Old 06-11-2011, 02:32 PM   #151
nhat
Member#: 140163
03 STi
hellaflunctional
Originally Posted by 11swpSTi
I have a 2011 STI Sedan and I am interested in getting a set of Enkei NT03+M wheels. I am looking into 18x9.5 but I am not sure what offset to get for them, +27 or +40. Also I am thinking of running a 255 or maybe a 265. Can I get away with just rolling the rear fenders? Please help. Also I will definitely be powdercoating the rims so any advice on colors? Im thinking some sort of gunmetallic color or black. Thank you.
I forgot to mention that I will be running RCE Yellows and their RCE Swaybar combo 25mm front/rear.
answered you in the other thread.
Old 06-12-2011, 12:16 PM   #152
11swpSTi
Member#: 279955
2011 STI Sedan
Thanks for the help! I appreciate it.
11swpSTi is offline   Reply With Quote
Old 06-13-2011, 12:38 AM   #153
builthatch
Member#: 185105
2009 C63 AMG
Palladium Silver
posting to remove email notification
builthatch is offline   Reply With Quote
Old 06-20-2011, 05:02 PM   #154
dmk0210
Member#: 284114
2011 WRX Sedan
World Rally Blue
Awesome thread, shouldn't this be a sticky or at least attached to the fitment thread already up there?
dmk0210 is offline   Reply With Quote
Old 06-21-2011, 06:43 PM   #155
chris scott
Member#: 276084
2011 WRX
Hi,
I'm getting some grids, 18x9.5 +38. I'm just down to deciding between the 255/35R18's and the 255/40R18's in the hankook ventus v12 evo k110's. I haven't seen the 255/40R18's talked about much here. Any reason why the 35 aspect ratio tires are more popular?
The 40's are about $15 cheaper per tire...do you think that will rub on the 2011 wrx sedan? They're about 26 mm taller than the 35's.
Thanks!
chris scott is offline   Reply With Quote
Old 06-21-2011, 07:33 PM   #156
nhat
Member#: 140163
03 STi
hellaflunctional
Originally Posted by chris scott
Hi,
Thanks!
www.miata.net/garage/tirecalc.html
compare the 2 sizes you listed with the oem tire size and you'll get a basic understanding of why 255/40/18 isn't a popular size for the impreza.
Old 06-21-2011, 09:48 PM   #157
chris scott
Member#: 276084
2011 WRX
so is it because it goes over the 2% rule, and is therefore too different for the speedometer/odometer?
Old 06-21-2011, 10:07 PM   #158
nhat
Member#: 140163
03 STi
hellaflunctional
no it has nothing to do with the speedo/odo. a 255/40/18 is 26" in diameter, it'll be difficult to fit without rubbing on an impreza body.
Old 06-22-2011, 10:45 AM   #159
dmk0210
Member#: 284114
2011 WRX Sedan
World Rally Blue
Originally Posted by chris scott View Post
Hi,
Thanks!
I got /35s to keep my diameter smaller than the OEM tires (actually got 265/35R18s so they are right about the same diameter as OEM). If I had bought 235s on 18s, I would have gotten /40s.
Going with a smaller diameter gives you a lower effective gear ratio for better performance. It shouldn't make all that much difference between a /35 and /40 in the same width but my personal rule of thumb is never go with a larger diameter or weight than the original wheels and every little bit adds up either for or against you as you make incremental mods on your car.
Smaller diameter than original also keeps your speedometer from reading too slow. I tend to drive a little fast so I would much rather have a speedo that reads 65 when I'm actually doing 63 or 64 than one that reads 65 when I'm actually doing 66 or 67.
Old 06-22-2011, 11:47 AM   #160
nhat
Member#: 140163
03 STi
hellaflunctional
have you compared a 255/35/18 and 255/40/18? or 265/35/18 and 265/40/18?
a 1" difference is a huge.
