Old 02-06-2013, 01:20 AM   #1526
b0yt0y
Member#: 334294
2013 WRX Sedan
WR Blue
Originally Posted by Nawratil View Post
It is thinner so it will fit even easier than the 18x9.5
Originally Posted by J_Maher_WRX View Post
Think about it, if a 18x9.5 will fit fine, a half inch smaller width wheel with the same size tire and offsets will obviously fit fine.. It'll have even more clearance
Originally Posted by sc00by4life View Post
this is why you need to learn how to use offset calculators to calculate comparable fitments with different size wheels...
use some common sense.
Thanks for the reply and I'm sorry if I ask this kind of questions. As I've said, I have no knowledge on this kind of things and I don't know how or where to get a offset calculator. My last car before the WRX is a 2003 rav 4 and I didn't even care about the wheels when I had the rav 4. I haven't seen a 18x9 and 18x9.5 up close nor know what will be the difference on fitting. Again, sorry if I offended anyone here with the question and thanks for the educational replies.
b0yt0y is offline   Reply With Quote
Old 02-06-2013, 10:22 AM   #1527
AkursedX
Member#: 340511
2011 WRX
Lightning Red
Is anyone running Fifteen52 RSL Tarmacs in 18x9.5 on their '11+ WRX?
Link to the wheels: Here
From what I have read/understand, an 18x9.5 +40et should fit with no issues except for a slight roll depending on the tire. I am curious to see what they would look like on an '11+ WRX.
AkursedX is offline   Reply With Quote
Old 02-06-2013, 01:45 PM   #1528
mewob
Member#: 321477
2011 WRX Limited 5-d
Question 17x9 +42 with 255/40R17
Hi Guyz,
anyone running Rota Grids 17x9 +42 with 255/40R17 on a 2011 WRX with stock suspension, no fender rolls?
i've hunted around this thread, but haven't seen this exact set up yet. i'm hoping to run this set up without having to roll the fenders.
Thx
mewob is offline   Reply With Quote
Old 02-06-2013, 03:10 PM   #1529
jordanc15
Member#: 276118
2011 WRX
Originally Posted by mewob View Post
Hi Guyz,
Thx
I had those same wheels with a 235 tire. I was lowered a lot but it almost rubbed. I think you could maybe do it but if you lower at all there's no way.
jordanc15 is offline   Reply With Quote
Old 02-06-2013, 03:21 PM   #1530
J_Maher_WRX
Member#: 290307
Hi Guyz,
Thx
You're perfectly fine. No issues at stock height.
J_Maher_WRX is offline   Reply With Quote
Old 02-06-2013, 03:41 PM   #1531
NWsoobie
Member#: 289516
2012 WRX
ISM
Here is a calculator for your needs. Enter your factory wheel specs in the "current" section.
http://www.1010tires.com/WheelOffsetCalculator.asp
NWsoobie is offline   Reply With Quote
Old 02-06-2013, 05:49 PM   #1532
b0yt0y
Member#: 334294
2013 WRX Sedan
WR Blue
Thank You so much
Old 02-06-2013, 06:22 PM   #1533
jlundy11
Member#: 324709
2012 WRX Sedan
I haven't seen the Tarmac on one yet. The Rotiform NUE is similar.
http://unlimitedautocraft.blurmotions.com/?p=110
jlundy11 is offline   Reply With Quote
Old 02-06-2013, 07:18 PM   #1534
mewob
Member#: 321477
Thanks much. Should make a sweet daily driver.
Old 02-06-2013, 07:50 PM   #1535
craig_D36
Member#: 296823
2011 WRX
Satin White Pearl
Want to get these wheels they are 18x8.5 +30
what tire size should i get?
And should I only need a fender roll?
thanks!
craig_D36 is offline   Reply With Quote
Old 02-06-2013, 07:54 PM   #1536
Jdub.csu
Member#: 283784
2013 EVO X GSR
thanks!
Way to low. Stock WRX offset is +53 (or 55 can't remember. Try to stick with around +40 You will have to get a roll, run stretched tires, camber ect.
Jdub.csu is offline   Reply With Quote
Old 02-06-2013, 07:56 PM   #1537
craig_D36
Member#: 296823
2011 WRX
Satin White Pearl
what about 18x9.5 +35?? and thank you for the reply!
