Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 03-26-2011, 04:46 AM   #1
silverongold
Member#: 132599
02 impreza wrx
Default please help with misfire!!!!!!
so i am getting a misfire for all four cylinders. it occurs shortly after boost comes on, runs rough and robs power.
i have:
used fuel system cleaner.
replaced plugs.
gapped plugs down.
new fuel filter.
logged and found nothing out of the norm other than it pulls timing as it misses.
checked coil packs for cracks or any visual damage.
i am having a way frustrating time trying to figure this one out and really do not want to take it some where to be checked out cause i have no funds for it at the moment. if you have had this problem or have some advice please help me thanks.
silverongold is offline   Reply With Quote
Old 03-26-2011, 05:37 AM   #2
801_STi
Member#: 200756
07 yellow clearbra
swp sti "Pearl"
air leaks / tune
801_STi is offline   Reply With Quote
Old 03-26-2011, 11:28 AM   #3
BuGS
Member#: 81353
06 STI
Blackness...
Originally Posted by 801_STi
air leaks / tune
With this ^. Check the hose after the maf and under the IC
BuGS is offline   Reply With Quote
Old 03-26-2011, 12:30 PM   #4
Frag
Member#: 200258
04/5 STI
Blue/White
diff check maf that mf is always ****in **** up
Frag is offline   Reply With Quote
Old 03-26-2011, 12:31 PM   #5
WRX N EFX
Member#: 157721
2003 WRX
Jordan didn't you get the memo? having a misfire that is hard to track down is the new cool thing.
WRX N EFX is offline   Reply With Quote
Old 03-26-2011, 12:37 PM   #6
silverongold
Member#: 132599
02 impreza wrx
f you brandon
Old 03-26-2011, 12:42 PM   #7
WRX N EFX
Member#: 157721
2003 WRX
^^whats this guy think hes captain knots, thinks hes captain tying knots? whenever someone needs some knots tied they go to him... Bulls**t!!!
Old 03-26-2011, 01:18 PM   #8
silverongold
Member#: 132599
02 impreza wrx
ha ha
Old 03-02-2012, 03:51 PM   #9
silverongold
Member#: 132599
02 impreza wrx
How do you check this?
Old 03-02-2012, 03:58 PM   #10
silverongold
Member#: 132599
02 impreza wrx
Sorry to resurrect this thread, but I need a little help....... again. I replaced all four coilpacks and the misfire went away!! it was retarded expensive but a relief to have figured it out.
Since when i drive it i will throw a miss fire code usually wen idling or slowing down for a red light. (the check engine light will flash a few times and the stay on)
recently I have moved and made a descent change in elevation. (just got a wide band today, finally to check up on this)
last night i thought i noticed a little miss but no flashing light, i think this was just under light load in the rpms.
later in the night i was under a descent load probably around 4-5k rpms and the motor cut hard and then came back in. it felt like a pretty hard miss or some thing.
I have not checked the code. I unplugged bat to reset and start over so i can check that as soon as it happens again when i drive it with the wide band in.
Any clues for me of what to look into now considering the first post on this thread of the things i already tried?
Old 03-02-2012, 06:06 PM   #11
TurboJunkie85
Member#: 193412
1985 pumas.
white
Could be a couple of things.
MAF, (like everyone is saying)
Tumblers, are gummed up, so the butterfly valves are not opening in time....or not opening all the way....
Boost Spike
Bad injector
Dirty Cam sensor
Dirty Crank sensor
Timing belt could of skipped a tooth. minimum of 3 before it sends a valve into a piston
Compressor bypass valve getting stuck.
Can you provide Data logs? Fuel trims, Timing, Boost, FBKC the works?
TurboJunkie85 is offline   Reply With Quote
Old 03-02-2012, 09:29 PM   #12
Eww Evo
Member#: 299687
TT3
06' Wrx Project
^ I would check what he said. Also fuel pump, spark plugs dadada
Eww Evo is offline   Reply With Quote
Old 03-03-2012, 04:58 AM   #13
silverongold
Member#: 132599
02 impreza wrx
Soo I checked the code today. All four miss at low rom like 2k.
