Old 07-25-2013, 09:02 PM   #2151
NWsoobie
Member#: 289516
2012 WRX
ISM
Originally Posted by Mach V Dan View Post
It's a little bit hard to tell from that angle, but that looks pretty sticky-out to me. Got a shot from straight on, or from the rear?
--Dan
Mach V
FastWRX.com
Yah it was pretty pokey. Thats why I got rid of them. Didnt have the flow for LCA's. Here is the best one I dug out.
NWsoobie is offline   Reply With Quote
Old 07-27-2013, 02:31 AM   #2152
jork
Member#: 359613
2013 WRX Prem
hey all, not sure if this was the appropriate place but I was wondering if anyone knew what wheels these were? thanks
jork is offline   Reply With Quote
Old 07-27-2013, 02:36 AM   #2153
Dova
Member#: 315989
2012 WRX hatchback
Satin White Pearl
Looks like Rota SVNs
Dova is offline   Reply With Quote
Old 07-27-2013, 03:08 AM   #2154
jork
Member#: 359613
2013 WRX Prem
cheers buddy
Old 07-27-2013, 12:22 PM   #2155
NWsoobie
Member#: 289516
2012 WRX
ISM
Yep. 18x10 38's too. Damn I want them soo bad.
Old 07-27-2013, 01:20 PM   #2156
sc00by4life
Member#: 97135
Et30.
They don't make +38.
Old 07-27-2013, 01:24 PM   #2157
NWsoobie
Member#: 289516
2012 WRX
ISM
Originally Posted by sc00by4life View Post
Et30.
That's right. My bad.
Old 07-27-2013, 09:51 PM   #2158
RandR
Member#: 292132
2016 Cayman GTS
Racing Yellow
MY12 Club Spec with Yokohama ADVAN RS 18x8.5 48 ET and ADVAN NEOVA 08R
235/40 x 18
Obviously no issues with fit and prodigious grip - near ideal sidewall alignment relative to wheel width
RandR is offline   Reply With Quote
Old 07-29-2013, 01:26 AM   #2159
NickDev96
Member#: 355754
2013 Subaru WRX
Obsidian Black Pearl
so Rota SVN-R 18 x 10 +30's will fit with no issues if rolled? or would i need a pull as well? & what size tire would it be best with, dont want a stretch, just a wide aggressive stance so i was thinking 255's?
NickDev96 is offline   Reply With Quote
Old 07-29-2013, 02:37 AM   #2160
sc00by4life
Member#: 97135
depends on the tire and how low you are. with 10" +30 with 255's will definitely require a roll all around, possible slight pull in the rear depending on height/camber settings.
Old 07-29-2013, 02:56 AM   #2161
WhatsASubie
Member#: 362544
2013 Wrx
satin white pearl
whats the biggest size rim i can fit without stretching tire and rolling fender?
18x9.5?
WhatsASubie is offline   Reply With Quote
Old 07-29-2013, 06:09 AM   #2162
sc00by4life
Member#: 97135
18x9.5?
Look at the very first post in this thread......
At least TRY to help yourself.
Old 07-29-2013, 10:31 AM   #2163
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
and a 255 on a 10" wheel will be stretched...
10" wheel youre looking at a 265 or 275 to be square.
gsrcrxsi is offline   Reply With Quote
Old 07-30-2013, 12:35 PM   #2164
colin1234567
Member#: 212639
WRX= 13/SWP/SOLD
'10 NC2 Miata
Stick with the 18x8.5 Svn at this point.
colin1234567 is offline   Reply With Quote
Old 07-30-2013, 01:22 PM   #2165
TryHonesty
Member#: 346323
2013 WRX on E85
Have: OEM235/45/17 Tires - OEM 17x8 Wheels
Want: OEM235/45/17 Tires - Rota Grid 17x9 Wheels
Would these tires fit the 17x9 wheel for my 2013 WRX? No suspension mods at the moment and don't plan on them yet.
TryHonesty is offline   Reply With Quote
Old 07-30-2013, 01:25 PM   #2166
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Will fit fine and will likely not require any fender work.
The tires will be pretty stretched though.
Old 07-30-2013, 01:57 PM   #2167
TryHonesty
Member#: 346323
2013 WRX on E85
Have: OEM235/45/17 Tires - OEM 17x8 Wheels +53mm Wheels
Want: OEM235/45/17 Tires - Rota Grid 17x9 +42mm Wheels
Want2: OEM235/45/17 Tires - Rota Grid 17x8 +35mm Wheels
Would the second option be better? Is that offset way too low compared to the stock +53mm?
Old 07-30-2013, 02:34 PM   #2168
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
both want options will work fine for you. just pick one. I'd pick want1.
the offset is lower in Want2, but youre making up for that entirely by the loss of 1" in wheel width. 1/2" (13mm) on each side
you are pushing the wheel further out by 7mm, but then reducing it by about 13mm.
the Want2 will actually stick out towards the fender less than Want1.
Old 07-30-2013, 02:46 PM   #2169
TryHonesty
Member#: 346323
2013 WRX on E85
Sorry, last question. Would the tire stretch in 17x9 be non-optimal? I just don't know the total risk of overstretching tires by 1" more than they are supposed to be.
Should I just buy 245/40/17 with the 17x9 and just say **** the 235/45/17 and try to sell them :\
Old 07-30-2013, 03:31 PM   #2170
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
depending on the tire, 245 could be pretty square, or still a slight stretch. i know my Continental DW's are still stretched on a 9" wheel.
a 245 will fit better than your OEM tires for sure. 255 will be just about perfect on a 9" wheel IMO. it really depends on what you want.
Old 07-30-2013, 04:19 PM   #2171
SomeGoalie
Member#: 342696
2013 WRX Sedan
What he said.
If I were going to go with a wider wheel, I would get the widest tires I could fit, but that's just me. Depending on the tire I would go 255 or 265.
SomeGoalie is offline   Reply With Quote
Old 07-30-2013, 07:40 PM   #2172
TryHonesty
Member#: 346323
2013 WRX on E85
Thank you fellas. I think I will wait until I have enough money for new tires and new wheels at the same time and not risk stretching them.
Old 07-31-2013, 10:56 AM   #2173
topherrwrx
Member#: 319759
2012 WRX Hatch
2012 hatch on bc br. Interested in rota svn 18x10 with 255/35. Not worried about rolling. Question is will I be able to fit with out a camber kit and/or lower control arms. I have seen these fit on a few vehicles but I would like to know how much work it requires. Like a I said I'm not worried about rolling
topherrwrx is offline   Reply With Quote
Old 07-31-2013, 11:13 AM   #2174
sc00by4life
Member#: 97135
Most likely not.
You'll need some form of camber management in the rear. And depending on how low you are, you might need to pull the rear.
Old 07-31-2013, 11:47 AM   #2175
high boost
Member#: 200410
2009 wrx
seen the 18x10 svn +30 on a 2009 wrx didnt have a crazy stretched tire or camber
high boost is offline   Reply With Quote
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 12:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 09:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 04:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 01:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 02:20 PM