Old 02-06-2013, 08:30 PM   #1538
FreeDiRo
Member#: 324928
2006 Sti
SGM
Would a 06 WRX be ok on a +45 offset wheel that is 17x7.5? No drop and on stock suspension, for now.
FreeDiRo is offline   Reply With Quote
Old 02-06-2013, 08:42 PM   #1539
2011rex18
Member#: 321728
2011 WRX Limited
Be prepared to be bashed
2011rex18 is offline   Reply With Quote
Old 02-06-2013, 08:45 PM   #1540
_davin
Member#: 260501
2003 miata SE
Blurple
That sounds like you will be just fine, bit your in the wrong thread bro, read the title.
_davin is offline   Reply With Quote
Old 02-06-2013, 09:26 PM   #1541
Cathartic
Member#: 336202
Well I personally said **** it I'm going to run 255/35s on my 8.75" width wheel, even though it has a tread width of 9.5". The 245 you are referring to has a tread width of 9". Here is a link to a 2011 wrx with 18x8.5" wheels and 245/40/18 PSS:
http://www.clubwrx.net/forums/suspen...rx-2011-a.html
As you can see, it doesn't appear to bulge too dramatically, and you clearly are benefiting from the wider tread. For comparison, a 255 PSS had 9.5" tread while a 255 Hankook v12 Evo has only 8.7"!! Almost a full inch of difference between tread width, which is clearly substantial. So like I said I'm going to run 255's on my 8.75" wide wheels, it should bulge only ever so slightly than the car in the above link, which I don't think will be too bad. I like the meaty look anyways as long as it is proper fitment
Thanks for the response! Judging by what I can tell from those pics, I will probably want to lower things a bit, but otherwise, I think 245/35/18 should work out pretty well with the PSS on the 8.5 wheels.
I appreciate the useful info - and good luck with your 255's - I hope they work out the way you want!
Cathartic is offline   Reply With Quote
Old 02-06-2013, 10:33 PM   #1542
FreeDiRo
Member#: 324928
2006 Sti
SGM
Thanks, my bad I did this at work, but I appreciate the assistance.
Old 02-07-2013, 01:39 PM   #1543
synaZaur
Member#: 309842
2012 WRX
Rally Blue
2012 WRX Wagon - looking at a set of Konig 18x8 +45 with 245/40/18... I'm thinking I should be good but I just want to confirm.
synaZaur is offline   Reply With Quote
Old 02-07-2013, 01:45 PM   #1544
J_Maher_WRX
Member#: 290307
You're perfectly fine... Read the thread...
Old 02-07-2013, 01:55 PM   #1545
synaZaur
Member#: 309842
2012 WRX
Rally Blue
Just saw the bore is 73.1... that's a huge difference no?
Old 02-07-2013, 02:07 PM   #1546
J_Maher_WRX
Member#: 290307
It is, you need hubcentric rings that reduce down to 56.1mm
Old 02-07-2013, 02:09 PM   #1547
synaZaur
Member#: 309842
2012 WRX
Rally Blue
just read that and was about to post.. shoulda done a bit more homework before posting!
Thank you
Old 02-07-2013, 07:57 PM   #1548
jdimitrooplis
Member#: 331585
2013 WRX
Plasma Blue
Can someone help me out… I have a 2013 WRX and am thinking about getting a set of Work Cr Kais that are 18x9.5 et38. Can I run these on the rear without having to roll my fenders? Thanks!
jdimitrooplis is offline   Reply With Quote
Old 02-07-2013, 08:46 PM   #1549
J_Maher_WRX
Member#: 290307
Read the first god dam page of this thread... Jesus lazy people...
Old 02-07-2013, 08:55 PM   #1550
ANR62NV
Member#: 283589
2011 Impreza WRX
Red
"Read the first god dam page of this thread... Jesus lazy people...[/quote]"
Just like I said , close this thread cause everything has been discussed...... pft^^^
Let him ask the question a thousand times if he wants , it's a forum, an open place for discussion ... Jesus
ANR62NV is offline   Reply With Quote
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 12:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 09:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 04:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 01:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 02:20 PM