Old 03-03-2012, 05:34 AM   #14
boosted03subie
Member#: 298710
03 waggons hoooo!
What codes logged? U have acess to a decent scan tool or scope?
boosted03subie is offline   Reply With Quote
Old 03-03-2012, 10:51 AM   #15
toddguy
Member#: 158534
99 2.5 Wagon
76 Datsun 280Z
JORDAN! stop breaking ****!
toddguy is offline   Reply With Quote
Old 03-03-2012, 11:21 AM   #16
silverongold
Member#: 132599
02 impreza wrx
I know!!!!!!!
Old 03-03-2012, 11:23 AM   #17
silverongold
Member#: 132599
02 impreza wrx
Well I used an auto zone one and it's a miss in all cylinders. Freez data rpms where around 2xxx.
Old 03-03-2012, 11:49 AM   #18
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
Could still be just about anything, not enough data to trouble shoot it down over the interwebs. Suggest methodically going through everything one step at a time to start ruling things out.
907Bum is offline   Reply With Quote
Old 03-03-2012, 09:13 PM   #19
TurboJunkie85
Member#: 193412
1985 pumas.
white
All four misfire uh? Fuel filter or fuel pressure regulator on the passenger side fuel rail.
Check the wiring harness for the injectors/coilpacks drivers side under behind the battery
I would seriously check the timing belt.
Old 03-04-2012, 01:45 AM   #20
rallymobile
Member#: 82531
To misfire on all cylinders if going to a bad sensor or incorrect voltage reading of some kind. I suggest checking for knock counts and check your grounds. A bad injector or plugs will throw a code for one misfire and/or random multiple misfire. The computer is recognizing that all cylinders are running poorly and I assume that will be traced down to one simple problem. Very possibly a ground, computer or fuel pump. That's my $0.02, and I hope it helps. If you post your mods, then that could help for suggestions.
rallymobile is offline   Reply With Quote
Old 03-04-2012, 02:24 AM   #21
boosted03subie
Member#: 298710
03 waggons hoooo!
So what was the pid code? (P.....) And where their other pending pids?, autozone readers are junk and dont tell you crap. If you can get me the make, yr model, and pending or logged codes, I can give you the trble shooter along with test procedures and commin problem tips from my data base,
Old 03-08-2012, 04:42 PM   #22
silverongold
Member#: 132599
02 impreza wrx
Sick!!
Codes p0301-p0304
All with pending codes of he same numbers
What's logged codes?
2002wrx
Thank you!
Old 03-08-2012, 04:47 PM   #23
silverongold
Member#: 132599
02 impreza wrx
Thanks for the ideas i am checking some today ! A lot of these commin suggestions have been checked as listed in first post and replaced just in case for example fuel pres reg and filter.
Please keep following this for input man!
What's the best way to check
Computer?
Low volts ( I have a small oddesy batt, so maybe this is a prob)?
Grounds?
Old 03-08-2012, 04:51 PM   #24
silverongold
Member#: 132599
02 impreza wrx
New packs installed and that fixed it just a bit ago when I first created this thread. It was a lot more violent of a stutter and miss back then though.
Timing belt is a pe Kevlar belt
Roger Clark cam gears and all new tensioner stuff
Maybe 700 miles ago
I did have this checked by a shop as well
Old 03-08-2012, 04:55 PM   #25
silverongold
Member#: 132599
02 impreza wrx
Sorry I thought the first post said more than it did!
New
Fuel filter
Plugs
Pressure reg and test
Timing belt checked
Afrs are ok a tad on the rich under boost 10.5 on e85
please help with misfire question! silverongold Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-23-2011 09:21 PM
help with misfire please? silverongold Rocky Mountains Impreza Club Forum -- RMIC 21 02-23-2011 07:33 PM
help with misfire! silverongold Built Motor Discussion 4 02-23-2011 10:57 AM
help with misfires near Plattsburgh NY? foxboroxt Tri-State Area Forum 7 06-07-2009 12:54 AM
Help with misfires beauhawk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-09-2007 07:18 PM
