Welcome to the North American Subaru Impreza Owners Club Sunday October 23, 2016
Old 07-16-2002, 05:11 PM   #1
Member#: 3603
Default Horn no longer working
Didn't know where to put this.
My horns no longer work. I have the Hella Supertones hooked into the factory wiring. They just stopped working one day. I've checked the fuse, replaced the relay, hooked back up to the factory horn, and nothing still.
Any suggestions?
hacman is offline   Reply With Quote
Old 07-16-2002, 05:18 PM   #2
Member#: 1165
2012 dcrawford died
for your sins
Try running a wire from the horn straight to the battery...I mean ground the horn to the car...attach a wire to the horn...and touch the positive terminal of the battery with the wire. The horn should sound. If it doesn't then there is a problem with the horn. If it does then work your way backward on the wiring for the horn...and keep testing it with the battery. That may help your troubleshooting.
Reciprocity is offline   Reply With Quote
Cigarette Lighter socket no longer works Smash! Electrical & Lighting 23 02-17-2016 10:28 PM
I no longer work for CITY GARAGE!!! 2003 sedan Texas Impreza Club Forum -- TXIC 1 04-01-2003 10:57 PM
left fog no longer works KillerTHC Interior & Exterior Modification 7 02-03-2002 07:22 PM
('93-'01) Help, the old URLs no longer work! Caron Impreza Forum 3 06-28-2001 06:59 PM
Well, my trunk's keyhole no longer works! Snoopy General Forum Archive 11 05-16-2000 12:48 AM
