Welcome to the North American Subaru Impreza Owners Club Wednesday July 30, 2014
Old 06-29-2011, 05:47 PM   #176
STi-LLlegal
Member#: 101315
2011 WRX Hatch
Torqued_Performance Stg 2
This should clear up some things. My setup is 18x9.5 Grids on 265/35/18 Hankook V12s. Front camber is -1.7 and rear camber is at -2.1. Rear fenders rolled almost flat. No rubbing with my coilovers on the softest setting.
STi-LLlegal is offline   Reply With Quote
Old 06-29-2011, 11:16 PM   #177
Mach V Dan
Member#: 12029
Originally Posted by STi-LLlegal View Post
This should clear up some things. My setup is 18x9.5 Grids on 265/35/18 Hankook V12s...
It would clear things up even more if you gave the wheel offset.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 06-30-2011, 02:57 AM   #178
STi-LLlegal
Member#: 101315
2011 WRX Hatch
--Dan
Mach V
FastWRX.com
Can't believe I forgot that. It's +38.
Old 06-30-2011, 07:43 AM   #179
Fleet Admiral
Member#: 249156
11 SWP WRX Hatch
Cobb Stage 2
Looks great! Quick question though. How are you adjusting rear camber?
Fleet Admiral is offline   Reply With Quote
Old 06-30-2011, 06:00 PM   #180
STi-LLlegal
Member#: 101315
2011 WRX Hatch
Cusco lower control arms.
Old 07-01-2011, 10:15 AM   #181
JamesWilson2
ForumWars Winner!
Member#: 196948
2003 Forester
295/35-17 Hoosier A6's on the Rota 17x8" +48 wheel. No rubbing anywhere unless there is a MAJOR JUMP. Stock springs, no spacers, just shocks and a 25mm front sway bar.
I have ordered a set of the 275/40-17 Goodyear Eagle RS racing tire, which is a very wide 275 (supposed to be equal in width to the 295 A6) but slightly taller, not sure if that is going to pose a problem or not. I'll post comparison pictures when I get them mounted up.
Plenty of room on the inboard part of the rear tire, I think a +47mm offset would rub the rear fenders under very high load.
FWIW, I run 245/45-17 Hoosier Wets for a rain tire on the cheap Discount Tire Drag DR-31 wheels with +47mm offset and zero problems.
JamesWilson2 is offline   Reply With Quote
Old 07-01-2011, 11:35 AM   #182
sc00by4life
Member#: 97135
I just don't understand why you autocross Mongloids insist on putting tires far far too large on narrow wheels. Ugh I can only imagine how crap the response is, and rolling like a boat in the corners.
Of course a 17x8 +47 will rub when you're tire size is....well.... THAT.
Old 07-01-2011, 06:12 PM   #183
JamesWilson2
ForumWars Winner!
Member#: 196948
2003 Forester
Because we can . Actually, because the rules for "Stock" classes are so limited that we have to make up responsiveness with overall grip.
Nevertheless, yes, those sizes do fit the 2011.
Old 07-02-2011, 12:07 AM   #184
T-WRX2011
Member#: 281804
2011 Impreza
Read a lot just want to get a clarification. I just ordered my 527's 18x8.75 et35 with 255-35-18 nexans (don't hate on tires upgrading later). I will be lowering on epic springs stock struts. I know rolling back fenders is necessary, but do you think the 255 are too wide? I'm not trying to run much negative camber either as close as stock. Will I need anything else?
T-WRX2011 is offline   Reply With Quote
Old 07-14-2011, 09:37 AM   #185
Mach V Dan
Member#: 12029
Originally Posted by T-WRX2011 View Post
...18x8.75 et35 with 255-35-18 nexans...do you think the 255 are too wide?
Too wide for what? The wheels? No. Are you asking if you will rub the fenders? Not in front. The rear will be tight. Based on the 265/35R18 on a +40 wheel we've used a lot, you have a 10mm narrower tire (5mm further from the fender) but are moving the wheel 5mm closer to the fender with the +35 offset. So, it may rub in the rear, which would require fender rolling back there, but that's it. You're squeezing the tire on to a narrower wheel than we usually use (8.75" compared to 9.5") so that may further narrow the tread. Plus, your 255/35R18 is 1.1% shorter than the 265/35R18, so that'll help clearance, too.
--Dan
Mach V
FastWRX.com
Old 07-14-2011, 10:29 AM   #186
nhat
Member#: 140163
03 STi
hellaflunctional
why do people continue to post this? the oem alignment is terrible! will it kill you? no. will it kill your tires? no. will you enjoy your car more and get even tire wear if you get a non-oem spec alignment? yes.
if you want low offset wheels, you'll have to deal with adding negative camber. otherwise, stick to +45 and higher offsets.
