Welcome to the North American Subaru Impreza Owners Club Friday January 30, 2015
Old 07-03-2013, 05:17 PM   #2101
le chocolate moose
Member#: 287147
2011 STi HB
Originally Posted by Mach V Dan View Post
265 is a little wide for a 9" wide wheel, but it can still fit on there. 255/35 is only 1.2% smaller than stock diameter...that's pretty close. I'd go with that.
We don't if we're just judging tire width versus wheel width.
--Dan
Mach V
FastWRX.com
Much appreciated, thanks!
le chocolate moose is offline   Reply With Quote
Old 07-03-2013, 08:13 PM   #2102
sc00by4life
Member#: 97135
Originally Posted by le chocolate moose View Post
Sorry, it was in the title: "18x9.0 on PSS 265/35 on GR STi"
Didn't mention offset since I am confident +36 will work with stock susp and possible slight roll to the rear.
Thanks,
Mike
Ahh yeah I don't pay attention to post titles. Sorry.
And I wouldn't call a 265 too wide for a 9" wheel. should fit fine.
Old 07-03-2013, 11:14 PM   #2103
sightline
Member#: 351172
2013 WRX
Dark Grey
Originally Posted by TryHonesty View Post
I'm looking to get Rota Grids for my 2013 WRX and would like an opinion:
The 17" look like they would fit no problems, any ideas on the 18"?
My 2013 WRX is wearing 18x8.5 +48 rims and 255/35 PSS tires. Stock height, no issues at all with rubbing, and plenty of rubber on he road.
-dave
sightline is offline   Reply With Quote
Old 07-04-2013, 03:22 PM   #2104
Ghostlystang
Member#: 338515
2013 WRX 6spd swap'd
305/345 (12.43@111.5mph)
My 2013 WRX on stock suspension is on 18x9.5 +34 with 255 tires. Also no issues.
Ghostlystang is online now   Reply With Quote
Old 07-07-2013, 02:46 AM   #2105
J_Maher_WRX
Member#: 290307
If you don't have your rear fenders rolled the first time you hit a bump or hit a corner hard you're in for some massive running haha
J_Maher_WRX is offline   Reply With Quote
Old 07-07-2013, 09:12 PM   #2106
Sharpz214
Member#: 351508
2011 WRX Premium
2011 WRX
Rear fenders rolled
Eibach lowering springs
Thinking about getting some new wheels. 18x9.5 +38. Tires will probably be 255/35/18s.
Thoughts? Should be able to run these no problem, right?
Sorry is this has been posted prior in the thread, I searched through tons of posts and didn't catch it...
Sharpz214 is offline   Reply With Quote
Old 07-07-2013, 09:44 PM   #2107
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Originally Posted by Sharpz214 View Post
2011 WRX
Rear fenders rolled
Ummm!!! Must not of looked very hard cuz right at the beginning of this thread u would have found your answer/
trev762 is online now   Reply With Quote
Old 07-09-2013, 06:06 PM   #2108
Ptown_finezT
Member#: 308190
2012 wrx hatch
dgm,2010 swp legacy prem.
2011 WRX
Rear fenders rolled
Yes they will fit, exact same setup that i have but with a 265/35/18 tire and no issues whatsoever.
AG Photo lightroom by AG's Photography, on Flickr
Picture for reference.
Ptown_finezT is offline   Reply With Quote
Old 07-10-2013, 11:43 PM   #2109
j3pwrx
Member#: 361041
Hi, I ordered some 18x9.5 +40 wheels but still deciding which tire to go for. Fenders will be rolled but will remain on stock suspension until next year.
I'm avoiding 265's to ensure tires are still tucked in the fender.
So, which should I go for? 255/35 or 245/40? Both are within the 2% rule and looks good from what I've been seeing here, but which better suits a DD on stock suspension?
I also want to avoid rubbing the fender liner when I lower it on coils.
Please advise. Thanks!
j3pwrx is offline   Reply With Quote
Old 07-10-2013, 11:54 PM   #2110
Evil XT
Member#: 102801
1992 PlymouthAcclaim
13WRX, RIP "Silver Van"
Those tires suggested will have too much stretch unless youre going for the mega flush, hella tuck or whatever you call that garbage...
Evil XT is offline   Reply With Quote
Old 07-11-2013, 02:03 PM   #2111
texascanuck
Member#: 317045
2012 WRX Hatchback
Default 255/35 - 18
Go with the 255/35-18 tires on your 18x9.5" wheels. Do not use the 255/40-18 because they are too tall compared to the WRX OEM tire size. In fact, they are over 2.78% taller.
