , in the interest of keeping my options open, what about 18x9.5 + 40 rolling on 255/35-18's? Keep in mind my intention is to lower my car on the GT Worx Suspension setup. Thanks for humoring me.
TheBigBadYeti is offline   Reply With Quote
Old 06-03-2011, 05:45 PM   #136
nhat
Member#: 140163
03 STi
hellaflunctional
roll the rear fenders ...
Old 06-03-2011, 10:05 PM   #137
TheBigBadYeti
Member#: 180503
2008 WRX 5 Door
Well, I guess if I'm gonna be rolling fenders, might as well go with 265's....
Old 06-04-2011, 03:59 AM   #138
DrDanimalSize
Member#: 254097
2010 2014 Impreza
or 275s.....
DrDanimalSize is offline   Reply With Quote
Old 06-04-2011, 11:37 AM   #139
TheBigBadYeti
Member#: 180503
2008 WRX 5 Door
Lol yea, but I think that might push it up front...
Old 06-05-2011, 04:21 PM   #140
lp87
Member#: 284237
2015 wrx
ism
If I get some 18x9.5 Linea Corse Lemans wheels with a +30 offset will I need spacers and if so what are the negative effects of having them? All I will need is an alignment and fenders rolled if I do this right?
lp87 is offline   Reply With Quote
Old 06-05-2011, 05:11 PM   #141
tuskenraider
Member#: 65699
15 WRX
WR Blue
While certainly not needed for the street, they will fit. 295/35/17's at 25.3" diameter can fit with the proper offset...........
tuskenraider is offline   Reply With Quote
Old 06-05-2011, 08:29 PM   #142
lp87
Member#: 284237
2015 wrx
ism
also, do you think any camber would be necissary?
Old 06-06-2011, 11:00 AM   #143
Fleet Admiral
Member#: 249156
11 SWP WRX Hatch
Cobb Stage 2
You need to research more before you buy anything... Spacers are for lowering offset.
Fleet Admiral is offline   Reply With Quote
Old 06-06-2011, 11:03 AM   #144
nhat
Member#: 140163
03 STi
hellaflunctional
please read and learn about offsets and spacers. if you don't understand these simple concepts, you shouldn't be looking at anything below a +45 offset.
i, as well as many other members, could tell you how to fit those wheels but if you don't understand a thing about your setup, we're not helping you at all.
Old 06-06-2011, 04:05 PM   #145
lp87
Member#: 284237
2015 wrx
ism
Okay I understand what offset and spacers are, offset is how deep the rim is and spacers help the wheel clear the brake caliper. Therefore, if i had a wheel with a +30 offset would it have problems with clearing the brake caliper?
edit: nvm talked to wheeldude and they say no spacers are necissary.
Old 06-06-2011, 05:41 PM   #146
nhat
Member#: 140163
03 STi
hellaflunctional
no...
Old 06-06-2011, 05:50 PM   #147
lp87
Member#: 284237
2015 wrx
ism
no...
okay you know what i mean, how deep from the middle to the hub..better?
Old 06-06-2011, 06:17 PM   #148
nhat
Member#: 140163
03 STi
hellaflunctional
http://www.tirerack.com/wheels/tech/...jsp?techid=101
http://en.wikipedia.org/wiki/Offset_(wheel)
http://www.miata.net/garage/offset.htm
Old 06-07-2011, 12:04 AM   #149
secondhandloser
Member#: 250925
'12 Mustang, '11WRX
Black/Spark Silver
very helpful thread
secondhandloser is offline   Reply With Quote
Old 06-11-2011, 01:21 PM   #150
11swpSTi
Member#: 279955
2011 STI Sedan
I have a 2011 STI Sedan and I am interested in getting a set of Enkei NT03+M wheels. I am looking into 18x9.5 but I am not sure what offset to get for them, +27 or +40. Also I am thinking of running a 255 or maybe a 265. Can I get away with just rolling the rear fenders? Please help. Also I will definitely be powdercoating the rims so any advice on colors? Im thinking some sort of gunmetallic color or black. Thank you.
I forgot to mention that I will be running RCE Yellows and their RCE Swaybar combo 25mm front/rear.
11swpSTi is offline   Reply With Quote
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 12:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 09:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 04:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 01:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 02:20 PM
