Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 04-20-2013, 07:07 AM   #1876
Turtlefart
Member#: 320054
2011 WRX
Originally Posted by AkursedX View Post
Oh whoops, +45et.
Looks really good! What's the tire size and do you have anymore pics?
Turtlefart is offline   Reply With Quote
Old 04-20-2013, 09:52 AM   #1877
Scargod
Member#: 260314
2008 STI hatch
Oh whoops, +45et.
Whatever, nice looking combo. Looks a little like 245/40ZR17's... The Falkens remind me of the Michelin Pilot Super Sports I use as rain tires when needed at the track.
Scargod is offline   Reply With Quote
Old 04-20-2013, 10:36 AM   #1878
AkursedX
Member#: 340511
2011 WRX
Lightning Red
Tires are 255/40/17. The FK453 wasn't my 1st choice, but discounttiredirect had a $50 off a set sale plus the tires also had an $80 rebate so I couldn't pass them up for the price.
I have to edit that post. I can't believe I forgot to put the tire size in it! Geez....that's what happens when you are trying to type a post with a 3-year old and 7-month old all over you.
AkursedX is offline   Reply With Quote
Old 04-20-2013, 10:39 AM   #1879
AkursedX
Member#: 340511
2011 WRX
Lightning Red
I bought these because they look like the Continental Extremecontact DW's that I have on my RX8. I'm hoping the Falkens perform as well in the wet as the Conti's. I don't plan on tracking my WRX much so I try to find tires that will perform well in the wet at the sacrifice of some dry-grip.
Old 04-21-2013, 12:07 AM   #1880
Charlie626
Member#: 339554
2013 Impreza WRX
Ice Silver Metallic
Really helpful thread. Definately helped me decide on what size tire to get for my new wheels.
Charlie626 is offline   Reply With Quote
Old 04-21-2013, 11:11 PM   #1881
dylanisco0l
Member#: 347674
2013 wrx
blue pearl
was thinking about getting 245/40ZR17 michelin pilot super sports, anyone have this setup? any rubbing or fitment issues? also what hoods are those on the OP car would love to pick one up.
dylanisco0l is offline   Reply With Quote
Old 04-21-2013, 11:36 PM   #1882
deanwrx
Member#: 188997
2007 STI
Just an FYI, that tire is a narrow 245. The PSS may run normal or "wide" in other sizes (according to some people) but the 245/40/17 is kinda below average in width. It will look good on a 17x8 wheel, but looks stretched on a 17x9. However, this will make it easier to fit than something like a Direzza Zii in the same size.
deanwrx is offline   Reply With Quote
Old 04-22-2013, 12:08 AM   #1883
dylanisco0l
Member#: 347674
2013 wrx
blue pearl
well the O.E. tires are 235 so wouldn't it be wider than the O.E. my upgrades are cobb DP, upipe, EWG, 44m WG tial, n1 exhaust, intake+airbox, don't plan on doing much more for awhile so 245 seems to be a proper size for the power for now at least, from what i have read. unless any other suggestion for size in the PSS tires.
Old 04-22-2013, 12:23 AM   #1884
Dova
Member#: 315989
2012 WRX hatchback
Satin White Pearl
After a whole lot of reading this thread , I've decided to go with Rota G-Force 18x8.5 48et in gold for my 2012 WRX hatch. I'm not into the whole hellaflush/poke scene. Debating if I should go with 245/40/18 ( 1.52% faster than stock tire ) or a bit wider with 255/35/18 ( 1.20% slower than stock tire ) , suspension wise it'll be stock for now.
Dova is offline   Reply With Quote
Old 04-22-2013, 04:54 AM   #1885
ryann.mendoza
Member#: 208859
2013 WRX
[quote=AkursedX;39627615]Thank you for the help that you guys have provided me in this thread. Here is the result. 17x9 et45 Enkei RPF1's with Falken FK453 Tires in 255/40/17. Stock ride height. No rubbing.
(pardon the dirtiness of the car)
more pictures please. This exactly the setup I wanted. Good to hear that there's no rubbing with this setup. Thanks!
ryann.mendoza is offline   Reply With Quote
Old 04-24-2013, 04:45 PM   #1886
xxllplayallxx
Member#: 267068
2015 EVO X GSR
Wicked White
whats up guys. I have 18x8.5 et45 with a 255/40 tire on stock suspension and rubbing in the back like crazy. I will be buying new tires Friday, i am going to go with a 225/45 18. I will post a picture when i mount them.
xxllplayallxx is offline   Reply With Quote
Old 04-24-2013, 07:47 PM   #1887
NWsoobie
Member#: 289516
2012 WRX
ISM
Why taller? Just go with a 235/40. You will be fine.
NWsoobie is offline   Reply With Quote
Old 04-24-2013, 09:20 PM   #1888
Dova
Member#: 315989
2012 WRX hatchback
Satin White Pearl
With that fitment , go with 245/40/18 Pretty much STi fitment. 255/40 is too tall for that size , should've went with 255/35 instead.
Old 04-25-2013, 08:07 AM   #1889
xxllplayallxx
Member#: 267068
2015 EVO X GSR
Wicked White
I do not plan on lowering the car, so I want to fill in the wheel gap.