And I think a 245 tire on a 9.5 wide wheel may be just a little too stretched.
texascanuck is offline   Reply With Quote
Old 07-14-2013, 10:58 AM   #2112
Scnsaracer
Member#: 319511
2013 STI Sedan
Ice Silver Metallic
Dan I have a 2013 STI sedan and some 18 9.5 38 work emotions coming. I intend to run Michelin pilot super sports 265 35 18. My car is lowered on Eibachs and I have the camber set around 1.5 all around. Obviously I will have some clearance issues in the rear. My question is, should I roll or trim the fenders? A friend of mine actually trimmed the rear lip instead of rolling. I like how it didn't distort the outside edge of the fender like rolling does but I was wondering what your experience was. Here are a couple pictures of my car's current stance.
One more question, I keep reading that OEM Subaru lug nuts are not to be used on aftermarket wheels due to the way the lug seat is shaped but the aftermarket lugs I have seem to be the same shape as my stock lugs. Can I use stock lugs on my work wheels? I'm not cheap but the lugs I have are red and I am not sure I will like the color combo.
Scnsaracer is offline   Reply With Quote
Old 07-14-2013, 01:15 PM   #2113
sc00by4life
Member#: 97135
Rolling will look exactly like OEM unless you're doing something wrong.
And again... There are a thousand threads on this. The seat on OEM lugs is EXACTLY the same as aftermarket, however it's possible that the shank width of the OEMs might not fit in the pocket of your new wheels. Play it safe and just buy a set of aftermarket lugs. Anything that is m12x1.25, or advertised to fit Subaru will work.
Old 07-14-2013, 02:44 PM   #2114
ryblair
Member#: 309638
2011 wrx premium
dark metallic grey
Can anybody point me in the right direction and let me know how 18x9.5 +30 with 235/40 will fit on my 2011 wrx? Will all fenders need rolling? Pulling? Any help appreciated
ryblair is offline   Reply With Quote
Old 07-14-2013, 03:04 PM   #2115
NWsoobie
Member#: 289516
2012 WRX
ISM
No pulling. Fronts will need a baby roll, and rears will need a solid roll. I flat rolled my rears for future setups.
NWsoobie is offline   Reply With Quote
Old 07-14-2013, 03:45 PM   #2116
ryblair
Member#: 309638
2011 wrx premium
dark metallic grey
Thanks man really appreciate it! Have a good one
Old 07-14-2013, 08:15 PM   #2117
Scnsaracer
Member#: 319511
2013 STI Sedan
Ice Silver Metallic
You're gonna need to run some pretty aggressive camber as well.
Old 07-14-2013, 08:26 PM   #2118
ryblair
Member#: 309638
2011 wrx premium
dark metallic grey
I kind of figures that. I have isc coilovers. Will camber affect drivability in any way for just the wear on the inside of the tire. I run a little bit right now cause in low on my stocks
Old 07-14-2013, 09:44 PM   #2119
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
With a +30 offset drivability is going to be horrible anyways mixed with lots of negative camber your suby will be trying to find center axes.
Old 07-17-2013, 01:40 AM   #2120
ryblair
Member#: 309638
2011 wrx premium
dark metallic grey
Decided I'm going to run a 225 tire rather than 235. Hopefully fitment will be a little better and cleaner looking.
Old 07-17-2013, 01:41 AM   #2121
ryblair
Member#: 309638
2011 wrx premium
dark metallic grey
Is the drivability really going to be that bad? I travel a lot
Old 07-17-2013, 12:17 PM   #2122
ABQautoxer
Member#: 198231
2007 Not a Subaru
Just to confirm, would 17x8 ET35 fit without any rubbing on stock fenders (235/45/17 tires)? I've run 17x8 ET45 just fine but wasn't sure if there was 10mm more to the outside fender without any issues.
ABQautoxer is offline   Reply With Quote
Old 07-18-2013, 12:12 AM   #2123
Azunhks
Member#: 90937
2011 Impreza WRX STi
Satin White Pearl
Wheels: Work Emotion 11R 18x9.5 +38
Tires: Federal SS595 255/35/18
Azunhks is offline   Reply With Quote
Old 07-18-2013, 12:25 AM   #2124
inferno6.1
Member#: 260586
2013 STI Sedan
^^^Very nice Azhunks...Here's my new setup below...18 x 9.5 TR Motorsport MT1's in 45 offset...18.5lbs each...Stock 245 tires. Now I just have to fix the ride height...
inferno6.1 is offline   Reply With Quote
Old 07-18-2013, 02:28 AM   #2125
j3pwrx
Member#: 361041
Hi Azunhks, are your fenders rolled? Any rubbing at all? camber?
Looks pretty flush. nice work!
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 01:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 10:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 05:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 02:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 03:20 PM
