Old 09-25-2013, 03:39 PM   #2326
Digitalwave
Member#: 321857
Originally Posted by Splatt2083 View Post
Not flush as in further into wheel well or further out of wheel well? Thanks
Further into the wheel well, as in in the tires might rub on the strut.
Digitalwave is offline   Reply With Quote
Old 09-25-2013, 04:49 PM   #2327
VEGAS WRX
Member#: 362867
2013 WRX
Further in. The larger the number the further into the wheel well. The lower the number the further out. Offset is mms that the center of the wheel is from the hub. A zero offset, the center of the wheel would be dead center on the hub/brake disc. (More lip) a +38 would mean the center of the wheel is 38 mm off center to the car. A +48 would be 10mms further toward center. It is "offset" from center. This is why different widths with the same offset sit different. Because offset is from center.
VEGAS WRX is offline   Reply With Quote
Old 09-25-2013, 05:55 PM   #2328
jlundy11
Member#: 324709
2012 WRX Sedan
Just for reference, the link below is an sti with 18x9 +63. Which is 12mm further in than a 18x9.5 +45 or 9mm further in than a 18x9.5 +48. I don't know how much the strut clearance varies on the GR WRX vs GR Sti but with minimal negative camber I'd guess you'd be ok.
http://www.iwsti.com/forums/gr-tires...ring-rf-2.html
jlundy11 is offline   Reply With Quote
Old 09-25-2013, 06:10 PM   #2329
sc00by4life
Member#: 97135
yeah looks like either 0 or positive camber on those pics....NOT safe. not to mention those most likely won't clear coilovers, and guys have difficulty fitting wider tires on the OEM bbs with a "sport" alignment.
realistically, there is such an assortment of wheels in the low to mid 40's that fit without issue, that an offset that high should not be considered.
Old 09-25-2013, 06:36 PM   #2330
Splatt2083
Member#: 337792
2013 WRX
Are you referring to my +48 or the + 63 he posted?
Splatt2083 is offline   Reply With Quote
Old 09-25-2013, 07:51 PM   #2331
jlundy11
Member#: 324709
2012 WRX Sedan
I don't know which coilovers you're referring to but mine gave me more inner clearance. And the Sti in the link is stock alignment and stock 245/40R18 tires. I personally think a +63 is retarded as well but like I was saying, this was just for reference.
Sidenote: I have seen guys running 18x9.5 +45 with 255/35R18 and -1.5 camber
Old 09-25-2013, 08:04 PM   #2332
sc00by4life
Member#: 97135
Coilover shock body is thicker than OEM struts. Not to mention depending on ride height and preload settings, the spring collars can get in the way.
The reason you can gain clearance with coilovers is through the use of camber plates which will actually angle the strut vs the hub (like with bolts).
This is all based purely on how they're setup though.
Old 09-25-2013, 09:01 PM   #2333
Ray521
Member#: 324129
2015 Evo
I have a 2013 WRX and I'm trying to figure out if a set of 225/50/17 Tires on 7-8" wide wheels will fit (stock is 235/45/17). I read the stickies and this thread but I just want to make sure before I spend a couple hundred bucks. It doesn't seem like a huge difference but the calculator I'm using says the tires will fill out the wheel well by an extra 7mm. This should fit, right?
Thanks
Ray521 is offline   Reply With Quote
Old 09-25-2013, 09:08 PM   #2334
sc00by4life
Member#: 97135
sure it'll fit, but a 225/45 would be better.
Old 09-25-2013, 10:03 PM   #2335
tgtrefz
Member#: 255232
2011 WRX Sedan Ltd
Spark Silver Metallic
The general rule is that you dont want to bemore than 3% taller or shorter thank stock
tgtrefz is offline   Reply With Quote
Old 09-25-2013, 10:13 PM   #2336
13whiteguywrx
Member#: 351622
2013 Wrx
Why is this?
13whiteguywrx is offline   Reply With Quote
Old 09-26-2013, 10:12 AM   #2337
Mach V Dan
Member#: 12029
MY general rule is to stay within 2% of stock, and I have heard many more people use 2% as a guideline.
Originally Posted by 13whiteguywrx View Post
Why is this?
For a couple reasons. First, if you change tire diameter your speedometer and tachometer will be off by the same amount, and after 2% it starts to be enough to actually be a nuisance.
Secondly, you're changing the car's final drive by the same amount, which will affect cruise RPMs, mileage, and driving behavior.
Finally, if the tires get too small you are losing ground clearance, and if they get too big in diameter you are risking contacting the bodywork.
SO: Generally speaking, if possible, stay within 2% of the factory diameter.
Now, one thing to keep in mind is that the GR/GV WRX and STI cars share the same chassis and bodywork, but the WRX comes with a smaller stock tire than the STI. (WRX = 235/45R17 = 25.3" diameter; STI = 245/40R18 = 25.7" diameter, 1.5% taller.) So you know there's at least 1.5% of headroom on the WRX in terms of up-sizing. I don't think I'd go much taller than that STI tire, though.