Old 07-14-2011, 10:44 AM   #187
SCRAPPYDO
Member#: 873
2013 F150 King Ranch
Datsun 71 240Z & 68 2000
I am going to assume you are being sarcastic and trying to be funny.
What would anybody in the WFC know about responsiveness or fitment or autocross for that matter.
but just in case you are being serious, although you cannot possibly be that dim, autocross has rules where in some classes tires are not restricted, but suspension mods (like springs), and rims are. He bought those to gain grip which when added in extreme amounts, more than makes up for lack of responsiveness. The owner probably has other wheels and tires for street driving.
Unlike most people in the WFC, he is using his car for what it was intended for. Not a glorified trailerqueen/doorstop.
SCRAPPYDO is offline   Reply With Quote
Old 07-14-2011, 12:18 PM   #188
nhat
Member#: 140163
03 STi
hellaflunctional
news flash: sc00by4life has a dedicated track setup with "correct" fitment, as do most WFC members who track their car
Old 07-14-2011, 01:31 PM   #189
SCRAPPYDO
Member#: 873
so like 2 of them..then..
Old 07-14-2011, 01:46 PM   #190
nhat
Member#: 140163
03 STi
hellaflunctional
how would you know?
you're a smart guy, you should know better than to make baseless statements
the educated WFC members understand the differences and you don't see them touting that their aggressive fitment setups handle great or better than a "correct" fitment setup. the CFC members love to bring up the fact that your car will handle worse even though these guys do it for style on the street, not the track or autox.
Old 07-14-2011, 02:21 PM   #191
sc00by4life
Member#: 97135
Using a rediculously wide tire, is not always the best or easiest way to increase overall grip.
I don't drive around cones in parking lots so I don't understand all the rules for autox, the guy who I was quoting replied back stating that it was really the only thing he can do in his class. That makes sense to me.
But a 255 handles like **** on an 8" wheel, why in gods name would a 295 handle any better (it doesnt.....). But again, its what he can do to stay within his class.....my original question was answered, "why the hell would you do that."
Old 07-14-2011, 02:40 PM   #192
SCRAPPYDO
Member#: 873
So I should have just said, he is exploiting the rules the best way he could...
Perhaps.... but now that would not be me for better or worse.
Old 07-14-2011, 02:41 PM   #193
SCRAPPYDO
Member#: 873
probably worse....
Old 07-15-2011, 10:06 AM   #194
Mach V Dan
Member#: 12029
Please refrain from turning this thread into another wrong fitment vs. correct fitment battle. If it continues I'll have the thread edited and all the argument posts removed.
--Dan
Mach V
FastWRX.com
Old 07-15-2011, 11:06 AM   #195
Ying
Member#: 166490
2011 WRX
--Dan
Mach V
FastWRX.com
Thanks Dan. I keep checking back in here for the reason this thread was started in the first place. Carry on...
Ying is offline   Reply With Quote
Old 07-15-2011, 02:07 PM   #196
TrueSilver
Member#: 152207
2013 Duramax LML
2000 Civic Si EBP
This is the exact same wheel I am picking up today. It is good to know what it will look like and how it may fit.
TrueSilver is offline   Reply With Quote
Old 07-15-2011, 08:52 PM   #197
kiger0183
Member#: 119895
2011 WRX
exactly what i was looking for. Thanks for the great writeup
kiger0183 is offline   Reply With Quote
Old 07-19-2011, 06:51 PM   #198
mikerulzu
Member#: 247774
2011 WRX
Could I comfortably (no fender rolling) run 245/45-17 Star Specs on my '11 with stock wheels? I actually like the way they look for the time being, and won't be replacing them immediately. Was wondering if I could get away with a little more meat on my tires.
mikerulzu is offline   Reply With Quote
Old 07-19-2011, 07:17 PM   #199
nhat
Member#: 140163
03 STi
hellaflunctional
with ease.
Old 07-19-2011, 09:51 PM   #200
olazy
Member#: 263322
2011 WRX Limited
WRBP
hi guys, i need some advice fitting my wheel/tire setup, i have a set of xxr 527 18x8.85 +35 with federal ss595 245/40/18. i test fitted them and obviously they are rubbing like crazy in the rear. i know i probably should have went with a smaller tire but i'm trying to work with what i got. any hope of getting these to fit? also how is everyone adding rear camber to their 2011s? lower rear control arms? do rear camber bolts work? i'm planning to roll my rear fenders. thanks in advance guys.
olazy is offline   Reply With Quote
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 12:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 09:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 04:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 01:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 02:20 PM