Old 04-25-2013, 09:49 AM   #1890
Mach V Dan
Member#: 12029
I understand what you're trying to do, but the diameter of the STi stock tire (245/40R18, 25.7" diameter) is already pretty big. If you go any taller, you are likely to rub the fender liners if nothing else. The 225/45R18 is 0.3" taller still at 26.0" diameter. It'll probably rub. But keep us posted.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 04-25-2013, 10:11 AM   #1891
xxllplayallxx
Member#: 267068
2015 EVO X GSR
Wicked White
I do have the 255/40 18 on right now and no fender liners are rubbing in the front. I only have an issue with the drivers rear fender which very odd. I have had a mechanic to check the suspension and nothing is out of spec.
--Dan
Mach V
FastWRX.com
Old 04-25-2013, 11:35 AM   #1892
Roycey
Member#: 354321
2010 MY 11 WRX
Satin Pearl White
Default Wheel fitting problem
Hi Dan, thanks for your great thread. I need some advice please because I could not see any comments with the problem I have. I purchased some Rota Grids 18 x 9.5 +38 for my MY11 WRX Hatch with std suspension. I did a trial fit before buying tires. I found that the rims protude past the guards. Front 6 & 9mm, Rear 4 & 7mm. I fiddled with the front camber adj by moving the bolt clockwise by 2-3 notches which just about tucked the rim in under the guard, but I am unsure what the actual neg camber setting would be & if it would work. I had a fiddle with the rear with no improvement because this is really only for toe in/out adj. Do you have any suggestions please? If I run with this set-up then I would possibly be Police bait & have insurance coverage issue's. Regards
Roycey is offline   Reply With Quote
Old 04-25-2013, 01:48 PM   #1893
NWsoobie
Member#: 289516
2012 WRX
ISM
Why would either of these happen? A cop isn't going to pull you over because of your wheels, nor will you have any insurance coverage issues. And what are your tire specs? That makes all the difference.
Old 04-25-2013, 08:32 PM   #1894
Roycey
Member#: 354321
2010 MY 11 WRX
Satin Pearl White
If the rims protrude past the guards that is un-roadworthy in Australia & the cops are on the look out for it in our Granny state!
For Vic Roads roadworthy it states that when in a straight ahead position, the guard or bodywork must cover the section width of the tyre. If its not roadworthy I may void my insurance cover should I have to claim.
So you suggest it may not be noticeable with the right tire selection?
I am still considering tire options in size 255/35R18 or 265/35R18 in a Dunlop Direzza Z2 or Bridgestone Adrenalin RE002 or Toyo T1R? I want a performance road tire, but the car is a daily drive for a sales rep, approx 20k miles per year, so I need a tire with reasonable wear rating-180 should be ok. Any suggestions would be greatly appreciated.
Old 04-26-2013, 03:52 AM   #1895
ryann.mendoza
Member#: 208859
2013 WRX
Error. Edit.
Old 04-27-2013, 09:20 AM   #1896
Xterrapin
Member#: 352282
I'm really interested in preserving steering feel and handling on a 13 WRX, and I'm looking at some 18x8.75 +33 wheels. I'm thinking 255/35/18 tires would be my best option.
I know that the +33 offset is cutting it close, but would this set up work with out rolling the rears ?
I will be lowered about an inch on Feal coilovers
Xterrapin is offline   Reply With Quote
Old 04-27-2013, 11:13 AM   #1897
punx0506
Member#: 230967
'05 AW STI
I have an 05 sti and currently am running a set if 18x8 +40 wheel with 235/40 tires. Right now the car sits a little higher than I would like it too and want to drop it down an inch. I am worried about the inner fender rubbing the tire when I do this but not sure if it is ok to completely take them out or not since the harness runs through drivers side. I plan on rolling my fenders but didnt know what to do with the inners. Has anyone done this that can give me some advice?
punx0506 is offline   Reply With Quote
Old 04-27-2013, 11:27 AM   #1898
Ruzty1311
Member#: 311911
2012 WRX Limited Sdn
SWP (TP Stg 2)
So by trial fit I'm assuming you mocked up the rims while the car was up in the air yes? So the protruding you are seeing might not be what you are actually gonna get once you put tires on and set the car back down...it should tuck somewhat with the suspension fully loaded and not be protruding as much as you are seeing with just the rims up in the air IF this is even the case haha
Ruzty1311 is offline   Reply With Quote
Old 04-28-2013, 08:52 AM   #1899
Roycey
Member#: 354321
2010 MY 11 WRX
Satin Pearl White
Sorry, I didn't explain that I had loaded up the suspension by dropping the car on a stand under the lower control arm & checked each wheels fit. Therefore, the rim protrusion is how it would be fitted to a tyre. Do you have any suggestions because some of pics I have seen with this size rim doesn't show the problem I am experiencing?
Old 04-28-2013, 08:53 AM   #1900
Roycey
Member#: 354321
2010 MY 11 WRX
Satin Pearl White
This thread is for MY11+ !!??
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 12:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 09:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 04:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 01:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 02:20 PM