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
Old 09-26-2013, 10:51 AM   #2338
johnmkv
Member#: 300848
2012 WRX
LR
--Dan
Mach V
ive heard that going with a shorter tire will benefit the wrx owners how is that? is the gearing going to be shorter also resulting in faster acceleration since our gears are much longer than sti?
johnmkv is offline   Reply With Quote
Old 09-26-2013, 11:01 AM   #2339
SenorDucK
Member#: 327511
13' WRX 6 Speed
11sec VF52 EL-EWG-E85
it will have the same effect of shorter ratio, yes.
SenorDucK is offline   Reply With Quote
Old 09-26-2013, 08:11 PM   #2340
XTi24
Member#: 271749
2015 STi Launch Ed.
2012 WRX hatch
Suspension: stock everything
Wheels: Miro 111 (machined silver finish)
- size: 18x9.5
- offset: +40
Tires: Yokohama Avid 255/35/R18
Fenders: no roll or pull
So far no rubbing, but we'll see!
XTi24 is online now   Reply With Quote
Old 09-26-2013, 08:45 PM   #2341
13whiteguywrx
Member#: 351622
2013 Wrx
18x9.5 +35 rota G force wheels with 245 45 18 tires stock suspension rear fenders had to be rolled but not rubbing after that.
Old 09-26-2013, 10:06 PM   #2342
MileyCyrusTWRX
Member#: 367713
2014 WRX
Great thread!
I'm planning on going with a spring/shock combo. Possibly Koni Inserts with swift springs, or billstien shocks with swift springs. (STill haven't nailed it down)
I plan to get the suspension dialed in before I make a final wheel choice, but I'm generally curious about enkeis.
I really like the RPF1's
What's the general consensus on wheel size with this wheel on lowered cars? I've seen 17x9 et35 as a common place, but I want to avoid rolling fenders. Would 17x9 or 18x9 (et35) cause any rubbing on the fender with a spring/shock combo if the fenders are not rolled?
MileyCyrusTWRX is offline   Reply With Quote
Old 09-26-2013, 10:31 PM   #2343
13whiteguywrx
Member#: 351622
2013 Wrx
Originally Posted by MileyCyrusTWRX View Post
Great thread! I'm planning on going with a spring/shock combo. Possibly Koni Inserts with swift springs, or billstien shocks with swift springs. (STill haven't nailed it down) I plan to get the suspension dialed in before I make a final wheel choice, but I'm generally curious about enkeis. I really like the RPF1's What's the general consensus on wheel size with this wheel on lowered cars? I've seen 17x9 et35 as a common place, but I want to avoid rolling fenders. Would 17x9 or 18x9 (et35) cause any rubbing on the fender with a spring/shock combo if the fenders are not rolled?
Depends on what kind of tires you put on there. I had 245 40 18s on a 18x8.75 et35 had rubbing in the rear.
Old 09-26-2013, 10:34 PM   #2344
MileyCyrusTWRX
Member#: 367713
2014 WRX
Just what I needed to know. THanks for the info. I'll have to do some more digging.
Old 09-26-2013, 10:37 PM   #2345
13whiteguywrx
Member#: 351622
2013 Wrx
I did a minor roll and it stopped. Don't be scared about rolling your fenders. Go to a shop that does it right and you will be fine. Make sure they heat the paint and it will all be good I have had no issues with my paint
Old 09-27-2013, 09:17 AM   #2346
Digitalwave
Member#: 321857
Great thread!
A 9" ET35 with 245 or 255 tires would almost definitely need at least a light roll in the rear.
Old 09-30-2013, 01:58 PM   #2347
drtmcgrk
Member#: 353305
2011 premium wrx
swp
I have 18x9.5 et 38 with stock suspension and a rear fender roll, and I have no issues. I've tracked my car @ summit point main(Jefferson circuit) as well I just got home from VIR and had no issues there. I run a 255x35 re11's pretty square set up.
drtmcgrk is offline   Reply With Quote
Old 10-04-2013, 12:00 AM   #2348
johnsonroda27
Member#: 302186
2011 wrx
pearl white
So im going with a 18x8 but cant decide on offset.. The wheel im getting comes in +35 or +48.. I kind of want the 35 but if this is going to compromise anything negatively or hurt anything i dont want to do that.. Any quick input?
johnsonroda27 is offline   Reply With Quote
Old 10-04-2013, 09:45 AM   #2349
Digitalwave
Member#: 321857
The +48 will sit almost exactly like stock (completely sunken), it's the same width and only 5mm more offset. The +35 will work fine and at least provide some visual offset change.
Old 10-04-2013, 09:48 AM   #2350
johnsonroda27
Member#: 302186
2011 wrx
pearl white
Whats your vote?
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 12:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 09:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 04:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 01:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 02:20 PM