Old 06-22-2011, 08:50 PM   #161
dmk0210
Member#: 284114
2011 WRX Sedan
World Rally Blue
Yea, it is a pretty good difference I guess. 4%
Old 06-22-2011, 09:55 PM   #162
nhat
Member#: 140163
03 STi
hellaflunctional
stop thinking about speedo difference and start thinking 1" or 25mm in terms of clearance.
it's the difference between rubbing and not rubbing.
Old 06-24-2011, 11:28 AM   #163
Ying
Member#: 166490
2011 WRX
So I'm still a dunce when it comes to offset. I've used the calculators and everything, but I still have a question. My old beater wheels from my STi are 17x7.5 +45 offset w 225 series winter tires. Should I be concerned about using those as my winter wheels on my '11 wrx or will those work fine?
Ying is offline   Reply With Quote
Old 06-24-2011, 11:52 AM   #164
nhat
Member#: 140163
03 STi
hellaflunctional
they'll work fine as long as they are 5x100
Old 06-24-2011, 12:15 PM   #165
Ying
Member#: 166490
2011 WRX
Thanks yes they are. They were for my old 04 STi.
Old 06-28-2011, 11:12 PM   #166
petiks
Member#: 261817
2014 WRX
hello, just wanted to check. planning to have 17x8 with +48 offset...what's the widest tire i can go with...will 245/45/17 have no rubbing issues? how about 255/40? this is for a 11 WRX sedan, by the way....thanks!
petiks is offline   Reply With Quote
Old 06-28-2011, 11:24 PM   #167
nhat
Member#: 140163
03 STi
hellaflunctional
245/45/17 would fit but 245/40/17 is more ideal. 255/40/17 is too wide for an 8" wheel.
Old 06-28-2011, 11:36 PM   #168
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
i run 245-45-17 nitto nt01's on 17x8 47mm offset.. no issues at all.... autox/track tire.
Robin2 is offline   Reply With Quote
Old 06-29-2011, 07:22 AM   #169
arf80
Member#: 125580
2011 WRX 5dr
Are there any 18" wheels that won't make the WRX brakes look tiny in profile? Enkei RPF1 perhaps, with that lip that runs around the inner circumference of the wheel? Volk ce28/Rota DPT?
arf80 is offline   Reply With Quote
Old 06-29-2011, 08:49 AM   #170
SCRAPPYDO
Member#: 873
2014 GLK/allroad
Datsun 71 240Z & 68 2000
If you are willing to get a Volk, then get bigger brakes...
SCRAPPYDO is online now   Reply With Quote
Old 06-29-2011, 09:06 AM   #171
nhat
Member#: 140163
03 STi
hellaflunctional
CCWs or linea corse would because of how the face bolts to the barrel.
Old 06-29-2011, 03:04 PM   #172
wongjonsilver
Member#: 262683
2011 WRX base
I'm planning on running the Enkei RPF1 18"x9.5" (+38 offset) on my 2011 WRX 5Dr. Any recommendations for Dunlop Direzza Star Spec tires? 2##/##/18 ? I currently still am on stock suspensions, but will be on KW or Mann Engineering coilovers in the near future. (believe I will have to roll the rear fenders a little bit)
wongjonsilver is offline   Reply With Quote
Old 06-29-2011, 03:15 PM   #173
DrDanimalSize
Member#: 254097
2010 2014 Impreza
^265-35 is pretty much the norm in this thread, 255 or 275 could work too
DrDanimalSize is offline   Reply With Quote
Old 06-29-2011, 03:45 PM   #174
nhat
Member#: 140163
03 STi
hellaflunctional
if you care about speedo accuracy, 245/40/18 or 265/35/18.
if you want gearing advantage, 255/35/18.
Old 06-29-2011, 05:00 PM   #175
arf80
Member#: 125580
2011 WRX 5dr
More importantly, where are you getting an 18x9.5 RPF1 in 5x100?
Edit: found the group buy
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 12:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 09:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 04:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 01:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 02:20 PM
