Welcome to the North American Subaru Impreza Owners Club Friday May 22, 2015
Old 07-16-2002, 05:46 PM   #1
Jewbaru
Member#: 1994
2013 Impreza WRX
Default Stock coolant temp sensor
We all know the stock temp guage doesn't move around much. However, does the stock coolant temp sensor output a wide range signal, that could be read for a guage or something?
I'm thinking about making a little relay type thing that will light up, or buzz to let me know when the engine is running too hot.
Jewbaru is offline   Reply With Quote
Old 07-17-2002, 01:54 AM   #2
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
Why not just install a gauge?
The stock H-C gauge sucks!!!! I've had my coolent up to 220 degrees and the stock gauge doesn't budge!!!!!
LVSUBARU is offline   Reply With Quote
Old 07-17-2002, 10:35 AM   #3
Jewbaru
Member#: 1994
2013 Impreza WRX
no room for an extra gauge.
Old 07-17-2002, 11:53 AM   #4
RallyNavvie
Member#: 7113
2008 Spec B
I echo the above statements. Find room for another gauge. You can get digital readout temp gauges from somewhere if that fits your scheme easier. As for the signal I have my old CTS sitting around somewhere. I could possibly check the resistance on it. Otherwise you'll know your car is running too hot when your fan is on constantly. You could always piggyback a light or something onto that relay so you know when your fan is running.
~Garrett
RallyNavvie is offline   Reply With Quote
Old 07-17-2002, 12:04 PM   #5
Jewbaru
Member#: 1994
2013 Impreza WRX
Ok, here's my exact plan. I found a little device you can build for around $10 that will trigger when it reaches a certain voltage. I am going to connect it to the coolant temp sensor, and program it to go off when the temp gets into the "too hot" stages. I'm then going to hook it up to either a buzzer, or a light that would go off, so I could hear/see if I was overheating much more quickly.
I would like to get the guage, but there's no room currently, and I can't watch the guage all the time when I'm driving hard. The light/buzzer would get my attention if there's something wrong. (Same premise as a shift light)
I was planning on connecting one to my EGT guage as well.
Old 07-17-2002, 02:42 PM   #6
giulio
Member#: 16040
1998 Impreza RS
Supercharged
Originally posted by Jewbaru
...I'm then going to hook it up to either a buzzer, or a light that would go off, so I could hear/see if I was overheating much more quickly...
Can you make it so electrodes on the headrest shock the driver's brain stem? sorry i couldn't help it
giulio is offline   Reply With Quote
Old 07-17-2002, 03:37 PM   #7
Jewbaru
Member#: 1994
2013 Impreza WRX
Honestly, yes you can.
Old 07-17-2002, 09:23 PM   #8
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
No room!!!!!!!
There is alwaysroom for more gauges!!! Currently I'm running eight aftermarket gauges in my Ru!!!
Engine coolant temp sensor check engine light? rhdude Mid Atlantic Impreza Club -- MAIC 2 11-09-2002 02:42 AM
CEL = engine coolant temp. sensor jrlegac8195 Service & Maintenance 1 10-30-2002 02:14 PM
Help finding Intake Air Temp or Coolant temp sensor jacksonww Legacy Forum 1 08-27-2002 01:42 PM
Coolant temp sensor LVSUBARU Normally Aspirated with bolt-on Forced Induction Powertrain 11 03-19-2002 12:28 AM
