Old 07-16-2002, 06:50 PM   #1
Blitzer
Member#: 21495
2002 WRX Wagon
white
Default Can't find the plugs to reset the ECU. Where?
I have a 2002 WRX and tried to follow these instructions for ECU reset
http://www.msu.edu/~briggsj7/WrxECUClearing.html
I found the two green plugs match only, but one black and one transparent plug which don't match (they are not male and female).
Is just disconnesting the battery resetting the ECU too? (could not find a clear "search" answer)
Thanks,
Blitzer
Blitzer is offline   Reply With Quote
Old 07-16-2002, 07:00 PM   #2
SFastWRX
Member#: 13379
I am Oz
Just disconnect the battery and then brake for several seconds. You're done.
SFastWRX is offline   Reply With Quote
Old 07-16-2002, 07:39 PM   #3
Blitzer
Member#: 21495
2002 WRX Wagon
white
AT HOW MANY MILES AN HOUR DOES MY GIRLFRIEND NEED TO DISCONNECT THE BATTERY, AND HOW HARD DO I BREAK THEN???
Just kidding...
thx
Blitzer
Old 07-16-2002, 07:48 PM   #4
SFastWRX
Member#: 13379
I am Oz
Depends on how good your girlfriend's been to you lately.
Nice car, BTW.
Can't get the CEL to reset mr.pessimist Baja Forum 10 07-07-2008 07:26 PM
Can't find any instructions to do the Kartboy rear shifter bushing Diversion Transmission (AT/MT) & Driveline 4 09-11-2005 11:19 PM
Is it time to Reset the ECU now after the HKS Full exhaust system starBug Transmission (AT/MT) & Driveline 0 07-26-2004 02:12 PM
Which is the correct way to reset the ECU?? z28dan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-26-2002 07:15 PM
Does it needed to reset the ECU for the following changes? V6 Normally Aspirated Powertrain 5 10-27-2000 09:32 AM
